Go to Post A problematic dynamic and culture becomes apparent when failure persists for such a duration and reoccurs so frequently that students begin to accept it as the norm, and never learn the proper way to do things. - sanddrag [more]
Unread 09-12-2009, 15:37
RandomStyuff RandomStyuff is offline
FRC #2212 (Spikes)
RandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the roughRandomStyuff is a jewel in the rough
Controlling PWMs through hardware
I tried searching for this (both here and on Google) and didn't find anything so I'm sorry if it's already been covered. If this is in the wrong section, I'm sorry too, feel free to move it (if that is possible).
My team is building (long story as to why) a scooter-like device using FRC parts, but we have one restriction: because our robot's code was wiped out when our school's IT guy 'accidentally' wiped our programming computer's hard drive (and yeah, we had backups, and my hard drive died some months ago, and the backup usb stick was lost, and ....I know, we need to be more careful) and we have an off-season soon, so we can't use the cRIO for this scooter project. We thought of using the old 2007/2008 (and earlier) system, but we can not find neither software nor anyone who remembers much about it. We came to the conclusion that the only option is to build something custom using two victors connected to some custom hardware that we are (hopefully) capable of making.
The big question is if this is possible in any way directly through some sort of lever ( we thought of using a potentiometer but the thought of the waisted electricity makes us shiver)to control the PWM signals sent to the victors?
Does anyone know where we can find what data is transmitted on which wire and the 'protocol' involved.
All we want to do is have two motors with some sort of variable speed, without having to use a control system.
(If anyone has a better idea, all ideas are accepted: keep in mind though, we are outside of the states, so ordering electronics from the USA is slightly more complicated here)
Thanks in Advance -
The Spikes 2212
EDIT:
I just managed to find the Jaguar's technical specs pdf and according to what I found there the three pins are 1)PWM 2) 5V(optional, doesn't need to be connected- can be ignored) and 3) Ground
2 can be ignored, and 3 is easy to figure out to do with (ground), but with 1WM
the refresh rates for the PWM format are:
-1= 0.67ms
0 = 1.5ms
+1= 2.33ms
I don't know what I can use to create signals that fast
Because using your robot's cannon to shoot at your nation's Minister of Education is worth all the 6 weeks of no sleep!
Unread 09-12-2009, 15:50
Data Nerd
FRC #0079
Re: Controlling PWMs through hardware
What about using some smaller micros to do it? Just buy a cheap 8bit micro that has a couple Analog to Digital pins and bit bang the signal out? Lighter than a CRIO or the old FRC control systems ever could be (plus uses less energy). You could, if you have one laying around, use a VEX brain to do it if you wanted.
Unread 09-12-2009, 16:24
AdamHeard's Avatar
Lead Mentor
So you just want a device to generate a PWM signal from a knob of some sort?
A servo tester would be a cheap way to do this, not sure if the packaging is very well suited to your purposes, but you could probably remove the POT on there and hook up your own that is the size and shape you want.
Unread 09-12-2009, 16:59
Don't be so quick to shiver at the power draw of a potentiometer. Typically it will be on the order of milliwatts. If you are moving a human with your device, that is nothing.
I have to run or I'd be more explicit, but google "PWM 555". A 555 is a standard chip that is useful for all sorts of timing operations. It is relatively straight forward to combine this with a few resistors/capacitors and your pot to make the PWM signal you want.
Edit: The modern way to do this is what Andrew said. Cheapy microcontrollers have gotten so easy and cheap that there are fewer and fewer reasons to do things in analog. The 555 is the old fashioned tried'n'true.
Unread 09-12-2009, 17:00
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
A Vex starter kit will have compatible outputs—though you may have to splice wires to get the proper connector gender. That will let you program it (in a similar manner to the old IFI RCs—they're based on the same architecture). You could probably hack an old joystick to connect to the analogue inputs on the RC, and use a simple variation on the default code to control it.
If you're going to go to that much trouble, though, you could just as easily use the IFI RC you already have (documentation and default code are available here and here)—as long you can track down a copy of MPLAB IDE. Actually, if nobody remembers MPLAB, there is probably an easyC default code for it that will work with the trial version of easyC PRO from Intellitek.
Alternatively, most other R/C car receivers will generate the right signals, but you'll have to control it with an appropriate R/C transmitter (e.g. with thumbsticks or a wheel).
If you're dead-set on building your own system, consider the ST Micro STM8S-Discovery evaluation board. (Free samples available from ST Micro, or cheaply from major distributors.) You can configure it with one of the standard examples to generate PWMs...but I haven't tested this myself, so I don't know if there are any practical limitations. You'll need to plan ahead, because the compilers (Cosmic, for instance) need registration codes that will take a business day or so to acquire (free, via e-mail; instructions on ST's website). More information here.
Unread 09-12-2009, 18:42
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
We were planning to build this servo tester kit to help teach soldering. The bonus would be that we could control a motor without the need to have a full controller setup. Sometimes it would be helpful when prototyping to be able to run a motor to see if things work as expected. With a battery, circuit breaker, fuse panel and a speed controller, we hope that this circuit will allow us to control a motor for testing purposes. We have not actually used this yet, so I can't guarantee that it will work.
http://www.gadgetgangster.com/find-a...projectnum=206
If a servo tester works for you, let us know.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 09-12-2009, 20:15
dman14 dman14 is offline
AKA: Darren Stahl
FRC #4783 (FRC #1305 Alumni)
dman14 will become famous soon enoughdman14 will become famous soon enough
A way to get MPLAB IDE can be found here.
Unread 09-12-2009, 20:40
AdamHeard's Avatar
Lead Mentor
If all you're doing is throttle control, you really don't want a whole control system on there.
Unread 10-12-2009, 07:59
Random,
The 555 PWM generator that Erik mentioned is likely the easiest for you to build with parts you can obtain locally. Radio Shack or equivalent stores in your area should have all you need.
Unread 10-12-2009, 08:36
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Random,
I agree with Al, like usual, on this one. A 555 timer will work just fine.
First link on Google seemed to look pretty good: http://www.dprg.org/tutorials/2005-11a/index.html
Try it out. This is a cheap and reliable solution. Probably way more reliable and safer than using a microcontroller.
Still the biggest reliability and safety problem will be the speed controller. Just with the Jaguar's reputation for failing out of the blue, I would use the trusted Victor 884. Keep it clean and away from any metal shavings and don't backfeed power into it by pushing your scooter around. You may also consider an 883 since it has a little more power handling than the 884, seeing that you're just running a simple scooter.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 10-12-2009, 21:26
Just thought of something for you as well. Motor current is proportional to motor load so make sure that the wheels on your cart and the transmission you use put the motor into a range on the motor curve it likes. I wish I had a dollar for every design I have seen that operated fine until you put it on the floor and tried to drive. The weight of the robot pushes down on the axles and without proper bearings that translates to very high motor current.
Unread 10-12-2009, 21:31
DonRotolo's Avatar
Back to humble
FRC #0832
See the last post in THIS THREAD
Search before you post, you'd have had the answer 18 hours ago.
Unread 10-12-2009, 22:36
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
At my school, we have a box with a nob and PWM out. It lets us generate PWM. I don't know what's in the box, how it works, but it has come useful to us at times... Sorry I can't help you any more.. but something like that does exist..
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 11-12-2009, 00:38
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Ill track it down one of these days and open it up to see what is inside (take some pics.)
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 14-12-2009, 02:11
DonRotolo's Avatar
Back to humble
FRC #0832
...or you can look at the thread I referenced 2 posts above, which tells you what's going to be inside that box of yours...
Controlling Arduino through Labview eitang NI LabVIEW 10 06-12-2010 01:20
PWMs Cap thing Brandon_L Electrical 1 02-02-2009 18:03
cmu cam pwms seanl Programming 3 29-01-2007 11:49
pwms fauxnominal Programming 8 12-01-2007 04:38
pwms for relays reilly Motors 3 18-02-2005 15:02
