Go to Post If everyone else in the world is an idiot, you may need to recalibrate your idiotness scale. - GaryVoshol [more]
Unread 10-12-2009, 16:52
AdamHeard's Avatar
Lead Mentor
Re: Hex Broaching?
You might want to check if a local college or shop has a pull broaching machine. Cal Poly (the school I attend) has a few, and is willing to let us use them. I've yet to do so though, as we have a line of push broaches in our shop which have worked adequately for us so far.
Unread 10-12-2009, 16:53
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is online now
FRC #0456 (Siege Robotics)
Re: Hex Broaching?
Originally Posted by NickE View Post
The biggest problem that we encounter with broaching is getting the broach perfectly perpendicular to the part. This season we built a fixture which is pressed onto the square ram of the press. This piece has a hole in it (about 1" deep, i believe) which is a slip fit for the broach. This ensures that the broach is held perfectly vertical in reference to the press, allowing for straight cuts.
Picture please? Sounds like a great idea!
Unread 10-12-2009, 16:55
AdamHeard's Avatar
Lead Mentor
Re: Hex Broaching?
It's pretty simple, imagine making a new end to your press that has a hole 1" deep in it that the end of the broach sits in.
Unread 11-12-2009, 03:30
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
Re: Hex Broaching?
Cory,
To be specific, a .505" hex rotary broach with a 1/2" shank runs about $70 from Slater Tools, when I asked for a .500" hex rotary broach, they quoted about $80 and about 1-2 day turnaround.
There are basically two kinds of rotary broach holders, Swiss type which are non-adjustable and the regular adjustable type. Since you plan to use it in a Haas milling center, you might want to consider the Swiss type. I asked the salesperson what the advantages were between the two. The Swiss type is smaller and has more clearance (it is round) whereas the adjustable has a wide base that could cause clearance problems since you will be spinning the tool holder rather than spinning your material. Adjustable ones are nice if you have a non-standard broach with a different length. You can only use standard length broaches in Swiss type holders and are limited to a max of 1/2" shank broaches.
Last year, I tried to use it on a bridgeport type vertical mill and failed miserably. I ended up having to retram the mill and gave up. We went back to our push broach which didn't always cut perpendicular no matter how hard we tried.
Of course your Haas is quite a bit stiffer. I would not expect a problem providing you adequately clamp your work piece.
This past summer, I decided to give it another try and placed the rotary broach in the tailstock of our lathe. Surprise, it was so easy and I felt like an idiot for not trying it earlier!
According to the slater tools chart, it takes about 600-700 pounds of thrust to rotary broach a 1/2" hex in aluminum.
Because rotary broaches are driven by the work piece, the hex can have a slight twist. One work around, is to reverse the spindle half way through the piece to reverse the twist. Rotary broaches don't care about spindle direction for cutting.
I'll let you know how it works out for us.
Unread 04-01-2011, 08:45
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Hex Broaching?
Originally Posted by polygon
This is a great thread, and I'm wondering if you have any more observations about the broaches. Has anyone run the broaching tools on a Bridgeport? Check out this video:
http://www.youtube.com/watch?v=uTsPXFy7Xx0
Also, you might consider Polygon Solutions as a pricing option.
Polygon,
Thank you for the information. It seems that your company's services and tools could be an asset to many FRC teams. That is a great video, as I have not seen broaching done in this way before.
Sincerely,
Andy Baker
Unread 04-01-2011, 09:32
Re: Hex Broaching?
Polygon, if you were a bit less faux-subtle about your motives here, you'd likely be a bit better received. Try again, and present yourself as a company with a product rather than apparently pretending to be a disinterested party. Most of us are engineers by inclination, and we like straightforwardness.
Unread 04-01-2011, 09:39
polygon polygon is offline
polygon is an unknown quantity at this point
Re: Hex Broaching?
Well said sir. My apologies, and thank you for the advice. I hope to be more helpful in the future.
Unread 16-06-2012, 05:35
nick_sheets nick_sheets is offline
FRC #3569
Team Role: CAD
nick_sheets will become famous soon enoughnick_sheets will become famous soon enough
Re: Hex Broaching?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Unread 16-06-2012, 05:36
FRC #3569
Team Role: CAD
Re: Hex Broaching?
We are looking to broach through 1.75" aluminum, does anyone have a recommendation on what size arbor press to get? We recently had a sposnor donate 1/2" Hex broaches.
Unread 16-06-2012, 06:25
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Hex Broaching?
The short answer is that's not going to work very well at all.
You're only supposed to go 2-2.5xD on a hex broach. Any longer than that and you'll get excessive wear and require massive amounts of force. You will need a 5 ton press and it will not be easy at all.
What is this for? Some type of hub? You probably don't need a full 1.75" of engagement and could counterbore your part to allow a more reasonable hex length.
2001-2004: Team 100
2006-Present: Team 254
Unread 17-06-2012, 18:03
FRC #3569
Team Role: CAD
Re: Hex Broaching?
Thanks COry for the reply, it would be a hub for a plastic wheel we got from our sponsor. Its about 1.5" long with a nub. Its a 1" od plug with a 1/2" bore.
Would you counterbore one side to .577" or similar and have the hex be 1.5" long? What would you suggest?
Thanks!
Unread 20-06-2012, 07:39
Bob Bonczyk's Avatar
Bob Bonczyk Bob Bonczyk is offline
FRC #0107 (107 Team R.O.B.O.T.I.C.S.)
Rookie Year: 1995
Bob Bonczyk is a name known to allBob Bonczyk is a name known to allBob Bonczyk is a name known to allBob Bonczyk is a name known to allBob Bonczyk is a name known to allBob Bonczyk is a name known to all
Re: Hex Broaching?
We made our own 1/2 hex broach years ago and it works just fine.
"Happiness lies in the joy of achievement and the thrill of creative effort." Franklin D. Roosevelt
Unread 20-06-2012, 09:14
Brandon Holley's Avatar
Re: Hex Broaching?
That sounds pretty cool. Have any pictures/details?
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 08-10-2012, 05:54
FRC #3569
Team Role: CAD
Re: Hex Broaching?
Hi guys,
Our team is making our FIRST (haha get it!) westcoast drive. We bought an arbor press and broaches a long time ago, but we can't seem to get a perfect broach... We have had this problem buying from FIRST suppliers as well. What is the best way to get perfectly hexd parts? When I mean perfect, I mean no wobble?
Nick!
Unread 08-10-2012, 09:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Hex Broaching?
Hi guys,
Nick!
Start it in a lathe, finish it in an arbor press.
Keyway Broaching Jonathan W. Technical Discussion 3 27-01-2008 09:58
Broaching? Easy way? brennerator Technical Discussion 3 22-01-2007 23:32
Hex vs. Key alysume Technical Discussion 12 31-05-2006 22:37
Hex Couplers Chris 481 Technical Discussion 9 03-04-2006 20:49
Non-Standard Broaching sanddrag Technical Discussion 3 17-03-2004 11:46
