Go to Post Which meant that I was completely unprepared when the congealing large globules suddenly accelerated back towards me at 64 ft/sec/sec. - dlavery [more]
Unread 28-07-2002, 10:58
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Question Gears
I know you can use 'Ring Wave' to make a ok looking gear, but i don't know how to anamate gears so they 'mesh' correctly. Can anyone help?
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 28-07-2002, 13:39
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I have an AutoLISP routine for AutoCAD that makes 3D gears, if you're interested.
You'd then have to export them, and it wouldn't help any with the animation, but it could be useful anyway. . .
Let me know if you're interested.
--Madison--
...down at the Ozdust!
Unread 28-07-2002, 17:14
Don's Avatar
Don Don is offline
#0288 (the RoboDawgs)
Don is an unknown quantity at this point
Send a message via AIM to Don
If you are using 3ds max 4 look up something called parameter wiring or something like that. It allows you to animate one gear and the 2nd gear will automatically rotate the correct number of revolutions.
Unread 04-08-2002, 11:05
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
well, not sure about the animating the gears, BUT
There is a plugin i used once that allows u to create gears (just like a standard primitive, just set the radis, number of teeth, etc. ) and it makes a gear for ya. I'll try and find its name, but you could probobly do a search on 3dlinks.com and find it there or something, just look for gears 3d studio plugin, somin like that. Good luck!
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 25-08-2002, 00:11
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
The trick isn't gears, since you can wire rotation together and there are plenty of freeware gear plugins. The trick is the chain that joins them. Using cloned arrays along a spline is just a pain in the butt. If somebody's got a chain plugin, PLEASE put it up.
Unread 25-08-2002, 20:39
Jack's Avatar
AKA: Andrew Schenk
i figured out how to wire them and i uploaded a pic of what it looks like. it if fully anamated. the mats. and lighting need work but the modeling is good. (except for the motor and air cylinder)
ps. all the gears mesh correctly
pps. i never thought about 'chain' because i didn't need to make any for this anamation. however, i think i will play around trying to find an easy way to make them because it seems tricky and a good challenge for me
Name:	trans2 metal2.jpg
Unread 17-09-2002, 10:17
Solaris Solaris is offline
Solaris is an unknown quantity at this point
Creating gears is somewhat difficult depending on your animation.
If you get the OD(Outside Diameter) of the teeth on the gears and then rotate them equally you should figure it all out fairly easy once you start but you just have to figure out a ratio of the OD's ya know 1 degree on one gear to every 17 degrees on another.
Unread 08-07-2003, 21:39
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
I REALLY NEED A GEAR FOR THIS FIRST CAMP THAT I AM A CONSOLER @. CAN YOU PLEASE HOOK ME UP WITH THE PLUGIN OR A READY MADE FILE?
THANKS!
The views expressed in my posts are Mine and mine only.
my myspace!
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
gears....? archiver 2000 16 23-06-2002 22:58
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
