Go to Post the jocks may have muscle, but we have extruded aluminum :D - [527]phil [more]
Unread 11-12-2009, 17:15
Phoenix.14's Avatar
Phoenix.14 Phoenix.14 is offline
AKA: Thomas
FRC #1757 (The Wolverines)
Phoenix.14 is an unknown quantity at this point
2009 Solenoid won't fire
I've been trying to set up a 2009 Festo solenoid, and it hasn't been firing. The manual fire switch works perfectly, and the LED is switching to orange when it should go into the extended state, and switching off when it should be in the retracted position (I'm assuming that that's how it should work). However, it still doesn't fire, even when the LED switches.
Is this a known problem, or am I working with a defective solenoid?
Unread 11-12-2009, 22:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: 2009 Solenoid won't fire
Are you working with Air Pressure? The Festos require a minimum of around 45 PSI to fire, last time I played with them (admittedly a few years ago).
Unread 11-12-2009, 22:41
Phoenix.14's Avatar
AKA: Thomas
Yes, we have a compressor, air storage tanks, automatic shut-off switch, etc hooked up and running. The solenoid is the only part of the system that I still can't get to work.
The air-carrying part is working right, though, because the manual fire switch still makes the piston go up and down. I'm fairly certain that I have the wiring done correctly according to the festo's guidelines, and it's plugged into the correct module in slot 8 of the cRIO. At this point, I really have no idea where the problem might be, unfortunately.
Unread 11-12-2009, 23:43
There are two different ways to wire the Festos and you can't tell by looking at them which way each should be - terminals 1&2 or 1&3.
Have you tried both ways?
Unread 12-12-2009, 14:07
Tom Line's Avatar
What language are you using, Labview?
Unread 12-12-2009, 16:40
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
The festo might be bad. Last year we had a festo that did the exact same thing that you described, we switched it out with a new one and it worked perfectly. If you have access to another one try switching them.
Unread 15-12-2009, 08:26
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
I believe Mark is correct. the pins you should be using are pins 1 & 3. We had this same situation during build season. Several other teams had the same problem. I can't recall the correct polarity, but I know that pin 1 is correct polarity wise. All you should have to do is swap the wire from pin 2 to pin 3. If that doesn't work I would assume there's something else going on. Good luck!
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 15-12-2009, 11:03
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The documentation for the two possible wiring conventions is here.
Originally Posted by GDC
Festo is committed to supporting the FIRST program. This year they encountered an unexpected problem, although not unsurmountable, in the production of the valve kit. The wiring of the valves supplied this year is different from the valves supplied in previous years. Rather than scrap a large number of valves or jeopardize meeting the deadline for the kit, Festo has updated the wiring instructions to enable you to use a valve of either wiring configuration. If after going through the instructions you cannot operate the valve please call the Festo Customer Resource Center at 1-866-463-3786 so they can troubleshoot or arrange to get you a replacement valve.
(From here.)
Unread 15-12-2009, 14:34
Phoenix.14's Avatar
AKA: Thomas
Thanks for the help, the switch from 2 to 3 made it work.
2009 Solenoid Valve & The Bill of Materials Martini1024 Pneumatics 4 24-02-2009 09:22
fire solenoid with butoon smcmahon NI LabVIEW 1 06-02-2009 15:40
Fire Drill!! Monkayyyyy Rules/Strategy 3 13-01-2007 13:02
Victor on fire P1h3r1e3d13 Control System 6 21-02-2006 23:31
