Go to Post It is NOT possible to fail within FIRST. It IS possible to fail within the competition (whatever your criteria for failure may be). - JVN [more]
Unread 11-12-2009, 23:43
Kdabr Kdabr is offline
FRC #3626
Kdabr is an unknown quantity at this point
Dev Boards for a nub
Howdy Everyone,
After having competed in the BEST competition this year with my school and doing quite well for a first year team, I have been collecting parts to build a robot of my very own. It is a robot that is going to be about the size/complexity (slightly more complex) than a BEST robot. I have rounded up all of the parts I need EXCEPT a good dev board. The BEST BRAIN (Their dev board) was nice in that it had multiple digital I/Os, servo outputs (not neccesary), as well as 4 motor outputs. I was wondering if any of the geniuses over here on the FIRST forums would know of any dev board that combines motor outputs (would you call that a speed controller?) and Digital I/Os. I was looking for an all in one solution just for the simplicity and convenience of it. If you guys think I should move up to big boy parts, a nudge in that direction would be appreciated as well.
Unread 12-12-2009, 00:24
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: Dev Boards for a nub
The arduino is a pretty cheap I/O board. It has digital I/O and analoge I/O so it can output a PWM signal. You would need a seperate motor controller.
http://www.arduino.cc/
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 12-12-2009, 00:50
FRC #3626
Already have a Duemillanove, love it.
I was just wondering if there is a magical product (like the BEST BRAIN) that combines that motor controller. Ive seen a motor shield addon for the arduino that is a bit small. Im looking to be able to drive 4 motors as well as 4 servos, while still retaining IOs for sensors/diagnostic lights
Unread 12-12-2009, 13:15
AKA: Bates
FRC #0125 (NUTRONS)
You could try out the VEX brain. It's not cheap but it's reasonably durable and has built in PWM output.
http://www.vexrobotics.com/vex-robot...ntroller.shtml
Unread 12-12-2009, 13:41
How much oomph do you need for the motor outputs? I've seen a couple motor control arduino shields that might work.
Unread 12-12-2009, 15:33
FRC #3626
The adafruit shield doesnt have as many servo outs as I would like. As far as my larger motors go, they are continuous rotation, not PWM. Doesnt the VEX brain only have pwm outs?
P.S.- When I say cheap, I mean not a CRio lol. $150 is not a big deal
Unread 12-12-2009, 17:51
Sovietmagician's Avatar
Sovietmagician Sovietmagician is offline
AKA: Ariel Eisenstadt
FRC #0694 (Stuypulse)
Sovietmagician is an unknown quantity at this point
Ok so one guy on my team once met this guy who invented something that is EXACTLY what you are looking for, at least i think so. The product is called a roboduino and essentially its compatible with arduino software and has 6 PWM out pins 6 ANalog pins and 14 digital pins, it is great for beginners and experienced people and i believe the fully assemlbed product costs about 50 bucks, so yeah i hope this helps
Shhhhhhhh... the code is compiling
Unread 12-12-2009, 17:53
oops forgot the link
http://www.curiousinventor.com/kits/roboduino
hope this helps
Unread 12-12-2009, 19:18
FRC #3626
That's the closest thing ive seen yet, pretty nice little product, although it looks like much of the functionality is the same as the stock Duemillanove. Is it possible to drive motors with that thing(non PWM)?
Unread 12-12-2009, 20:13
AdamHeard's Avatar
Lead Mentor
Sparkfun has some cheap motor controllers that you could use to power a motor off a vex controller. You could also take a continous rotation vex motor, open it up, and pull the electronics out; they will function as a small speed controller.
If you're planning on using something with more current, you're going to need to go with a larger speed controller.
Unread 12-12-2009, 20:32
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
I'm still inAuburn for Souths best. I find it funny that they are lke ROBOTICS! but yet, they aren't. our teamsmotor mounts failed, so we weren't as satisfied as we hopedbut still got about 25th overall.[/i]
Originally Posted by Kdabr View Post
Howdy Everyone,
Unread 12-12-2009, 21:47
FRC #3626
Well John, being a BEST expert, do you know if it is possible to purchase a BEST BRAIN? As for using the servos speed controller, my motors are quite a bit larger than the Vex ones, and draw more current
Unread 12-12-2009, 22:13
REVving up for a new season
FRC #2848 (All-sparks)
if you have a ardunio Duemillanove board that already has pwm outputs why not just get RC speed controls that take a pwm input to control a larger motor. In FIRST we use the innovation FIRST victor or the Texas instruments Jaguar, but realistically there are tons of other options. http://www.robotmarketplace.com/prod...lers_main.html
Integrated speed controllers is not a common thing for cheap development boards but if you already have pwm you might as well use that for control with a secondary controller.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 13-12-2009, 10:44
Gdeaver Gdeaver is offline
FRC #1640
You might want to take a look at this web site. Allot of AVR and motor drive and controller solutions. http://www.pololu.com/. Wireless PS2 controllers are not to difficult to interface and use as a wireless robot controller. One of my favorite combination motor and servo is the Dynamixel AX12+. They are controlled by a serial bus kind of like what we will be doing with the can jags. http://www.crustcrawler.com/motors/A...ex.php?prod=63 And the VEX brain really isn't that bad when you consider that it is part of a system. You can do allot more with it than build vex robots. I had a great time VEXING my neighbor's kids large gas powered truck.
Unread 19-12-2009, 02:49
FRC #3626
http://www.makingthings.com/store/ma...oller-kit.html
I think this is exactly what I want, in the smaller, more convenient form factor that I was yearning for.
Post any concerns that you may have. Are there any obvious problems with this board?
WPILib in Dev C++ mikelowry C/C++ 2 22-09-2009 10:41
Connecting Multiple PXI-boards for faster data aquisition speed Is it feasible? Relative0 NI LabVIEW 2 06-02-2009 21:58
Dev C++ Dested Programming 4 05-01-2005 00:55
The need for File Maker Pro 5 Dev. Edition archiver 2000 1 23-06-2002 22:50
