Go to Post ah, common sense, not as common as one might think... - Ansem Retort [more]
Unread 13-12-2009, 21:14
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: Side view of third try drive.
Unread 13-12-2009, 21:17
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: pic: Side view of third try drive.
doh. Ignore - I went and looked at the other pictures and realized I wasn't looking at what I though I was.
Unread 13-12-2009, 21:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Edit: Nevermind, I misunderstood the design.
Unread 13-12-2009, 21:20
Tom Line's Avatar
Triple DOH and apologies to the poster. You need to look at ALL the pictures to understand this drive setup. It is not what you think it is (nor what I thought is was).
So why have both chains running over the middle wheel? How do you control the motion of that wheel?
Unread 13-12-2009, 21:23
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
From other pictures posted by this team, it appears that it is in fact 2 chains. The four corner wheels are mecanum, and the chains feed to a ball differential, that allows the central omniwheels to spin only when the 2 gearboxes are moving in the same direction. For the most part, it acts as a standard mecanum drive, but the central wheels in combination with a suspension system provide additional forward traction and climbing ability.
Here is how it appears in reality: http://www.chiefdelphi.com/media/photos/34391?
Unread 13-12-2009, 21:34
NickE's Avatar
NickE NickE is offline
_
Looks like definite improvement with this gearbox mounting method over this earlier method. To save a little weight and make the gearboxes more compact, you could consider using the new Toughbox Nano gearboxes.
Unread 13-12-2009, 22:01
joeweber's Avatar
Coach team 1322
To save a little weight and make the gearboxes more compact, you could consider using the new Toughbox Nano gearboxes.[/quote]
The nano looks like a good idea except they are $78 each. The kit gear boxes will weigh more but save us some money. You can veiw our video and more pictures at http://www.team1322.org/ideas.htm
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 13-12-2009, 22:04
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Okay, I'm confused about something (trust me, this isn't an unusual condition): The advantage of mecanum is that you can make the bot go sideways by rotating front and back wheels in different directions. If you chain them together by tying them to the middle wheel, aren't you defeating this potential?
"It's NOT Just A Robot Thing!"
Unread 13-12-2009, 22:12
Joe G.'s Avatar
AKA: Josepher
I believe the plan is for the ball differential mounted on the center shaft to only allow power transfer when the 2 chains are moving in the same direction (when the robot is moving forward or backwards.) When the chains are moving opposite each other, when it is driving sideways, the ball differential will slip, no power will be transferred to the center wheel, and the chains will be allowed to move independently.
Unread 13-12-2009, 22:26
NickE's Avatar
_
I believe they're implementing this design for these reasons:
Unread 13-12-2009, 23:11
joeweber's Avatar
Coach team 1322
Here is a link to the first utube video of the drive. Maybee this will help with understanding the system. http://www.youtube.com/watch?v=urFsD0gA1D4
Unread 14-12-2009, 12:20
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Don't worry about being confused, this is a very advanced drive/suspension system.
(Correct me if I'm wrong with any details)
The 2 chains are not attached together. They are attached to a ball differential which allows them to drive the center (Omni) wheel when moving together and disengages them when the chains are driving in opposite directions (mechanum straifing).
There is also a pivot along the center axel through the omni wheels which allow the robot to keep all of the mechanums in contact with the driving surface even while cliimbing a ramp.
My only question is can it climb a ramp at any angle other than straight on? or will it slide sidewards if not aligned properly?
___________________
- Tennyson, Ulysses
Unread 14-12-2009, 13:31
joeweber's Avatar
Coach team 1322
You are correct the chains are not attached together. Follow some of the links from previous post for video and photos.
Yes it can climb ramps on an angle and does it very well but to make it work on angles we had to add a second set of suspension to the front.
Unread 14-12-2009, 16:33
Mr_I's Avatar
Thanks to all for the explanation. No, I did not realize the ball differential was in use (or even existed!). Very cool, but I honestly hope you won't need this in competition this year, because there are few teams that would be able to do this!
(Note: I don't mind being educated -- I figure it's part of my job in life to ask the questions that bunches of other people might have but are too shy to pose.)
Unread 14-12-2009, 18:17
joeweber's Avatar
Coach team 1322
Actually this system is very easy to build. The ball differental was the hardest part and we made it in house with no probblem. I also believe F.I.R.S.T. wants us to come up with new designs, thats the fun part. We have an addtional design we are working on for this that we will post when completed.
We have posted all parts of our design and anybody can build it. Below is the parts to the ball differental.
pic: 1346 Side View 2009 dtengineering Extra Discussion 8 05-02-2009 15:23
pic: Drivetrain Side View AustinSchuh Extra Discussion 23 30-12-2006 03:41
pic: 710 2004 side view of drive train CD47-Bot Robot Showcase 6 16-02-2004 19:43
pic: Team 271's Side View CD47-Bot Robot Showcase 1 17-03-2003 18:48
pic: Right Side view CD47-Bot Robot Showcase 2 03-03-2003 15:26
