Go to Post Amazing what you can find with a quick video and the unlimited power of the internet! - AveryLevin. [more]
Unread 13-12-2009, 11:33
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
pic: Wheel Idea 2
Sorry. Yes, I meant Live axles.
Unread 13-12-2009, 11:38
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: pic: Wheel Idea 2
The roughed Aluminium looks good for this. Only thing I would suggest is the replacement of your decorative hex holes with round holes. This would save a lot of manufacturing time.
Looks good, sort of a prehistoric ice cave themed look? (mabye its just the render lighting...)
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 13-12-2009, 11:44
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
If you are planning to use dead axles, the wheel has to have bearings that fit into it so it can be driven, which means you either have to somehow find a ball bearing with a hex outside shape. Or find a bushing in the shape of a hex shape externally and put a ball bearing inside of that which doesn't make sense as bushings sort of work like bearings.
If you are planning on driving the axles, you are fine.
Direct drive wheels aka live axles (which your wheel looks like it is made for as there is no mounting hole for a sprocket) you are fine as you are.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 13-12-2009, 12:11
The CAD Guy
Thanks, I originally had fillets on the hex holes so that during cutting the bit could just go to that point then continue on. The must have gotten deleted in all my many fixes and I didn't notice. Do you think that with the fillets it would speed it up enough or should I still change to circles?
I meant live axles. Sorry for the confusion, I must have gone brain dead while submitting this.
Unread 13-12-2009, 12:41
DonRotolo's Avatar
Back to humble
FRC #0832
As far as cool looks, it's a winner.
As far as manufacturability and efficiency, it could be further optimized:
1. Hex holes must be broached, round ones can be drilled. Unless you require a hexagonal hole, use round. (But, those hex holes in the spokes DO look cool)
2. The ring surrounding the axle area (that has those oblong slots in it) serves lettle purpose aside from adding weight. To understand why, imagine the metal 'spoke' if that ring wasn't there - it would go from the central hub to the outer rim. The ring might be distributing forces very slightly across the spokes, but not enough to make any difference. Instead beef up the center hub a little bit (thinnest area about 3/8-1/2 inch) and lengthen the spokes to fit.
3. Ease the edges of the spokes a bit.
Unread 13-12-2009, 14:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
How thick are the spokes? To me it seems you could get away with them being about half as thick.
Unread 13-12-2009, 16:00
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Judging by the picture, the hex holes seem pretty small. In order to maintain the "hex" look with fillets, you would need them to be tiny, which is just as bad because you don't want to be machining the wheel with a 1/8 inch bit.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 13-12-2009, 16:39
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Eliminate the external radius on the hub. External radii are the best way to make your machinist hate you. Everyone loves them because they look cool but you need a special tool to do it and it takes time. If you really want a non-square edge, chamfers are much better.
2001-2004: Team 100
2006-Present: Team 254
Unread 13-12-2009, 17:11
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Agreed and why not make the hub smaller if your going live?
http://www.chiefdelphi.com/media/img...2011234f_l.jpg
On these wheels (the one under the one standing up), there is a mini hub instead of a lightening pattern around the hub. Try it out in CAD and see if you lose more weight that way.
-RC
R.C.
MadTown Robotics Team 1323
Unread 14-12-2009, 10:21
Brandon Holley's Avatar
Ditto to what Cory is saying here. The external fillet is not providing additional strength to the wheel and thus is purely cosmetic.
Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 14-12-2009, 13:49
The CAD Guy
Ok, Here are a list of things that I could improve upon that I have taken from everything that has been said.
1. Switch from hex to circles. (Would it be better to go for a keyway circle? Or keep the hex on the drive? )
2.Trash the outside ring on the hub and make the spoke longer.
3. Take off the fillet on the hub.
4. Take off some of the width on the spokes.
If I have left anything out or am misinterpreting things, please, do not hesitate to correct me.
-Rion
Unread 14-12-2009, 14:44
-Rion
The change from hex to circles was only in reference to your lightening pattern in the spokes.
The choice of hex broaching for direct driving is based on our resources and experience with hex.
Unread 14-12-2009, 15:38
R.C.'s Avatar
Rion if you ever get some time. Send the wheel over to me and I'll take a look at it. I'll be able to give you detailed explanation of things.
-RC
R.C.
Unread 14-12-2009, 16:07
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
-RC
I agree with RC here. If you are going to drive it with a live axle, your interior hub can be smaller, those 5 interior slots can be omitted, and your spokes can all be longer.
Keep up the good work. It takes guts to put your design out here to be critiqued. Good job.
Sincerely,
Andy Baker
Unread 14-12-2009, 16:10
-RC
Publicly explaining and critiquing might be better for all of us who are still learning about wheel design, RC. I know I'm learning from these posts, so I'm sure others are too.
pic: Wheel Idea 1 Rion Atkinson Extra Discussion 12 14-12-2009 14:59
Detecting wheel slippage! Possible idea, amp/power feedback in Jaguars. 7-11number1 FRC Control System 1 10-01-2009 18:25
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
