Go to Post Mmmm scrap used parts. Dismantle, find data sheets and have fun.:D - techhelpbb [more]
Unread 14-12-2009, 22:25
Re: cRIO Does Not Communicate, Yet Can Be Pinged and Re-Imaged
Originally Posted by 1951-44U View Post
Yea, the lights on the relay module was what I was referring to. Do they signify anything (e.g. Digital Relay Module active and working? Data transmission?, etc.)?
They signify that the default code is rapidly switching the relays. Cute with nothing attached, a bit scary if pneumatics or any other outputs are attached to the module.
Greg McKaskle
Unread 15-12-2009, 17:57
1951-44U's Avatar
1951-44U 1951-44U is offline
ROAR.
AKA: Phil Chang
FRC #0025 (Raider Robotix)
1951-44U has a spectacular aura about1951-44U has a spectacular aura about1951-44U has a spectacular aura about
Greg McKaskle
So they signify activity in the digital outputs?
A cRIO that is running the OS can be pinged and it will respond. If it is not also running a robot code will also respond to the FRC protocol and will show as having robot code.
The cascading lights last year were not on the digital breakouts, but on the relay module, and that was a "feature" of the default project image and could have been in your code as well I suppose.
Greg McKaskle
So what would cause a cRIO to be pinged yet not communicate with the DS specifically? (I say the DS specifically because I can re-image from the laptop and can ping it via WiFi as well -- thus the problem is limited to the "DS <---> cRIO" connection)
Unread 15-12-2009, 21:25
Make sure to check the team ID on the DS as well as the IP on the laptop.
Greg McKaskle
Code deploys but does not save to cRIO Bill Taylor NI LabVIEW 11 15-02-2012 20:30
Crio network light does not light when camera plugged in Bongle Programming 16 16-01-2009 11:00
DS and cRIO Not Maintaining Communications Will_Sica FRC Control System 0 10-01-2009 13:39
RC will not communicate with OI Ryank Electrical 3 08-01-2008 17:00
Yet another NASA sponsored contest... And look, you can even win a Segway!! Elgin Clock Math and Science 5 17-09-2003 12:26
