Go to Post A sign of character is the ability to move on and make the best of what you have, even if you feel you were completely wronged. - Cory [more]
Unread 14-12-2009, 23:52
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Problem with cRIO Imaging Tool
We're having a weird problem trying to get a new cRIO-FRC set up to practice programming on.
We received a brand-new cRIO controller and have it breadboarded to power it up. We've been trying to reimage it to be sure the latest code is on it but every time we run the FRC cRIO Imaging Tool it fails to find the cRIO and returns the "No Compact RIO devices found" error.
I've found a few similar problems posted online, but not this exact one. I am able to run the MAX program and change the IP address with that. I can ping the controller as well, so I don't believe there is a communications problem, yet the imaging software refuses to run. We have tried two different laptops as well.
Any ideas? How can I be sure I have the proper image in the cRIO without the imaging tool? Has anyone had this problem and solved it?
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
cRIO Imaging Tool HELP PLEASE!!! furiousgeorge FRC Control System 2 08-02-2009 22:44
FRC cRIO Imaging Tool furiousgeorge Programming 1 06-02-2009 09:52
cRio Stand-alone Image Tool Vikesrock FRC Control System 3 29-01-2009 19:38
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
cRIO Problem Pneumaticsman NI LabVIEW 8 10-01-2009 11:59
