Go to Post Valentine's day, who has time for Valentine's day?????? I have code to write!! - paulcd2000 [more]
Unread 15-12-2009, 01:29
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: Air Suspension
Unread 15-12-2009, 01:33
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: pic: Air Suspension
Clever... since the pistons are all connected and of the same bore, the pressure and therefore the force on each wheel must be the same.
But since the weight distribution in your robot is not 100% even, do you8 have a problem with it sitting at a funny angle? Also is there a benefit to using double-acting pistons or could you save hose, fittings, and weight and go with single acting pistons?
Neat idea!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 15-12-2009, 07:55
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Alec Issigonis, the designer of the original Mini, had similar designs for a hyrdraulic suspension back in the day.
Neat Idea although there are often added complexities to adding suspension. Chain tension can be problematic.
Unread 15-12-2009, 07:57
joeweber's Avatar
Coach team 1322
We are using this design to replace our curent design. The old design cuts off the front of the robot and would create design problems with game collection peices. The new design clears the front and also makes it stronger.
Below is the old design
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 15-12-2009, 08:40
Joe,
I would just like to make you aware that in the past, using mechanical force to move a piston and create pressure was deemed illegal under the robot rules. Each year pneumatic rules change but before you dedicate your design, please wait for kickoff and then ask the question through the Q&A.
Unread 15-12-2009, 09:56
Regardless of legality, have a few students write white papers on these different approaches. Make them thoroughly research and explain them, and include pictures of the beasts. It will make applying to college and getting scholarships into a cakewalk.
Very cool designs!
Unread 15-12-2009, 10:18
Joe,
I would just like to make you aware that in the past, using mechanical force to move a piston and create pressure was deemed illegal under the robot rules...
I don't think the rules have ever been quite that specific and restrictive. In many applications, the robot mechanisms "push back" on the pneumatic cylinders and can potentially pressurize the system. In my experience, the main thing the inspectors have watched for in such cases is that a relieving regulator prevents overpressurizing things.
You wouldn't be permitted to use a totally closed pneumatic system as shown in the drawing. You'll want to put a regulator on it to maintain the desired pressure anyway, and that ought to take care of it.
Unread 15-12-2009, 10:26
GaryVoshol's Avatar
Cogito ergo arbitro
You have to watch what this does to your bumper zone, should bumpers be required again this year.
(since 2004)
Unread 15-12-2009, 15:52
dtengineering's Avatar
AKA: Jason Brett
Joe,
...using mechanical force to move a piston and create pressure was deemed illegal under the robot rules.
Al makes a good point... but it got me thinking that a system like this could be tied in to the robot's pneumatic system and you could actively raise or lower the pressure in the system to achieve different ground clearances... when you want to hold position and not be pushed around, just lower the robot frame right down on to the ground!
But regardless of FRC legality, this is a cool project on its own right.
Jason
Unread 15-12-2009, 16:18
NickE's Avatar
NickE NickE is offline
_
One thing I can think of to do this is have this pneumatic system on a secondary regulator and use a servo to actively change the pressure of the secondary regulator. I'm not sure if this is legal but it'd be interesting for sure. You could adjust how springy your suspension would be. Another idea would be to use a center-closing solenoid and close the solenoid when the piston is wherever you want it to be.
Unread 15-12-2009, 17:23
Creating pressure using mechanical force on legal pneumatic component has been deemed illegal in the past. Reasoning behind such a rule is the possibility of a pneumatic system already at full pressure, with flow restrictors, could conceivably exceed system pressure of 125 PSI if pushed on with enough force.
Also, until last year, pressure modulators were not allowed. Last year, a few changes in the rules did allow them and I remember seeing one robot that had somehow controlled a pressure regulator to achieve a desired effect. I don't remember if it proved advantageous or not.
Unread 15-12-2009, 17:57
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
I am loving the idea. It would prove very advantageous for anything. It has true real world potential. If legal it FIRST I would love to see it on a bot.
I agree with Gary, bumpers could cause a problem..
Unread 15-12-2009, 18:19
joeweber's Avatar
Coach team 1322
As shown on our other post http://www.chiefdelphi.com/media/photos/34389? we would attach the bumpers to each section of the drives which would allow them to move up and down with the wheels keeping them at the correct height. The only problem I see is the bumpers could be called articulating which would be illegal.
Far as the pneumatics I Like the idea of having a pressure relief valve and a pressure regulator to make it legal.
Unread 15-12-2009, 18:24
IIRC, Al, it did not extend to the generation of vacuums. I know of three separate instances where a team used 100% FRC-legal pneumatics to generate a vacuum via mechanical means. (2 in 2004 and 1 in 2007). All three were judged legal. It is possible to argue that this system creates 2 vacuum systems.
You could also make the argument that this effectively creates 2 closed-loop gas shocks, which have a rather off-and-on legality if I remember the past rules correctly. (Of course, then that begs the question of "Why not just do that on one cylinder instead of two?", but that's beside the point.)
And remember, now that we are in a bit of a rules discussion: 2010 rules may forbid pneumatics altogether or otherwise make this design either legal or illegal, so anything said here may or may not apply after 1/9/2010.
Unread 15-12-2009, 18:28
The CAD Guy
That makes perfect sense. A very good idea. And the argument of if the bumpers are articulating or not could be argued every which way.. Technically I would say they wouldn't be. What is the difference between a robot with center drop and this when it comes to the bumpers? They are moving up and down (Now yes not as much, but none the less. They are moving) so couldn't that technically be called articulating? The bumpers would only move with the wheels, which would go with the level of the ground, so wouldn't they technically never go above or below the rule book's allowance?
Just my thoughts. I may be misinterpreting something..
-Rion
pic: Robot suspension joeweber Extra Discussion 11 15-01-2010 20:32
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: 6 wheel suspension joeweber Extra Discussion 16 13-11-2008 18:22
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
