Go to Post Life is not about avoiding risk, but managing it. - dtengineering [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 12-12-2009, 02:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Mouse pointer and dual monitors
Does anyone know of a program that will constrain the mouse pointer to the primary display, and then release it to the secondary based on a gesture (such as hitting the boundary twice within X amount of time)? I always seem to lose my mouse off onto the secondary.
Unread 12-12-2009, 14:25
NickE's Avatar
NickE NickE is offline
_
Re: Mouse pointer and dual monitors
The only thing I can think of is on my Wacom tablet, it can be configured to have a button switch between mapping the tablet to one screen or to both screens.
Unread 12-12-2009, 14:39
AdamHeard's Avatar
Lead Mentor
Assuming you're refering when teh 2nd monitor is physically off/disconnected, but the OS is still running it, Ultramon is a great program I use to handle dual monitors. You can set a hotkey to toggle the 2nd monitor on/off.
Assuming both monitors are on the entire time, why can't you just move the mouse left (or right)?
Unread 12-12-2009, 15:40
I can easily enable or disable the monitor through ATI Catalyst, but I was hoping for something that would allow me to keep the mouse contained to the primary while both are on.
Unread 12-12-2009, 16:32
Honis's Avatar
Honis Honis is offline
AKA: Nate
FRC #2478
Honis is an unknown quantity at this point
That is an unusual request. I don't have a solution but you can enable the mouse sonar in windows to speedup finding the pointer (until you get the solution you're looking for).
Control Panel > Mouse > Pointer Options (tab) > Show location of pointer when I press the CTRL key (check box)
Unread 12-12-2009, 17:02
I have found something close to what I am looking for. By repositioning the monitors "1" and "2" in the display properties to be on a diagonal, I can essentially set a narrow pathway that the mouse can travel through between monitors. This lets me keep it on the primary for the most part, but is a little roundabout to get to the secondary. Still would be great to have a double-bump to break through the barrier.
Unread 15-12-2009, 14:49
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
sanddrag,
I don't know of one you can find online, but if you have any experience with any of the .NET languages (VB.NET, C#, etc.) you should be able to write a short program to do this for you.
The System.Drawing.Point that holds the mouse pointer position on the screen can be found at System.Windows.Forms.Cursor.Current.Position. Let me know if you need more info on this part.
From there, I would think sampling the cursor position on a fixed interval should be good enough to do the cursor trap on screen 1 and to watch for the 'screen side tap' gesture.
Hope that helps... have fun!
-q
p.s. Note that System.Windows.Forms.Cursor.Current returns the cursor which is currently the system mouse pointer... if you want, this means you may be able to have more than one cursor on the screen at a given time, then have your program switch between them based on some input... might be a fun project sometime
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
LCD monitors robot180 IT / Communications 30 15-06-2006 21:55
TTL Serial Port and PS2 Mouse Interface cbolin Electrical 8 29-12-2004 15:00
Optical Mouse / Ball Mouse Clark Gilbert Chit-Chat 26 22-07-2004 13:17
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
