Go to Post don't be grumpy. No one is allowed to be grumpy during build. - JaneYoung [more]
Unread 14-12-2009, 08:46
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Controlling PWMs through hardware
[quote=Tristan Lall;887100]A Vex starter kit will have compatible outputs—though you may have to splice wires to get the proper connector gender. /QUOTE]
A lesson we've learned the hard way - before you splice all your PWM cables, simply put some header pins into the female side - instant male-male PWM!
I'm still scratching my head as to why nobody makes Male-Male PWM cables.
With the amount of teams who use VEX controllers at least for prototyping, if not special projects like yours, there should be some sort of market out there.
Hi!
Unread 14-12-2009, 11:03
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Just use a FRC Y Cable, it has male ends on both sides.
Unread 14-12-2009, 11:56
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Adam,
Can you post your vision code in a thread? I've looked all over the WPI site and can't find it!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 14-12-2009, 22:35
xanarchyx xanarchyx is offline
Capt' of Manipulator
AKA: Collin Matthews
FRC #1714 (More Robotics)
xanarchyx is an unknown quantity at this point
hey guys, I myself have been thinking about this for the last year on and off and with a bit of research found the answer.
Like someone from 111 i believe had posted, use a 555. They are exactly right.
After some testing and troubleshooting i got it down.
you need 1 555 that outputs a steady 50Hz signal. That should go to the trigger pin on a second 555. Use the second one to create the pulse 1-2ms with a pot (50-100K) and around a .2 uF cap.
I used a 556 IC, its got 2 555 built into it, this made it smaller and a bit simpler to wire.
Or.... like someone said you could probably use a vex controller although iv heard there's sometimes problems with that.
I guess if your not very comfortable around breadboards, go with the vex controller.
Unread 15-12-2009, 15:23
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Or you could look into an Arduino. It's a controller that's pretty cheap ($30 or so) and can be programmed through a USB cable. It has an IDE which uses a language which is basically C. It can also output PWM signals, so it could be useful for your case.
Twitter Profile
Controlling Arduino through Labview eitang NI LabVIEW 10 06-12-2010 01:20
PWMs Cap thing Brandon_L Electrical 1 02-02-2009 18:03
cmu cam pwms seanl Programming 3 29-01-2007 11:49
pwms fauxnominal Programming 8 12-01-2007 04:38
pwms for relays reilly Motors 3 18-02-2005 15:02
