Re: combo encoder and chain tensioner
Instead, install it on a tensioner that supports its shaft independently. (See here for some examples of shaft-mount encoders that you might be able to use.) |
Eric - thanks, but that photo's a little grainy in that area, I can't quite make out what's behind the sprocket (or is it hidden by the sprocket anyway?). Also, I planned on using surgical tubing or equivalent to give a bit of compliance. We've had problems other years with mounting plates that didn't quite line up the encoder axle with the axle it was encoding. Thanks very much. - Steve Last edited by SteveJanesch : 15-12-2009 at 17:03. |
Here's better pictures of what we did in 2007 and 2008.
Joe,
Thanks, those pix make it very clear. I had in mind spring-loading it on an arm, kind of like a bike derailleur, rather than mounted right on the frame. I think we'd be okay if there's not a lot of play to begin with, otherwise the slack being taken up during acceleration might give inaccurate readings. - Steve |
Steve,
I'd be worried that when the slack is taken up during acceleration, the chain gets loose enough to skip, defeating the purpose of the tensioner. Austin |
When you put a spring loaded tensioner on one side of a drive chain that goes both directions, in one direction you shouldn't have torque startup issues, but in the other the initial start may be enough to pull the tensioner and loosen the chain adding quite a bit of slack. And more slack = higher chance of popping off Also the main reason bike derailleur's are spring loaded is the gear changing system, fixed drive bikes simply slide the back wheel forward and back to tension the chain and no spring is involved. |
#7
Thanks, all. It looks like a single sprocket that's actually taking up tension is probably going to give us problems. I'll shelve it for now and lean on the mechanical guys to give us a more conventional means while keeping my sketchpad handy.
Steve |
| Chain Tensioner | RoboGeek99 | Technical Discussion | 23 | 12-01-2009 21:16 |
| what Chain size and tensioner to use for the drivetrain | edBringas | Technical Discussion | 28 | 22-01-2008 14:42 |
| pic: Kitbot Chain Tensioner 2 | Donut | Extra Discussion | 13 | 10-12-2007 15:57 |
| Chain tensioner usage | Rhs953 | Kit & Additional Hardware | 3 | 10-02-2004 17:04 |
| Chain Tensioner? | Gabriel | Technical Discussion | 14 | 29-01-2004 09:16 |
