Go to Post If the left side of your brain controls the right side of your body then left handers are the only ones in "their right mind". - Al Skierkiewicz [more]
Unread 03-11-2001, 14:55
punky2k1 punky2k1 is offline
punky2k1 is an unknown quantity at this point
Send a message via AIM to punky2k1
Unhappy Wheels
Can you send us more 8-inch lawn-mower wheels? The hubs were bent during fabrication, and they will not spin on the center.
-Thanks
Team #224
Unread 03-11-2001, 16:39
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
If you are local, you can contact Mr. Martus and get new wheels.
If you are not local, it may be quicker to order them directly from McMaster.com
page 1124
Part number: 2331T53
Description: Welded Rim Semi-Pneumat Wheel W/Ball Bearings 8" Dia X 1-3/4" W, 1-3/8" Off Hub, For 1/2" Axle, 60#Cap
Good luck.
Joe J.
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
Question about wheels Randy_Ai Technical Discussion 9 24-01-2002 17:14
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
