Go to Post There is nothing that compares to the smell of burning flesh, especially when it is your own. - Al Skierkiewicz [more]
Unread 13-12-2009, 19:46
HAL3019's Avatar
HAL3019 HAL3019 is offline
AKA: Mike LiBretto
FTC #3019 (HAL)
HAL3019 is an unknown quantity at this point
Send a message via AIM to HAL3019
[FTC]: More assistance...
Thanks everyone for the help before! I have a couple more questions that other might have asked, or are asking. The first being, how do you mount the Tetrix metal to PVC tube? I mean screws get in the way, and I'm not too keen on the adhesive rules. The second question is regarding the LabVIEW 2009 (or 2010, whichever came with the kit). Does anyone know of block updates and could provide a link? Our sister team has a blockset we don't (the move motor group) and I don't remember it being in the first installation.
Unread 13-12-2009, 21:01
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: [FTC]: More assistance...
Regarding the PVC pipe, you just have to drill holes in it and bolt it on. if you are trying to spin the tube like an axle, i suggest taking one to the pieces of channel that has only one set of holes in it,the 1x1x1 piece. Then drill two hole through the pvc pipe on the vertical axis that line up with two of the holes in the hole pattern. then you need some bolts that are extra long that dont come in the kit but are included in "related hardware". use spacers to space the tube to the center of the piece. bolt it together and now you have a mount.it looks kind of like this(double lines or the metal single are the tube stars are the bolts, disregard dots.
sorry for the lack of pictures. ill try to post some soon.
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 13-12-2009, 22:36
HAL3019's Avatar
AKA: Mike LiBretto
FTC #3019 (HAL)
Thanks, but we can't bolt it on, the bolt would get in the way of the ball. The pipe is acting as an exit tube because we can control the path of the ball better... are adhesives for the metal to PVC allowed?
Unread 13-12-2009, 23:48
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
use flush bolts on the inside facing out if that would work
Unread 14-12-2009, 07:42
From the manual
<R5> c. The following additional components may also be used:
5. Polycarbonate glue/cement is allowed, only for the joining of polycarbonate pieces. Use of polycarbonate glues/cements may or may not be allowed in the pits at tournaments based on site-specific rules or requirements.
12. PVC cement and cleaner (only for gluing PVC). Use of PVC cements and cleaners may or may not be allowed in the pits at tournaments based on site-specific rules or requirements.
<R9> Parts may NOT be modified as follows:
Welding, soldering (except as listed below), brazing, gluing, melting or attaching in any way that is not provided within the TETRIX System will NOT be allowed.
Although slightly contradictory, PVC cements can be used to glue PVC to PVC and polycarbonate glues/cements for polycarbonate, but glues of any kind cannot be used to bind other robot parts together to form structural bonds. Threadlocker is the only exception when used on hardware only.
Unread 14-12-2009, 22:42
HAL3019's Avatar
AKA: Mike LiBretto
FTC #3019 (HAL)
okay, now the compatible fastners include a flat head screw right? to drill thru the PVC and into the Tetrix?
Unread 15-12-2009, 16:21
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
They are all in the Tetrix palette. These VIs are polymorphic meaning if you wire a single motor control to Move Motors it will move a single motors, if you wire an array of motor controls to Move Motors it will move that group.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 15-12-2009, 16:25
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Don't think so. Read the manual.
Like Aquidneck Island Robotics on Facebook!
Unread 15-12-2009, 17:14
Meaning...
<R5>, c. The following additional components may also be used:
13. Compatible mechanical fasteners (nuts, bolts, screws, etc.)
Those two rules together says only use Tetrix Fasteners/screws.
Unread 16-12-2009, 15:26
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Meaning...
The rule states:
Meaning if you have 6 - 32 screws of any length and shape go ahead and use them.
Unread 16-12-2009, 15:38
One needs to read the Q&A for specific answers. This is but one in the "other parts and materials"...
This is in regard to the original question in post #2.
A: It is impossible for us to list and/or rule on all compatible or incompatible fasteners. However, information about the intent of the rule should provide sufficient guidance.
Rule <R5>c13 allows "compatible mechanical fasteners (nuts, bolts, screws, etc.)." The intent of this rule is to allow teams to use fasteners from any supplier that are substantially the same as TETRIX fasteners. Compatible fasteners are characterized by using the same thread characteristics as TETRIX fasteners. For example, an acceptable substitute for the TETRIX 6-32 thread, 1/2" length socket head cap screw is a 6-32 thread, 3/4" length, button head cap screw purchased at a local hardware store.
Threaded rod with the same thread characteristics as TETRIX fasteners is basically a headless screw and would be an acceptable substitution as long as it is used as a fastener and not as a structural element.
Unread 16-12-2009, 15:45
jamie_1930's Avatar
Team Role: Student
But a second in your earlier post you said that only tetrix fasteners maybe used. This is what I was clarifying that any screw that is 6-32 is considered compatible and may be used.
Unread 17-12-2009, 09:46
The one refers to me. I thought I had read that in the Q&A last week so I went looking for it for the correct interpretation.
[FTC]: Can anyone lend assistance? HAL3019 FIRST Tech Challenge 11 17-11-2009 21:21
[FTC]: More than 3 motors in use? Connor FIRST Tech Challenge 1 06-01-2009 19:02
[FTC]: more than 4 input devices? saaby FIRST Tech Challenge 2 18-11-2008 18:44
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
