Go to Post Achieving a goal by merely finishing, or reaching mediocrity is not acceptable; Excellence is the only satisfactory result. - AdamHeard [more]
  #31   Spotlight this post!
Unread 10-12-2009, 13:28
Dick Linn's Avatar
no team (Synergy)
Re: Afghanistan robot
Nathan is in a 443 acre camp in a 3 square mile secure area out in the middle of the "Desert of Death". There are thousands of Marines there, probably more than a few big mean ones. I think it is a pretty secure facility.
Hey there, Mario Gal! You doing OK? Nathan did get to hang out here at the house a couple times before he left.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #32   Spotlight this post!
Unread 10-12-2009, 14:32
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
History tells us that nothing is really secure.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
  #33   Spotlight this post!
Unread 10-12-2009, 15:49
Dick Linn's Avatar
no team (Synergy)
Yes. I appreciate that more than most. Read my signature line carefully.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #34   Spotlight this post!
Unread 10-12-2009, 16:25
Dick Linn's Avatar
no team (Synergy)
Update from Nate:
I’ve got an update on our parts scavenging. We found a box originally used to control a camera. Contained inside (the box was brand new, too) was a 12VDC motor with a 4:1 tranny, a 24VDC motor with a 3:1 tranny. Don’t know how fast they spin or what their output is, but we’ll figure it out. Also we got 4 limit switches, 2 sensors that measure how far the sprocket has traveled, a circuit board, and there is a voltage regulator that controls 24V to 12V, but I haven’t figured out exactly where it is. If it’s on the board it could get interesting. This thing was a miniature goldmine for hardware. Got some really small chain and sprockets, 2 worm gears, and some bearings too. We’re going to look for another one so we’ll have two 12V motors and then test their capabilities to see if we can use them as drive motors. We’ve got the drive wheel and the tread itself drawn up in CAD, just need to put a few more components in and we can design the drivetrain/chassis right there in the computer with full 360 degree views of a 3D model. There’s tube stock aluminum over there, though it seemed a little thin to be a good frame material in my opinion. I’ll send a flashdrive or a CD with pictures and our design as we progress. The search for parts is coming along nicely and we’ve got some good prospects on where we might find another one of these boxes.
-Nathan
Keep in mind folks, this is a project to keep them occupied in the off hours while they are stationed in a flat, featureless desert camp. I hope they don't start swiping parts off an Abrams tank or something.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #35   Spotlight this post!
Unread 10-12-2009, 17:08
enrgizerbunny enrgizerbunny is offline
AKA: Nathan Waters
FRC #0975 (Synergy)
enrgizerbunny is on a distinguished road
Alright. I was finally able to get the reply page to load, so this post may get long again.
We're currently in the process of designing the drivetrain and chassis in a CAD program on one of our personal computers. In theory we'll have a 3D model as we build.
I know these descriptions are vague, because my knowlege of the components is only what's printed on them.
As of now we currently have:
A set of treads and all the necessessary wheels to drive them.
1 24VDC motor on a worm gear (window motor) rpm/torque/hp unknown
1 12VDC motor with 4:1 gearbox attached, rpm/torque/hp unknown
1 24VDC motor with 3:1 gearbox attached, rpm/torque/hp unknown
1 Gearbox 1:1.84 ratio, output shaft is perpendicular to input
Sprockets and chain, large and small. Not enough to complete project.
2 worm gears
3 bearings with the possibility of being used on axles
4 limit switches
2 Potentiometers
1 circuit board with about 6 capacitors among other components that would be difficult to desolder/remove
1 switch that will most likely serve as a main power switch
1 voltage regulator 24VDC to 12VDC (I'm still finding it, but I know it exists for the 12V motor with the gearbox) Not sure if it works yet or not, but it likely does.
12VDC batteries 880 cca
There's more than enough scrap metal in usable condition available to us as well. Getting things like keyed rods is more tedious, but available.
I think there was a little confusion (my fault) when I said that everything was 24VDC. We have 12V batteries, but most things run on 24V. Yes, that means almost everything has two batteries wired in series. Since total output voltage =24VDC, most the components such as motors are 24VDC. If there's anything that runs on less voltage, it has to be stepped down at the component.
Our design is looking to incorporate a set of treads (think tanks anyone?)
two large wheels-1 drive, 1 roller
1 small roller wheel between the two which will hopefully be on a strut to move up and down with the terrain
Dimensions:
length of tread with wheels in place: ~32 inches
Height of tread with wheels in place: ~12 inches
The treads will be the outside of the bot, no outer frame rail if I can help it. I think it will probably be just wider than it is long. We're going to try to build an arm or some sort of manipulator when we finish the drivetrain.
  #36   Spotlight this post!
Unread 10-12-2009, 17:22
AKA: Nathan Waters
FRC #0975 (Synergy)
Update from Nate:
On we would never do anything like that. The camera box that was practically new was damaged. It suffered some sort of trauma that caused all 4 of the screws attaching it to the mount to be sheared clean off, which also caused some internal damage, but it seemed to be practically new otherwise.
  #37   Spotlight this post!
Unread 16-12-2009, 23:24
MarioGal56's Avatar
MarioGal56 MarioGal56 is offline
AKA: Katy
FRC #0975 (Synergy)
MarioGal56 is infamous around these parts
Send a message via AIM to MarioGal56
Nathan said they have enough games now, He would like snacks such as:
Nip Chee (its a cracker by Lance)
peanut butter crackers
and any kind of snack you may take for granted over here.
  #38   Spotlight this post!
Unread 16-12-2009, 23:26
MarioGal56's Avatar
AKA: Katy
FRC #0975 (Synergy)
AND GIRL SCOUT COOKIES!!!! he loves Samoas.
  #39   Spotlight this post!
Unread 01-01-2010, 20:51
Dick Linn's Avatar
no team (Synergy)
This just in:
"...Christmas wasn’t too bad and New Year’s was pretty good we had a fire in our burn barrel and made s’mores....."
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #40   Spotlight this post!
Unread 01-01-2010, 21:31
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
This just in:
Good for them! Anything to take thier mind off of where they are and what they are up against .................if only for a short time.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
  #41   Spotlight this post!
Unread 01-01-2010, 22:01
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
All of this is great and such but don't you think they may be a little difficult to ship? With everything that is going on in that region and with what happened here in Michigan at Christmas, security is high. If the military sees gears and motors, electronics and such, there may be trouble. Heck I couldn't even send canned vegetables to Canada. They destroyed everything.
  #42   Spotlight this post!
Unread 02-01-2010, 03:33
rkelly23 rkelly23 is offline
FRC #2975
rkelly23 will become famous soon enoughrkelly23 will become famous soon enough
If we sent them a few parts they could mount thier M-4's on thier robot and it could keep them occupied and safe!
  #43   Spotlight this post!
Unread 11-01-2010, 19:37
NC GEARS's Avatar
NC GEARS NC GEARS is offline
AKA: David Carrier
FRC #1918 (NC GEARS)
NC GEARS is an unknown quantity at this point
One of our former team members just deployed to Afghanistan. He says:
"One of my sergeants and I are starting on a robotics project, we’ve got some treads and we found some chain and sprockets, I even found a gear box, I’m still looking for another one."
So if anyone knows where there is "another gearbox" over there, holler.
I'll keep posting if anything comes of this project. Robot enthusiasts are nuts.
that makes sense homie g in the hizzle
United States Coast Guard Academy
Class of 2014
  #44   Spotlight this post!
Unread 07-02-2010, 03:22
AKA: Nathan Waters
FRC #0975 (Synergy)
Eh, the whole thing kind of fizzled out when we had no controller for it, if anybody sent parts that I haven't recieved I'll ship 'em back when I get them, but I moved to a different FOB (Forward Operating Base) and we never started building. I'm going to send back the parts I have and probably do something in my spare time, lots of spare time.
Robot-to-robot and robot-to-trailer GaryVoshol Rules/Strategy 11 06-01-2009 19:18
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
Can an a robot take a tetra from another robot in their allinace? Koko Ed Rules/Strategy 3 10-01-2005 23:01
Robot Gallery from the 2003 robot expostion in Tokyo, Japan Andrew Rudolph Chit-Chat 1 04-12-2003 15:22
