Go to Post you know you're going to meet someone important, so you put on your robotics team shirt. - NorviewsVeteran [more]
Unread 16-12-2009, 16:50
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Driverstation Pong!
Yesterday, the programming part of our team had a little fun playing pong on our (still functional!) Driverstation. I had originally written the code coming back from one of our competitions while trying to teach some C++ to a VB programmer, and had never tested it. Once we finished what we were doing yesterday, I happened to notice the project, and decided to test it out. Aside from a few small bugs, it worked! I have the (C++) source attached. This is fun!
to use: create new simpleTemplate example project, and copy DS pong files to it. Build and download. Then switch to the user display on the DS (hold Select down for 1 second). Start pong by pulling Joystick 1's trigger. to reset after winning or loosing, pull joystick 1's trigger. The ball moves in random directions from random locations.
Ideal setup: Driver station on table between 2 people, with joystick 1 on left of DS, joy 2 on right, both backwards (trigger towards front of DS)
Watchdog.Kill();
Unread 17-12-2009, 19:35
Bigcheese Bigcheese is offline
C++0x FTW!
AKA: Michael Spencer
FRC #1771
Bigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the roughBigcheese is a jewel in the rough
Re: Driverstation Pong!
This is quite a cool idea, although I did take a look at your code and found some issues.
  • There are quite a few places where there's no code formatting, making it very difficult to read.
  • The use of a try/catch statement for program flow is bad. There's no reason to do this. Simply use a goto statement if you want to reenter the loop.
Now, to defend the use of goto.
Using an exception is the exact same thing as a goto in this case, except that the try/catch implies something different is going on, and ignores all real exceptions because of the catch(...).
Yes, you could use some extra logic to handle exiting the double loop, but in the end, the simplest, and most readable solution is to have a label directly before the main while, and a goto on win.
Although the best solution would be to split the code up into separate functions such as.
  • Setup
  • WaitForStart
  • Update - Returns a value in {continue, player_1_won, player_2_won}
Then the problem wouldn't be there to begin with .
Unread 17-12-2009, 19:45
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
cool. At first glance, I thought you were talking about "apple juice" pong. I then imagined trying to play DS pong and how hard it wouold be.
Unread 17-12-2009, 19:48
Team1559is1337 Team1559is1337 is offline
None #1559
Team1559is1337 is an unknown quantity at this point
Question Re: Driverstation Pong!
where do you paste the code in the template?
Unread 17-12-2009, 20:05
None #1559
Talking Re: Driverstation Pong!
haha just kidding i just got it. nice code!
Unread 17-12-2009, 22:25
byteit101's Avatar
  • Setup
  • WaitForStart
I know, Its not ideal (I could improve it a ton), but I did not want to spend too much time designing if statements, remembered about exceptions, and used them. (I did not think of goto until just now, being a very OOPy programmer)
It is hard, I have a 30-40% hitting rate! (and about half are lost on the first hit)
Watchdog.Kill();
Unread 18-12-2009, 00:12
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Anyone dare to post a picture?
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 18-12-2009, 10:35
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Just as a random thought. (I have not dared to mess with my team's DS.) I know people have created virtual Driver Stations. Would it be possible to put this game into the Virtual DS?
Unread 18-12-2009, 15:12
byteit101's Avatar
I think it can display the User Data, so yes.
Watchdog.Kill();
Unread 18-12-2009, 20:03
that's pretty good i guess. we should start up a new game, and devote half of thursday to having a DS pong tournament. -
Unread 22-12-2009, 23:35
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
I have a stupid question...
Where are DriverStationLCD.h and DriverStationLCD.cpp coming from? I notice the official WPILib Header, but neither are in the latest version I'm aware of (3.1.1764). Should I be getting updates form somewhere besides the following site?
http://first.wpi.edu/FRC/frcupdates.html
Unread 26-12-2009, 20:12
byteit101's Avatar
The WPI think tank site: http://thinktank.wpi.edu/article/144
Watchdog.Kill();
Unread 16-01-2010, 16:31
byteit101's Avatar
I (finally!) have a video of DS Pong:
http://thecatattack.org/DriverStationPong
I don't know if it will work on the classmate, but I would think so, because it has the status updates in the corner
Watchdog.Kill();
driverstation outputs agough C/C++ 3 15-02-2009 22:25
mindstorm and pong RX7-bernie General Forum 1 01-03-2007 14:54
Shooting Ping Pong Balls Jeremiah Johnson FIRST Tech Challenge 1 01-05-2006 21:20
pong mechanik Andrew Rudolph Chit-Chat 4 13-10-2004 22:44
Revive a Classic: Pong K. Skontrianos General Forum 6 21-02-2003 16:20
