Go to Post I trust my life to a 3650 pound rolling chunk of metal every day that, if some silicon failed in just the right (wrong?) way, would splat me pretty quickly, but I have faith in engineering. On the other hand, it doesn't turn me upside down. - DonRotolo [more]
Unread 18-12-2009, 23:40
Crashdown12 Crashdown12 is offline
FRC #2016
Crashdown12 is on a distinguished road
Motor Couplings
Hello everyone I have a couple questions based off of the topic title.
1)Could i please have some information on Motor Couplings?
2) I would like to know from teams if they have used them before on their robots and how did they work out for them?
Thank you,
p.s( i hope i posted this in the right place)
Unread 18-12-2009, 23:49
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Motor Couplings
Welcome to CD, teams do use couplers and they work really well.
We used them on our bots in the past, were you looking for a specific motor coupler?
-RC
R.C.
MadTown Robotics Team 1323
Unread 18-12-2009, 23:54
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Motor Couplings
The information will likely be dependent on what motor you are looking to couple and what size shaft you are looking to couple it to.
One general thing to keep in mind with using a shaft coupler on a motor shaft is that many motors are not designed to withstand substantial side load so you must be careful with how you support the shaft if you are using a non-flexible coupling and your application may side load the motor.
As RC mentioned, many teams have used shaft couplers before. For some of the kit motors it may be helpful to adapt them to a standard size if you can't find the coupler you need to connect your motor to your desired shaft. Andymark makes adapters to turn both a CIM shaft and Globe shaft into a standard 1/2 keyed shaft.
Unread 19-12-2009, 00:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Motor Couplings
Just be sure to size them properly for the power/application, and choose the insert that is rated for the most torque (like Hytrel, instead of Buna-N).
Unread 19-12-2009, 00:31
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: Motor Couplings
Thank you,
Team662 has used motor couplings in the past. We designed a gearbox using stem pinion gears and used a coupling to connect it to a CIM. We used a flexible shaft coupling from McMaster Carr. The coupling prevented the gearbox from binding since we were not able to machine the gearbox with great precision. Check out this link from the McMaster Carr catalog:
http://www.mcmaster.com/#shaft-couplings/=4zsysp
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 20-12-2009, 09:17
FRC #2016
Re: Motor Couplings
ahhh thank you everyone! and no rc just in general, and gburlison that link helped alot thank you!
[OCCRA]: Shaft Couplings Alex Golec OCCRA 3 01-10-2005 22:30
CEC Composite Couplings from MSC Travis Covington Technical Discussion 4 27-02-2003 15:38
Drill couplings Parks General Forum 9 07-02-2003 14:44
keeping hex-shaped shafts in the couplings DaveG702 Motors 5 02-02-2003 21:03
Shaft Couplings archiver 2001 11 24-06-2002 00:46
