Go to Post PLIERS: Used to round off bolt heads. - Andy A. [more]
Unread 19-12-2009, 19:31
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Re: Historic Size of Battery
Al is much more experienced here, so anything I say takes a very distant second to anything he says.
A typical battery that size has a liquid or gel in it--something that can flow within limits--and a series of plates. Essentially, there is a chemical reaction happening. When the battery is recharged, the reaction is reversed. The reason to recharge upright would be to ensure that the plates are fully coated for maximum reverse reaction occurrence, or more speed/better depth of charge. Discharging can be done in any orientation because the reaction will concentrate in the contacted area. Charging, you don't necessarily want that.
Oh, and charging on the side has another drawback: should a seal break, the acid or other liquid can leak. Charge upright, and it's easier to clean up than if it spills out.
Oh, and for those inserts: there is a type of pink foam that is fairly dense, closed-cell, I think (not sure of exact type/brand). It cuts easily with a hotwire, great for spacing/organizing.
Thanks for the quick reply. Would you say that charging on the side shortens the life of the battery or would it simply not charge fully?
Thanks,
Jason Law
Unread 19-12-2009, 19:35
EricH EricH is online now
Thanks,
Jason Law
I defer to Al on that one, because I don't know. Here's what I know about batteries:
1) You charge them, they work, unless there's something wrong.
2) Typical lead-acid or gel-type construction internals.
3) Typical FRC batteries have a joint near the top and none visible near the bottom.
My response was based on 2) and 3) in that list.
Unread 19-12-2009, 20:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Al seems to be more concerned about the battery being able to vent properly
http://www.chiefdelphi.com/forums/sh...87&postcount=7
Unread 19-12-2009, 20:31
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Here's MK Battery's reference document for sealed lead-acid batteries: Valve-Regulated Lead-Acid (VRLA) Technical Manual. There's a lot of excellent advice in there regarding best practices.
Unread 19-12-2009, 21:07
The document that Tristan has linked to is part of the references I have used in the past. The current battery is an AGM style battery so the electrolyte is absorbed in a mat but can become fluid under certain conditions. I recommend charging upright so that any fluid that might be present doesn't cover the pressure valves. Should pressure build to the point of venting, loss of fluid is inevitable. For the students handling batteries, if we make it a normal procedure to charge upright, then should they be in position where they are charging some other types, the vents will likely be facing up. If the battery experiences some failure during charging, then all venting will take place where pit crews can see it and react ASAP. We are not sure at this point what failures may have occurred, but a small number of teams have experienced battery failures over the last two years. Some have occurred during charging and the rest appear to be physical damage. Since the battery stores a large amount of energy, physical damage can cause internal heat. The domino effect causes venting, external heat, and leaking fluid. Please instruct your students to never handle the battery by the wiring, always carry with two hands and in the event of a drop, be sure to put the battery on the side until you (or another mentor) can determine if it has internal damage. A few hour test with a load tester like the West Mountain Radio CBA II will show if one or more of the cells have a reduced capacity indicating internal damage.
Unread 19-12-2009, 23:03
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Thank you to all who responded so quickly and thoroughly in the answers. We were in the middle of finalizing the design tonight and the students wanted to understand why the batteries can not be charged sitting on its side.
Our original design would have the batteries laying on its side with the top facing out when charging in the pit. At other places where space is not a constraint, we will lay the battery cart down on the back which is on wheels so all batteries will be upright.
Now at the pit, we can either lay it on the back and put it under the table or take the batteries out of the holder that carries two batteries and set it upright without the holder in the battery cart. Either way we are going to charge it upright. It may be hard for others to understand what I am talking about. We did manage to finish the CAD model tonight. We are going to tweak it a little, put in the details where the holes are to run the charger wires, power strips etc. We will post it here for you to see at a later date. It is really cool.
Please don't call me Mr. Ed, I am not a talking horse.
Historic Match Results Greg Marra General Forum 6 02-04-2008 18:38
Pit Size Super Serb Technical Discussion 24 09-03-2008 17:43
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
size great_one411 General Forum 3 06-02-2003 09:02
Project Size stevet75 Inventor 0 13-03-2002 21:21
