Trying to get my computer back...
Sorry for the random meaningless thread. However, I have almost completely got my system back to its somewhat original state after frying my hard drive. The only problem I can't seem to fix is the ability to access all pages on the internet. There are many places that I can not go and some that will not load completely. These pages include the FIRST site, so any suggestions would be greatly appreciated.
Use different DNS servers...
Might help... |
sorry, for my uninteligence.... what is DNS?
domain name server, it's what changes a domain name to an ip address
also, you might want to try an anonymous proxy Stephen |
Ehh...I doubt it's DNS. I use the same servers...works fine for me. It's probably IE's dumb little security thing. If the webpage isn't hosted on IIS, it won't let you view it or something
But go search for security levels and put them at a minimum. |
Any other suggestions. I moved all of the security levels to low, and was still unable to access the FIRST page and others. I can't even get the team page to load completely.
#7
did you try an anonymous proxy? you can check out http://anon.free.anonymizer.com/http://www.usfirst.org. Sometimes the first site won't show up there, because the server is not responding quickly enough.
also, i can't ping www.usfirst.org, that might be causing a problem? if you really need to see a site, there's always google's cache, but that's no substitute for fixing your problem Stephen Last edited by srawls : 31-07-2002 at 21:50. |
#8
That is really cool! I have never heard of those before! Thanks!
#9
Try going to http://newton.usfirst.org ...It is odd though that the site is un-pingable. I don't know whether that would cause a problem. I think I remember you mentioning that you can't get to www.team84.org. That site is pingable, so maybe it's still some other problem...
#10
the newton.usfirst.org thing didn't work. I can get into the team page, but I can't get the icon tab things on the left side to load to navigate through the site. I have to use the links at the bottom of the page. By the way, what the heck are you doing up this early? Did I miss a dropping of the A-Bomb?
#11
With team84.org it's probably just because our web team doesn't know HTML. As for usfirst...try using netscape and see if it will load. It might just be an IE problem and not system wide.
#12
make sure u have ur browser fully updated
can u load any pages? can u ping any websites? its possible ur isp is having a problem see if anyone nearby with same service provider is having similar problems u might want to try reinstalling ie |
#13
it might be how everything is set up. try to upgrade IE. you might have an older version. try d/l IE6. dumb question and all. but what ISP do you use? (INTERNET SERVICE PROVIDER; AOL, Netzero etc....) or what would be your connection speed. I get Usfirst.org with no problems. except when they change the site and pull it from the WWW world to upgrade. Anyways try upgrading your current version of Internet Explorer to Internet Explorer 6. umm. make sure all security levels are low and make sure someone didnt go on your comp and block the site / password protect it. can't think of anything else.
Now what you can help me with is pinging a web site. how do you do that. I spent a year in cisco and was able to ping routers. never heard of pinging a web site. how do you ping a website? |
#14
open up the command prompt. type in
ping <website URL> Ex. ping usfirst.org |
#15
well...usfirst.org isn't in any DNS records (available to outsiders.) So you need to ping www.usfirst.org or newton.usfirst.org.
For some reason, there is still no ping response (even though their servers are obviously...) Not sure why pings would be blocked...Possibly to limit DOS attacks. Epix (the local...sorta...ISP) doesn't normally have problems so I doubt it's that. Normally, the DNS service (or the entire DSL service) will die for a few minutes or hours... |
| What if FIRST changed back to 2 coaches? | D.J. Fluck | General Forum | 45 | 08-01-2007 18:25 |
| My computer loves Microsoft ARGH!! HELP ME! | team222badbrad | Chit-Chat | 12 | 29-01-2005 09:17 |
| List of UTC Hartford Teams | archiver | 2001 | 3 | 24-06-2002 01:09 |
| Full list of teams & competitions | archiver | 2001 | 14 | 24-06-2002 00:52 |
| Good or bad: back wheels coming off the ground | Gui Cavalcanti | Technical Discussion | 2 | 17-03-2002 22:09 |
