Go to Post Heck, I gave several [E-Saver Lightbulbs] away as Christmas presents... - DonRotolo [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 21-12-2009, 02:32
Nameo0's Avatar
Nameo0 Nameo0 is offline
FRC #0599
Nameo0 has a spectacular aura aboutNameo0 has a spectacular aura aboutNameo0 has a spectacular aura about
Poles
How do you make a pole?
Set option for it?
"If it is not broken, then break it and then fix it." - Nameo0
Unread 21-12-2009, 02:34
Chris is me's Avatar
AKA: Pinecone
Re: Poles
Set option for it?
A pole is usually made of aluminum or steel pipe. You can get these wherever you get metal.
As for polls, there's a check box in the "Additional Options" section of the New Thread page that you can click to create said poll.
Unread 21-12-2009, 10:51
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Poles
Give birth to a child while in Poland.
Unread 21-12-2009, 11:00
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Poles
You could follow the instructions here: http://www.ehow.com/how_5008167_magnetize-iron-rod.html and you will actually end up with two poles.
Then you can check out this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=79272 and learn all kinds of stuff about magnets.
Unread 21-12-2009, 11:03
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Poles
simple - install an integrator and create a root in the denominator
but be really really careful or your will end up with a "pole in the right half plane".
and everyone knows that if you have too many poles in the right half plane then your plane will crash !
Ed Barker
Unread 21-12-2009, 11:42
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Re: Poles
Can a mod delete this thread?
Answer is here. http://www.chiefdelphi.com/forums/fa...l&titlesonly=0
Like Aquidneck Island Robotics on Facebook!
Unread 21-12-2009, 13:51
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Poles
I don't know... this thread just gave me a good laugh... that's not as available in the other thread.
FRC 766, 2015-, Mentor
Unread 21-12-2009, 14:03
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Re: Poles
I'm with you there. I think this will be a great object lesson about homonyms and polymorphism.
Note: I hope I am using the term polymorphism correctly, vis. the same word can have multiple definitions. Language techs, feel free to correct me.
Unread 21-12-2009, 14:30
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Re: Poles
[/url]
I don;t think it should. I had a good 2 or 3 minutes of laughing from this. I say we either sticky it or just not delete it.
Unread 21-12-2009, 15:09
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Poles
Perhaps we should have a poll to decide whether or not to delete this thread.
It appears there are two opposite poles regarding this thread...
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 21-12-2009, 15:19
Onward through the fog.
Re: Poles
As long as it doesn't become polemic in nature, I'm good with it.
~ Helen Keller
(1880-1968)
ebarker's Avatar
AKA: Ed Barker
Re: Poles
some math poles - here
some control theory poles - here
Dave might go for an aggregation of stardust in relation to a celestial pole. Or just the simple 'ship-star'.
or you can go for more variations of nerdy engineer jokes below
A large diplomatic delegation from Poland gets on a plane to go to a UN conference. The plane takes off normally, and everything seems fine during takeoff. Five minutes into the flight, however, the plane starts flying erratically, inverts, and crashes killing everyone onboard. The investigators analyzing the crash are dumbfounded since everything seemed to be in order with the aircraft. Eventually, they bring the problem to a contol engineer who immediately recognizes the problem: "It's simple really... you had poles in the right half of the plane!"
Q: Why do Eastern European airlines fly half empty?
A: There must be no poles in the right half-plane
A group of Polish people got on a plane to New York. For some reason, they all ended up getting seating on the left side of the aisle, and spent their trip talking about this and that. As they approached New York, the pilot announced that they were now passing over Liberty Island and that if people looked out of the right side windows they could see the Statue of Liberty. Our Polish people rushed to look, and as they did so the plane immediately plummeted and crashed into the ocean.
Why?
... too many Poles in the right half-plane.
Conjugate Poles
The Russian airline Aeroflot has a flight which goes from Moscow to Prague with a stop at Warsaw.
On one day the plane stopped at Warsaw, and a couple got on and seated themselves on the starboard side of the aircraft. On take-off, the aircraft gyrated violently and crashed. The accident investigation board concluded that the aircraft became unstable in flight because it had a pair of conjugate Poles in the right half of the plane.
Ed Barker
Unread 21-12-2009, 15:27
The CAD Guy
Re: Poles
Its post like the ones here that makes me think we need something better to do. *Goes back to CADing a wheel*
Unread 21-12-2009, 15:42
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Re: Poles
For the love of God,please post the hint. We're starting to lose control.
Unread 21-12-2009, 15:44
Re: Poles
I agree:
In the absence of a valid game hint, the natives in CD tend to get restless and resort to this sort of pun-ishment of one another.
