Thread Tools |
Rating:
Display Modes |
Re: [FTC]: TETRIX DC Motor failure analysis
One of the (many) failure modes I've seen among our local teams stems from the encoder set screw. When this screw is tightened into the soft bushing, the bushing deforms and binds on the output shaft. This binding causes a torque to be transmitted to the bushing every time the motor is rotated. At best there will be accelerated wear and the bushing will survive. At worst, we send another $30 to Pitsco. The set screw torque needed to cause this failure is quite low and I consider it to be a fault of the design rather than of the installer.
| [FTC]: Anyone new to FTC or TETRIX, READ THIS NOW! | PhilBot | FIRST Tech Challenge | 21 | 04-12-2009 17:34 |
| [FTC]: FVC (Vex) VS. FTC (Tetrix) | jbbjjbt | FIRST Tech Challenge | 79 | 24-09-2009 12:39 |
| [FTC]: VRC (VEX) AND FTC (Tetrix) | jbbjjbt | FIRST Tech Challenge | 1 | 21-09-2009 14:59 |
| [FTC]: Rookie Team Needs Help With Tetrix FTC Kit! | rjustice4 | FIRST Tech Challenge | 8 | 05-10-2008 09:44 |
| Engineering Failure Analysis | mikeleslie | Technical Discussion | 19 | 26-04-2007 23:24 |
