Re: First Robot
And put your team number on the cart, so Ed knows who to yell at (er, speak to gently) to get it into the proper parking spot.
Re: First Robot
Now I just hide them. |
Re: First Robot
It is possible the robot may be geared in such a way, and the wheels and tread have sufficient characteristics that you may not need a cart at all. If you do need a cart, I would most definitely recommend free-wheeling (human powered) over motorized. Fewer problems, easily variable speed and maneuvering, less weight.
Re: First Robot
Remember that whatever you build will need to be shipped. The combined wisdom of the above posters taken together would imply something that is light, human powered, collapses for travel (or easily fits in the robot crate) and can do double duty as a work platform and a transport for pit tools and accessories.
Re: First Robot
And make sure it fits through a normal size doorway because, trust me, you will be on the other side of that doorway at some point, late for a presentation.
I have fond memories of gentle inquiries about the size of a spanking new customized cart and was reassured they had that taken care of. Oops. Not quite. They were off by .... |
#7
Re: First Robot
As someone who had to push around a robot cart for four events last year, a few things:
1. Big wheels (pneumatic tires or rubber) make going over gaps and wiring sections on the floor much easier. 3 inches of ground clearance in the middle is perfect, less requires some work. 2. A solid handle is significantly better than a rope handle. 3. 2 fixed, 2 omni / swivel casters works well for maneuverability; four casters is a little harder to control with just one person. 4. Storage for stuff like the driver station is nice, not required but your drivers will thank you if they have a spot to throw the controller. (Some robots have room on them for this kind of stuff). 5. Some events (cough 10,000 Lakes cough) have only 32 inches of clearance for your cart. Long way forward and no wider than your robot is the best solution, or at least a way you can shrink it. |
#8
Re: First Robot
The cart Andy suggested is basically what my team has used the past few years. They are available from a ton of manufacturers, and are customizable to your own needs. Last year, we mounted a plywood deck for the robot to sit on. If you choose to do this, ensure it is strong enough to handle the robot (If it isn't, injuries will occur).
Also, you should consider your robot's center of gravity in whatever you build (we almost dumped our robot off the side of the cart a few times last year). Flashy carts are usually a waste of money, I would much rather have a flashy robot . |
#9
Re: First Robot
Chris has some great points, but here's some additional information (shown in red) that 228 has learned from about a half dozen different iterations of homemade robot carts over the past twelve seasons. We've learned all nine points the hard way at one point or another.
6. Most FRC robots are a maximum of five feet tall. Remember this when building a cart. The maximum height of a robot on top of the cart should be less than the maximum clearance height of the lowest doorway you'll encounter. 7. Your robot will change every year, but when you finally build a cart, build it once. Therefore, design in an easy to change method for holding the robot every year. One good solution is to mount blocks on pieces of 80/20 (or other similar extrusion), to slide to new positions every year. 8. If you have a giant flat surface, put a lip on it. There will be times where you'll have loose hardware from a mechanism on the cart that's still being assembled as you rush back to the field. Having lips on the cart will prevent that loose hardware from getting hopelessly lost. 9. Make your cart lightweight. Don't make it motorized, don't put on surround speakers, don't have permanently attached toolboxes, etc. Make it carry the robot, carry spare batteries, and potentially carry the operator interface. Anything else should stay in the pits. Here's a photo of the homemade (wood) cart 228 has been using since 2006, which incorporates all of the above features: ![]() with handle removed: ![]() |
#10
Re: First Robot
| Your first robot | Akash Rastogi | Robot Showcase | 23 | 20-01-2008 12:24 |
| First time wiring a robot | Andy L | Electrical | 18 | 07-04-2007 09:13 |
| Part Four: The FIRST Robot Rock Opera: The Robot Rebellion | Gabe Salas Jr. | General Forum | 0 | 14-03-2007 17:57 |
| **FIRST EMAIL**/The FIRST Robot Chicks Union | Amanda Morrison | FIRST E-Mail Blast Archive | 4 | 11-06-2005 12:56 |
