Go to Post Don't just assume that because you can modify an existing design that you are an engineer. - Daniel_LaFleur [more]
Unread 22-12-2009, 12:54
jeremy56763 jeremy56763 is offline
FRC #2883
jeremy56763 is an unknown quantity at this point
First Robot
There are a few ways to make a carrying devise from pit station to game area you can go motorized or manual. What I would like to know is what is the better way to go.
Unread 22-12-2009, 13:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: First Robot
Welcome to Chief Delphi
It's good to see that you and your teammates have found your way here to the forums.
I recommend you familiarize yourself with the search function here on the forums (spread the message to your teammates too!).
I also recommend checking out these two threads for some general info/advice on posting here on the forums:
http://www.chiefdelphi.com/forums/sh...ad.php?t=78869
http://www.chiefdelphi.com/forums/sh...ad.php?t=50532
The first one is a freebie. I believe the the device you are talking about is what is commonly referred to as a "pit cart" or "robot cart". A small number of teams have designed motorized carts, but most of us find high school students make good motors.
Here's a good thread about carts.
Many pictures of carts can be found here
Here's a motorized cart
My personal opinion is that a motorized cart is a waste of time. A motorized cart will likely be much larger than a non-motorized one. There are also significant safety concerns that must be addressed with a motorized cart (see the description of the picture I posted above). If you're looking for an offseason project I think playing around with different drivetrains or designing a demo robot is more useful than a motorized cart.
Unread 22-12-2009, 13:18
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: First Robot
I second what Vikesrock said.
In addition, remember that the pit area is 10'x10' (max, some are smaller), so make sure that you can fit it (and your robot) into the pits.
___________________
- Tennyson, Ulysses
Unread 22-12-2009, 16:15
DonRotolo's Avatar
Back to humble
FRC #0832
Re: First Robot
...and your tools, and your battery charging area, and the people who will work on the robot, and EVERYthing else you bring....that isn't in the stands cheering the team and/or scouting.
In other words: The pits are a lot smaller than you might prefer.
Many teams use their pit cart as their work table for when they work on the robot. Some have a lift mechanism, some sit on small stools as they work.
Others have a pit table that stays there all the time, and they just put the small pit cart somewhere out of the way...
Unread 22-12-2009, 16:30
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: First Robot
Welcome to Chief Delphi!
Our cart is just an off-the-shelf metal hand cart, with a hydraulic lift system. All we did was add some brackets to it to help fit the robot onto it. We choose to store our tools, batteries, etc. in the pit, but with the brackets that we have, there is a little space underneath the robot to store small things if need be.
The only part of the cart that extends outside of the bumper perimeter is the handle. When we bring our robot back to the pit, it usually just stays on the cart. Even with our gigantic pit tables, the fact that the cart is the same length and width as the robot means that we don't lose any space to the cart. The cart provides some elevation, too, which is useful when making repairs to the chassis.
If we need to take the robot off the cart for some reason, the small size makes it easy to shove into a corner of the pit.
(This picture gives a decent shot of the cart with the robot in the pit, even though half the team appears to be present also)
Oh, and make sure that the cart will fit through a standard-sized door. You might have more than few problems if it doesn't.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 22-12-2009, 17:05
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: First Robot
Working que the past few years it stuns me the amount of teams that go all out to build a fancy tricked out motorized cart (which then I have to move to the right place after they loaded their robot onto the field and they forgot all about it) but build a mediocre robot.
Build a manual cart that gets the robot and important things like batteries and tools to the field and spend more time on focusing on building a more competitive robot.
You'll be better for it in the long run.
Unread 22-12-2009, 18:16
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: First Robot
I agree with what Ed has said. Happens a little too much where a "sick" cart carries a mediocre to "what the heck does it do" robots.
However, building carts like this can be a good learning experience. Designing and building a motorized cart can be a useful tool when bringing new students onto the team as you can introduce CAD and other methods of the team into the process. But don't make it such a huge priority that other items get side tracked all for the precious cart!
Our team has a simple garden cart from the hardware store with some rails to support the robot, along with a rack in the front to hold some batteries other items of use when your out on the field, (tether, some tools, etc...). We have found that it works really well as it has large tires making it easy to traverse over uneven ground without rocking the bot too much.
Good luck with whatever you end up creating.
1058 PVC Pirates 2016 - xxxx
Unread 22-12-2009, 18:17
GaryVoshol's Avatar
Cogito ergo arbitro
Re: First Robot
And put your team number on the cart, so Ed knows who to yell at (er, speak to gently) to get it into the proper parking spot.
(since 2004)
Unread 22-12-2009, 18:58
Best Available Data
FRC #1778 (Chill Out!)
Re: First Robot
Agreed. We had a garden cart with 2x8s around edge that was spray painted red. Robot sat on the top of the 2x6s, and the area underneath was great for batteries and zip ties. We used it for five seasons, but it was definitely a little worse for wear at the end of last year.
We had a ground level cart on casters in 2004 that was a real pain. You definitely want to be able to pull it from a normal height.
Unread 22-12-2009, 19:07
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: First Robot
Ask the Florida teams, I no longer yell at them to get their carts.
Now I just hide them.
Unread 22-12-2009, 20:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: First Robot
It is possible the robot may be geared in such a way, and the wheels and tread have sufficient characteristics that you may not need a cart at all. If you do need a cart, I would most definitely recommend free-wheeling (human powered) over motorized. Fewer problems, easily variable speed and maneuvering, less weight.
Unread 23-12-2009, 07:47
Re: First Robot
Remember that whatever you build will need to be shipped. The combined wisdom of the above posters taken together would imply something that is light, human powered, collapses for travel (or easily fits in the robot crate) and can do double duty as a work platform and a transport for pit tools and accessories.
Unread 23-12-2009, 08:43
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: First Robot
This is what I suggest using as a robot cart (or something similar):
Andy B.
Unread 23-12-2009, 15:04
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
Re: First Robot
And make sure it fits through a normal size doorway because, trust me, you will be on the other side of that doorway at some point, late for a presentation.
I have fond memories of gentle inquiries about the size of a spanking new customized cart and was reassured they had that taken care of.
Oops. Not quite. They were off by ....
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 23-12-2009, 15:18
Chris is me's Avatar
AKA: Pinecone
Re: First Robot
As someone who had to push around a robot cart for four events last year, a few things:
1. Big wheels (pneumatic tires or rubber) make going over gaps and wiring sections on the floor much easier. 3 inches of ground clearance in the middle is perfect, less requires some work.
2. A solid handle is significantly better than a rope handle.
3. 2 fixed, 2 omni / swivel casters works well for maneuverability; four casters is a little harder to control with just one person.
4. Storage for stuff like the driver station is nice, not required but your drivers will thank you if they have a spot to throw the controller. (Some robots have room on them for this kind of stuff).
5. Some events (cough 10,000 Lakes cough) have only 32 inches of clearance for your cart. Long way forward and no wider than your robot is the best solution, or at least a way you can shrink it.
Your first robot Akash Rastogi Robot Showcase 23 20-01-2008 12:24
First time wiring a robot Andy L Electrical 18 07-04-2007 09:13
Part Four: The FIRST Robot Rock Opera: The Robot Rebellion Gabe Salas Jr. General Forum 0 14-03-2007 17:57
**FIRST EMAIL**/The FIRST Robot Chicks Union Amanda Morrison FIRST E-Mail Blast Archive 4 11-06-2005 12:56
