Go to Post We also indirectly benefit from those rookie teams having well-built and working drivebases. It helps raise the level of performance across the board, making for a better competitive environment. - Alan Anderson [more]
Unread 23-12-2009, 11:50
Re: 2010 Control System Getting Started
I believe that is the normal procedure for things that WPI presents, and I believe they are assisting with the SW related presentations.
Greg McKaskle
Unread 23-12-2009, 12:02
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
I just wanted to add that a lot of the results of the Beta test may not be in documentation format. How many teams that are implementing advanced traction control go out and use someone else's code? Its not cut & paste, and the differences between 2008 & 2009 coding style may not be that different.
I see the biggest benefit of the beta test being the experienced users that come out of it. Last year 1511 helped 340 Beta test, and consequently the two teams were able to get all of the Rochester area teams (20+) up and working on the system relatively quickly. Additionally 3 of the 1511 programming mentors (including a labview guy), instead of helping their own team make bigger and better and more perfect code, left the code to the kids at competition and went off and helped other teams with the control system at all 3 of our events, and traveled to a 4th that was in need of help. You can bet that is VERY likely to happen again... and honestly was much less likely to happen if they weren't part of the Beta test.
It is probably very hard to sit on the outside and see very little released to the public, but a lot of what is being done is working through tedious and annoying bugs... and what do you care about the bugs if they are going to be gone before you get there? Could there be more documentation released? Likely true, but there are some rules FIRST imposes, and there are the hours in the day limits (making something readable/useful for others is much harder than just posting up what you have done at the end of the day). 1511 had proposed a wiki-type setup for the 2008 Beta, but I think a lot of that was knocked down by FIRST trying to keep things under wraps.
I see both sides... but just try to look at what is useful coming out of this - teams that can help other teams, and maybe future Beta tests will start early enough that teams will have more time to document and get others up to speed.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 24-12-2009, 01:11
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Very well said, and YES it is difficult for me and many eager teams to sit by and watch.
Most open source models still publish a bug report to inform the other users of their development.
The fact that FIRST imposes rules makes be very uneasy.... but that's another story.
I agree that documentation is very difficult, I just wish the Beta Organizers would have encouraged more team created tutorials. The community really needs Beta teams to put proper time into creating tutorials. The Java WPI page is a good clean web page tutorial, hopefully NI takes notes and organizes their pages into one cohesive page.
Here's my biased example of tutorials. http://mentorsearch.us/node/3
"Knocked down by FIRST" sounds very discouraging for a community that should be encouraging creative ideas. I hope that you bring back your wiki idea because it sounds great !
Thanks for taking the time to talk about this important issue.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Problem Getting Victors to run with the new control system Boommaster713 Programming 11 15-02-2010 15:29
Unclaassified: Information about the 2010 control system Nadav Zingerman General Forum 35 24-11-2009 19:17
2010 Control System Beta Testers Posted Jared Russell Control System 3 04-09-2009 16:40
Bills Blog: A few more details on control system and 2010 beta test Joe Ross FRC Control System 3 13-08-2009 13:52
Getting Started Cheese Head Programming 4 09-10-2002 22:24
