Go to Post Just a modest request for folks NOT to put 3000-pixel-wide pictures inline in the forum. A link to the big picture works just as well while keeping the text readable. Thanks. - Rick TYler [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 39 votes, 5.00 average. Display Modes
Unread 24-12-2009, 11:18
TEntwistle's Avatar
TEntwistle TEntwistle is offline
AKA: Trey Entwistle
FRC #0433 (Firebirds)
TEntwistle is just really niceTEntwistle is just really niceTEntwistle is just really niceTEntwistle is just really nice
Re: 2010 Game Hint (Real)
It looks more to me like two parallel bars with stops at either end, then another set of tubes that slide over the parallel bars from one stop to the other (there is a small ledge on the pole beyond the center piece that suggests it is not really a telescoping piece)
Unread 24-12-2009, 11:21
ionave's Avatar
ionave ionave is offline
Sara Fails at Engineering
AKA: Sara
FRC #2022 (Seraphim Engineering)
ionave can only hope to improve
Send a message via AIM to ionave
Re: [BB] 2010 Game Hint #1
The mechanism in the picture looks adjustable, kind of in the same way that a hurdle can be adjusted... Maybe the robots will have the task of changing the height of the mechanism?? Who knows...
Unread 24-12-2009, 11:22
EdwardP's Avatar
EdwardP EdwardP is offline
FRC #0971 (Spartan Robotics)
Team Role: Tactician
EdwardP is a jewel in the roughEdwardP is a jewel in the roughEdwardP is a jewel in the roughEdwardP is a jewel in the rough
Originally Posted by Pausert View Post
I don't see how it would be adjustable. There are two pins on either sides that snap into other tubes, but those holes in the center are for attaching the plastic piece, not for sliding, right?
Perhaps the piece that slides over it just isn't pictured.
Unread 24-12-2009, 11:23
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
It might be a field piece, but it would have to be something attached to the robot side. Again, it just doesn't seem substantial enough (thick enough) or has proper fasteners to be a stationary (permanent) field piece.
It's shown in a horizontal position, maybe we should think of it as a vertical piece of some sort, say a tower? Maybe this is the game piece, you have to make a tower of this and use the Lexan part as some sort of shelf to hang something off of or put something on.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 24-12-2009, 11:25
TEntwistle's Avatar
AKA: Trey Entwistle
The center (outer) poles look like they slide over the longer inner poles and stop at the pins at either end. On the render, there is a little ledge on the poles that suggests that the inner pole extends the entire length of the image, and that the larger diameter pole is actually shorter than at first glance. I still don't ahve a clue as to what it does, though.
Unread 24-12-2009, 11:27
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Perhaps we should think of what someone might call this object, rather than what it's function is? A name for this piece might be some kind of play on words for a more complex and subtle game hint within this piece itself. I mean....it is the GDC we're dealing with here...
(09-12) - FRC 176 - Aces High
(13 - 14) - FRC 229 - Division By Zero
Clarkson University - 2016, Innovation and Entrepreneurship
Billfred's Avatar
Billfred Billfred is offline
You're right about the tubing diameters, but I don't think the bigger ones slide on the smaller ones out to the stops. (Where would those two fasteners slide in the absence of slots in the smaller tube?)
Unread 24-12-2009, 11:29
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
FIRST did this in 2008 with the Overpass. They weld it together, and pretty much make it a connection. So maybe this piece is solid and doesnt move, but what it's connected to....
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by brianc217 View Post
This is the first actual hint released today on Bill's Blog and the usfirst.org website.
Looks to me that it's in the wrong orientation and that it is a support for something like a 2x4 or box aluminum.
___________________
- Tennyson, Ulysses
Unread 24-12-2009, 11:34
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
I say they are lasers, and you have targets you have to shoot. The field is foggy too. There are some safety issues involved, but he I can dream right?
(Wow I'm posting this on my blackberry curve in a waffle house)
Unread 24-12-2009, 11:35
TEntwistle's Avatar
AKA: Trey Entwistle
Good point. I don't think that the connectors go all the way through, though. If they only went in to the outer tube, without penetrating the other side, you wouldn't need the slots, but you also wouldn't ahve a very strong connection either.
The center bracket has 4 small holes in it, making me think that they are designed to be attached to a very specific piece, not used as a rest or anything else. I can't think of anything that would fit that bolt pattern. Perhaps a gearbox, or some other item that we regularly use, but with a bolt pattern that is new from prior years.
Unread 24-12-2009, 11:36
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Perhaps a mod can merge the threads?
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 24-12-2009, 11:41
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Possibly a field element for dispensing game pieces? Looks to be about 8" wide, assuming that's 1/4" polycarbonate. Maybe a clue as to how big/how many game pieces we have this year?
Better yet: a tray that holds one robot's battery at the beginning of the match. In order to be functional, an alliance member must go get the battery and plug in the disabled robot.
Unread 24-12-2009, 11:45
TEntwistle's Avatar
AKA: Trey Entwistle
An additional thought - the holes in the inner side of the outer tubes looks like they are there so that the bolts holding the brackets to the poles can be tightened or a nut placed on them. It sounds crazy, but if the machine screw were placed from the inner aspect of the pole (using the access hole), if the screw hear were slightly rounded to match the internal diameter of the tube, and if the hole in the outer tube were countersunk (countersinked?), the connection could still be secure, yet allow the outer pole to slide over the inner.
I like the idea of the bracket connecting to a 2x4 or aluminum box. Perhaps it creates a field element that raises adn lowers, giving the robots a short windoe of opportunity to cross from one side of the field to the other, like the year that the robots had to cross on the tilting platform.
Unread 24-12-2009, 11:48
gallo26's Avatar
Team 79 Alumni
AKA: Bryan Gallo
It looks like there are short standoffs?
2003 Stack Attack had the same thing. If your robot was small enough, you could just go right under
[Joke] 2010 Game Hint Greg Needel Rumor Mill 67 24-12-2009 10:30
Game Hint #3 SuperJake General Forum 1 29-12-2008 14:59
Game hint #3 garyk General Forum 7 02-01-2008 16:54
Game hint?!?! Andy Grady Rumor Mill 67 30-12-2002 18:15
