Thread Tools |
Rating:
Display Modes |
Re: [BB] 2010 Game Hint #1
So I got a little bored while watching National Lampoon's Christmas vacation and drew up my version of this in CAD so we could look at it from other views. maybe this will help out deciphering this clue.
I had that very problem a few nights ago, but I didn't do anything, I just sat there and stayed bored.
I also believe its just a part of the field and I feel it may just be a place to put the actual game piece on.
-RC |
More likely just a bracket that another part of the field goes on.
after viewing 340x4xLife's post I think that they put some type of mechanism to return the balls to one spot, or recycle the balls to field. This would require high goals in order for the mechanism to work (gravity) = Idea 4.
I think this piece is designed to suspend the rails, not provide rigid support.
I highly doubt that lexan piece is for support. First, its too expensive, and second, this piece (owing to its short length and connection style) is apparently designed to slip in between two pre-existing railings, a very poor choice if your trying to make something stronger. Since it isnt for structural support, instead, it must be for suspension. I think these lexan pieces, must be used as a way to suspend rails (curved or straight?) either above a surface, or away from a wall. the rectangular 'tounge' is bolted to the wall, floor, piece, etc. and the rails extend from it suspended. And.. why isnt this is the rumour mill like it usually is? Its hard to find here Last edited by Beta Version : 24-12-2009 at 21:43. |
#7
As far as where it was in years past, I don't remember, and I'm not awake enough yet to want to go look, but my answer to your question would be that it's technically not a rumor...the hint picture is an officially released document from FIRST. Much like the "what do they mean by rule X?" discussions that will be starting in a few short weeks, what is being discussed is not a rumor, but rather an interpretation of official documentation.
#8
Finally a game hint! So excited!
![]() Can't believe i read all the 14 pages 'till now... So i'm gonna say something obvious that wasn't mentioned so far (i like the track idea, btw): It's the letter "H". |
#9
If it is a track, the "bracket" probably would attach to something to hold it up, like a pole, which would make it difficult for the robot to manipulate the balls from directly underneath. It seems more likely that it needs to be manipulated from the side, thus, it probably won't be mounted high, but more waist height. That's my two cents. |
#10
Break out the propellers! ((In all seriousness, I really like the ball track idea. As a personal opinion, I really don't want to attach something to the robot. I also want to be back on carpet. That's the extent of my serious thoughts so far; I've had a long day.)) |
#11
Well your assuming that the game is using "balls"
there have been loads of other shapes in the past For instance the balls would be knocked off a lot. But if it was an object of any shape with a hook to latch on to the rail, well then a track would make more sense. You would have teams fighting over placing certain objects in one area and others in another. Different areas with different objects would score different amounts of points. With the most hard to reach area scoring the most points. This could tie in to recycling. Just an idea, we have no idea what to expect. Its going to be a fun year |
#12
Was that banana image a prank by a mentor earlier? I just had to ask and get it out of my system...
#13
Lots of good ideas similar to what I came up with already so I don't feel the need to repeat.
I must say I am intrigued if this is a permanent field element how well it could stand up to some of the hits robots make on field elements assuming it is 1/4" lexan. Regardless of whether or not it is fake the Banana thing made me think of Have A Banana productions ending to the animation if memory serves me right. Edit: That Knex kit is in my basement and was built many times. |
#15
I have been reading this forever, and about a quarter of the way through (my hour long quest...) i came to he conclusion of a gumball machine. Teams are supposed to herd balls into a certain spot and it would be lifted upward into a funnel, much like one of those spiraling coin things, where the goal would be get as many of your colored balls through the hole in the funnel in the 2:30 time period you have. You could control the game by either scoring balls or herding the other teams, to prevent scoring. The hint is the piece of the elevator that would lift the ball. (The gumball machine isn't conventional, but rather one of the fancy ones you see in the mall) ![]() ![]() |
| [Joke] 2010 Game Hint | Greg Needel | Rumor Mill | 67 | 24-12-2009 10:30 |
| Game Hint #3 | SuperJake | General Forum | 1 | 29-12-2008 14:59 |
| Game hint #3 | garyk | General Forum | 7 | 02-01-2008 16:54 |
| Game hint?!?! | Andy Grady | Rumor Mill | 67 | 30-12-2002 18:15 |
