Re: Clamp On DC Current Meter
I'm just waiting for Al to chime in.
I have used the Fluke and really like it. It is accurate to 3kHz so trying to measure a Jaguar (at other than full throttle) will have some inaccuracy. Victors are not a problem. It is not something you will use on a regular basis so the money may be better spent on something you will use on a regular basis. You can just as easily measure current by using a volt meter across a 1 foot length of #10 wire. 0.1 volts is equal to 100 amps.
Please remember that using a clamp type ammeter, you must only put the clamp around one wire. If you put it around both, the result will be zero. |
Thanks, Al, I think I might actually remember that: .1;1;10,100
Thanks for the feedback everyone. It looks like there is no point in the extra cost.
| Detroit Regional-Blood Glucose Meter Found | Btower | Regional Competitions | 0 | 15-03-2008 19:01 |
| Clamp Race | kE7JLM | General Forum | 4 | 05-02-2008 18:43 |
| Timing Belt Clamp | shorton | Technical Discussion | 10 | 18-07-2006 22:50 |
| pic: Just kidding! That was a CNC Clamp | CD47-Bot | Extra Discussion | 2 | 14-02-2004 21:05 |
| D.C. Clamp on Ammeter | archiver | 2000 | 2 | 23-06-2002 23:27 |
