quation Holonomic Drive use Windriver C++
I use Windriver C++
Where I can fined from the Simple Template (windr River VxWorks) how to hooked up the PWM pin of the Jaguars using 4 Motors to the Digital Outputs (Digital Sidecar PWM outputs for controlling speed controllers) I am using this : Holonomic Drive 4 Motors Jaguar plugged into PWM port 1 Jaguar plugged into PWM port 2 Jaguar plugged into PWM port 3 Jaguar plugged into PWM port 4 Code: MyRobot . Holonomic Drive (stick. GetMagnitude() ; stick.GetDirectionDegrees(); degree_90_fix); //drive with arcade style (use right stick) Team 1946 |
Re: quation Holonomic Drive use Windriver C++
MyRobot.HolonomicDrive(stick.GetMagnitude(),stick. GetDirectionDegrees(),stick.GetTwist()); |
still I need from where I can fined from the Simple Template (windr River VxWorks) how to hooked up the PWM pin of the Jaguars using 4 Motors to the Digital Sidecar PWM outputs for controlling speed controllers) |
change the code by right clicking open Declartion youcane see the source code
| pic: it's a Vex Holonomic Drive! | artdutra04 | Robot Showcase | 29 | 01-11-2006 23:08 |
| Holonomic drive and ramp | robotaddict | Technical Discussion | 11 | 13-01-2006 16:57 |
| Holonomic Drive Question | Jeff Waegelin | Technical Discussion | 12 | 20-11-2005 21:23 |
| Holonomic Drive Mathmatics Discussion | robotaddict | Programming | 35 | 15-10-2005 13:29 |
| Killough platforms (A.K.A Holonomic/kiwi drive) | AK1 | Programming | 8 | 04-02-2005 21:36 |
