Go to Post FIRST for me is getting to opportunity to learn from the smartest people I know, the mentors. - faust1706 [more]
Unread 03-11-2001, 23:49
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Are Grommets considered fasteners?
Are grommets considered a "fastener" for wire?
We'd like to protect wiring running through sheet metal bulkheads from chafing, and aren't sure if we can use grommets or not.
If grommets are illegal, what would be considered a legal encasement to protect wires when they're run through bulkheads?
Thanks!
- Keith McClary, Huron High Team 830
Unread 04-11-2001, 17:26
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
When you refer to wire, do you mean electrical wiring? or guide wire?
There are a number of ways to protect the electrical wire from chafing or being cut when running through sheet metal. One way is to protect the wire itself by wrapping something around it, another way is to eliminate the sharp edge on the sheet metal.
As for grommets. I'll refer to the rule book.
Definition of a fastener: any item that is used for the sole intended purpose to join two or more items together with no other auxiliary purpose or function including Pop Rivets.
Depends on what you are trying to do. If you are joining 2 pieces and simultaneously protecting the wire running through it - you are okay. If not - then fabricate the device from thin sheet plastic (lexan), Rubber, or Aluminim which are all on the additional hardware list.
Q&A166: Bolts are fasteners. Period archiver 2001 0 24-06-2002 00:25
Are Shaft Collars fasteners? archiver 2000 1 23-06-2002 23:10
Interested in Extrusions and Fasteners? Andy Baker Technical Discussion 16 11-01-2002 19:01
fasteners gail Off-Season Events 1 14-11-2001 06:32
Are bolts to hold wheels on, and bearings, considered "fasteners"? kmcclary Off-Season Events 3 22-10-2001 23:35
