Re: Kind of off topic c programming question.
I'm not going to give you code as this is for a school assignment however why not trying looping through the numbers and comparing against the upper and lower bound.
Assign the high value and low value variables to a null value Loop through each input Check if the high value is null, if so assign the input to the high value Check if the low value is null, if so assign the input to the low value If the lower/upper bounds are not null... set the high value to the input if the input is greater than the current high value set the low value to the input if the input is lower than the current low value Take some time to think over the problem - flowcharts are always helpful. You also have a few errors in your program...slow down, look at your code. Debugging is an art. I'll give you a few tips: Watch for typos - I see an invalid comment Watch your assignments - looking at the main structure of your code where it compares the numbers, I see an incorrect assignment. Plus when posting code on the forum please use [ CODE ][ /CODE ] (without spaces). Good luck! ![]() |
PHP Code:
Also, there's another bit of a small discrepancy here that you made logically, but doesn't actually work. First, a short description of pointers...
Pointers are basically variables that don't take up any space. They don't store data, they store a memory address that points to something that does store data. So if I had an unsigned character variable Var, and it had a value of 123, I could make a pointer Pnt of the same type (unsigned char), that wouldn't take up the full 8 bits of memory space, but would instead redirect the computer to read from wherever Var is stored. There are two things you have to deal with (and they get very tricky) when working with pointers; lvalues and rvalues. lvalues (left values) are what you see on the left side of an equal sign, you're taking an actual quantity and telling the computer where to put it. The lvalue is just the address of the variable. rvalues (right values), are the actual quantity value that you're reading or putting into another variable. When working with pointers, you have to specify, because it changes whether you are reading or writing to the variable which it points to. You specify an address (lvalue) by an ampersand (&), and you specify the value (rvalue) as an asterisk (*). This brings us to scanf. You call scanf as "scanf("%c", &Var);" This is because you're writing a value to Var, and you need to know where to put it. However, when you want to display the same variable with printf, it needs to know what it's showing, not where to look, so you use the rvalue, but there's no asterisk needed, because normal (non-pointer) variables are assumed to either be an rvalue or an lvalue depending on where they show up. As a parameter to a function (something in between parentheses, no joke intended), it's assumed you want to give that function data, so the computer assumes an rvalue. However, with scanf, you really want to know where to put the data, so you have to specify with an &. You don't for any other common function. This was a long way of pointing out that you don't need an & in the printf() statement at the end. Trust me, I've made this mistake plenty of times. But the address is actually a really big number that's stored in the register, not memory, which is why you get such a weird and huge value (which is also different every time) if you try to read data from that. Otherwise, just slips and typos here and there, stuff every good programmer does every once in a while. |
If you're curious, run this code: Code:
char *fooPtr;
printf("fooPtr is %i bytes\n", sizeof(fooPtr));
Ah, I stand corrected. But the rest is correct, yes?
#7
The sad thing is after you do these silly sorting assignments you find that qsort() is built into the standard library. :/
#9
...ahhh true wisdom basicxman!
I'll add a 2 word hint: bubble sort ...a classic approach to learn. |
| Off Topic | Brett Elflord | Chit-Chat | 1 | 30-11-2007 18:05 |
| OFF TOPIC: av switch | matt111 | Electrical | 2 | 21-03-2004 15:34 |
| Threads getting off topic | Mike Soukup | CD Forum Support | 29 | 20-08-2001 04:08 |
| chat/off-topic | Brandon Martus | General Forum | 6 | 06-08-2001 10:10 |
| off topic thread | mike o'leary | Chit-Chat | 4 | 31-07-2001 22:55 |
