Go to Post FIRST will work with you if you work with them. - R.C. [more]
View Poll Results: Which OS do you perfer the most?
Mac 15 22.06%
Windows 36 52.94%
Linux 17 25.00%
Voters: 68. You may not vote on this poll
Unread 30-12-2009, 19:58
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: OS
I always had a preference for Unisys 1100 series Exec 8. Mainly because where I worked, I had the source code and could modify it as needed.
Unread 30-12-2009, 22:35
DonRotolo's Avatar
Back to humble
FRC #0832
Re: OS
Originally Posted by Phalanx View Post
Whatever happen to simple elegance?
It got to be too much work, cheaper to just throw hardware at it. But, some of it still lives at Apple.
Originally Posted by BrendanB View Post
But I really like Windows7 But I might go to a mac down the road as my cousin has had his for several years with no problems and it runs so much faster than my computer.
Good story, hope it gets fixed fast.
If you think a mac runs fast, try running DOS on a modern computer. That was when elegance wasn't an option - if you couldn't make it run in <640k RAM, it didn't run - and people still had to get things done as fast as possible, but with a 5 MHz clock speed.
For certain (non-commercial) programs, I still run DOS, because it's easier to write in and executes very fast on a 100 MHz Pentium. Same calculations in XP take longer.
Of course, my daily PC runs XP. Another prisoner of Windows. It could be worse (CP/M for instance)
Unread 30-12-2009, 23:04
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: OS
Originally Posted by squirrel View Post
It's an opinion, how can it not be valid? Because it differs from your opinion?
No, because it's an uneducated opinion. I won't voice claims about Linux (which I have used for about an hour or two), and I would certainly hope that people who have attempted to learn another OS would do the same.
A rational person wouldn't claim that a particular brand automobile is inferior to another if all they've done is test drive both. They wouldn't gain any insight into the reliability, durability, or performance of the car in various conditions.
While a first impression is a valid aspect of an educated opinion, it simply isn't sufficient to create one on it's own in the case of operating systems.
Unread 31-12-2009, 00:09
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: OS
Ok.....
I don't want to spend the money it would cost to acquire a "valid" opinion of the current Mac OS.
Unread 31-12-2009, 00:33
How Fanboys View Other Operating Systems
Unread 31-12-2009, 01:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: OS
I grew up on Apple II through Mac OS8 through elementary school. After that, it was Windows all the way.
I made it a whole two weeks of no Windows by using Ubuntu, but that was as long as I could stand it. Just took too much time to research and read how to get everything working like I wanted too. Too many things I can do with a mouse in Windows, that I had to do with a terminal window in Ubuntu. For a server, Linux is great. But for a desktop, I think it'll be quite a long time before I give it another try. Just too many things I do work only on (or better on) Windows. Every now and then when I'm feeling nostalgic, I do enjoy firing up the 8MHz Mac Classic with System 7.5 though.
Unread 31-12-2009, 09:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: OS
It's hard to form an opinion about something after only twenty minutes or less. I bet if you put a seasoned driver of automatic cars into a car with a manual, and told them to drive across town, they'd probably have an unfairly negative opinion of manual transmissions after only twenty minutes due to stalling at every red light and gear shift on hills.
After a day or two of driving gets them over the initial learning curve, their opinion will be much more realistic.
Try out Windows 7 (whether it's a friend's computer or one of the computers at Best Buy or similar stores). Download Ububtu (it's free). Try out Mac OS X (at Best Buy or the Apple Store. The Apple Store will let you use the computers there as long as you want). Use all three long enough to get over the intial learning curve, and then you'll have an accurate opinion of what works best for you (it might be more than one OS).
Gigabytes are cheap, so dual (triple?) booting is really easy nowadays. Computers are even getting fast enough to run one operating system in a virtual machine inside another operating system without any noticeable lag. I personally dual boot Windows 7 and Mac OS X, use them both daily, and wouldn't give up either.
Art Dutra IV
世上无难事,只怕有心人.
Unread 31-12-2009, 12:01
MrForbes's Avatar
AKA: Jim
Re: OS
Good point about multi boot Art....I have Windows 7 RC and Ubuntu 9.10 on my computer, but I still use XP all the time, and hardly ever use the others. I find them to be kind of lame, and they don't offer anything that I can't do with XP.
I can't put OSX on my machine because Apple doesn't want me as a customer. Says so right in their EULA.
Unread 31-12-2009, 12:26
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Re: OS
I voted for Mac, I use linux, and windows 7 is impressive.
Unread 01-01-2010, 18:11
buddyb's Avatar
buddyb buddyb is offline
FRC #1885 (ILITE)
buddyb has a spectacular aura aboutbuddyb has a spectacular aura aboutbuddyb has a spectacular aura about
Re: OS
Originally Posted by Lil' Lavery View Post
I'd have to ask anyone who doesn't have more than 20 minutes of experience with, well, anything to refrain from comparing it to products they have extensive experience with. You simply cannot adapt to a new operating system, or much of anything for that matter, in only 20 minutes, making any opinions created during that experience essentially invalid.
I know that my opinion on OS X is invalid; I felt as though my opinion was requested on all three OSes, so I put down what I felt about all three. I prefaced my opinion of OS X with the time I spent operating them in order to show that I am not, by any means, a reliable source on an "OS X vs -" debate, and that my opinion should not be counted, if the final decision is between a Mac and Linux/Windows.
I am sorry for any misunderstandings.
FRC - Team 1885 - Programmer.
Unread 02-01-2010, 13:50
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Re: OS
I wish there was an option for multiple in this poll. I use both windows, and os x in equal amounts. They both have their pros, and their cons which makes it easy to want to switch between the two.
I win! XD
Unread 03-01-2010, 16:39
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
Re: OS
I like Mac OS 10.4.1
until about a month ago, I was running Mac OS 9.2
My internet browser was "Wamcom" which was a custom build of Mozilla 2 or something like that...I had ZERO javascript support, and it was slow as a snail...Not to mention it only had a 6GB hard drive.
Now I have Safari 4 with my OS 10.4
I am still running it on my G4 quicksilver, so not much about the speed has changed.
But overall It works much better, and I upgraded to 120GB of space!
The only downside is: I still only have 512 MB of ram
Unread 11-01-2010, 16:58
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
Re: OS
I dual-boot XP and Ubuntu... Ubuntu works well for general stuff, and I use XP for CAD and gaming.
Unread 10-02-2010, 19:50
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Re: OS
Dude! use Ubuntu! it works with netbeans programming OOTB! anything you need is just an apt-get away!
Unread 10-02-2010, 22:51
spaztec's Avatar
spaztec spaztec is offline
Electrical Pit Crew
AKA: Luke
FRC #0069 (Hyper)
Team Role: Electrical
spaztec is an unknown quantity at this point
Send a message via AIM to spaztec
Re: OS
i <3 windows vista basic.
2007 Boston Regional Champion
2005 California Regional Champion
2005 Connecticut Regional Champion
2004 California Regional Champion
2004 NH Regional Regional Champion
2002 Connecticut Regional Champion
2001 Connecticut Regional Champion
