Go to Post I think another really awsome thing about FIRST can be summed up by what Dan, the Wildstang operator, said when they won nats: "I built that!" I mean, the feeling of satisfaction you get knowing that something you created can perform such unbelievable tasks is amazing. - Jupee [more]
Unread 31-12-2009, 10:34
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
pic: Chassis Idea
Unread 31-12-2009, 10:38
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: pic: Chassis Idea
Looks really good!
Nice Work!
A couple suggestions:
You could definitely get away with 1/16 inch wall tube on the inner parts of the frame to save some weight.
I'm assuming you're welding the extrusion. The other thing is that my team found is if you cut the edges of the square tube extrusion to 45 degree angles where they meet at the corners, it is more structally sound.
Are those wheels the ones you posted before?
Looks really nice, the rendering makes it look very appealing.
Unread 31-12-2009, 11:41
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
I see you have really been hitting up the CAD software recently! Awesome work!
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 31-12-2009, 12:38
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Originally Posted by Formerly Famous View Post
My thoughts would be if you make it so that you can slide the battery in through the larger holes on the front (or back), and (this is something 190 did a while back) since you have a six wheel base I suggest moving the middle wheel down from the outer wheels. This is a common base that will tilt when you move allowing for a smaller turning radius and better maneuverability. This sometimes creates to much maneuverability or to little, depending on your needs. So in order to give yourself more, or less, maneuverability you can put high friction wheels in the middle and back sections and have the last two be omni wheels. This way if your driving one way you have high maneuver ability, while driving the opposite direction will allow you to stay more stable and go forward straighter for longer amounts of time without stray.
| High Friction High Friction |
| Omni Omni |
Unread 31-12-2009, 13:06
Jared Russell's Avatar
Taking a year (mostly) off
Very nice work! This is about as simple a box frame chassis as I've seen, and it is definitely a good start towards a top notch final design.
Some things to think about when designing a chassis (obviously some of these are dependent on the game and rules):
  • How will we ensure that our chains will be properly tensioned?
  • How we will adjust the drop of the center wheel (if any)?
  • How will we mount our bumpers?
  • How will we fix X when it fails? X = wheels, sprockets, chain, gearbox, motor, speed controller, cable, frame members, welds, etc. (and how long would such a repair take?)
  • What sorts of COTS and custom made spare parts will we want to bring to competition with this drive base?
  • Do we have easy access to all bolt heads, nuts, rivets, etc., for tightening or loosening?
  • If something must go to make weight, where will we start?
  • What is the center of gravity, and how can we move it to where we want it to be?
  • How long will it take to build this once build season starts?
  • How much does it cost? Can we lower the cost somehow?
  • What are the wiring paths?
  • Where can we put the battery?
  • How will we lift this thing?
Hope this helps!
My only two questions/comments about your particular chassis are (1) if there is a ramp to climb, you will probably want to move your wheels further to the front and rear of the frame and (2) how do you plan on supporting the plywood base in the middle?
Unread 31-12-2009, 13:09
The CAD Guy
Originally Posted by sgreco View Post
Looks really good!
Nice Work!
Thank you for the weight saving tip! I have been going through all of my options. I wasn't sure if that would be safe.
We are hoping to be able to weld it. Money and knowledge may hinder that though. If we can not then we will be creating brackets out of 1/16" Aluminum and riveting it together.
The wheels are a more recent version of what I posted. A picture of them can be found here. If you go over one you can see it with the gear. (I haven't put the bolts in yet. I am about to do that when I have finished this post.)
Thank you for all of your help.
| Omni Omni |
I currently have a center drop of 1/16. I apologize for not mentioning that in my description.
Thank you for the tips on maneuverability.
Hope this helps!
Thank you for that list. I have only considered a few of them, and I will definitely be keeping all of that in mind as I perfect this design.
That is a good point, I had not thought about any ramps. The nice thing is that no design changes will need to be made; just the location of the wheels.
I am considering that at the moment. I have thought about mounting an aluminum cross beam in there. Do you have any suggestions?
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 31-12-2009, 13:13
Looks good.
I'm wondering...did you want the wheels on dead axles or live?
Unread 31-12-2009, 13:20
The CAD Guy
Originally Posted by Akash Rastogi View Post
Looks good.
(Starts editing the OP.)
The wheels are on live axles. Sorry about that.
-Rion
Start Something
Unread 31-12-2009, 13:25
Hopefully someone with more experience with 6wd can post here (I've never built a live axle system before) but what is the purpose of having a live axle system? To my understanding, the occasion when you use a live system is when the gearbox is directly driving either the center wheel (live) or a corner wheel but then the other two wheels are on dead axles.
Someone want to clarify this for me?
Unread 31-12-2009, 13:28
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
As far as I can tell, there is no particularly compelling reason for this to use live axles.
--Madison--
...down at the Ozdust!
Unread 31-12-2009, 13:30
I meant to ask the question in general too. Is there less loss of power when using live axles or something? What is the benefit, if any?
Unread 31-12-2009, 13:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Live axles are great for small sprockets/wheels, cantilevered "west coast drive" or direct driven wheels. They are also great if you use 3/8" hex, 1/2" hex, or 1/2" keyed drive shafts with the ends stepped down to 3/8" with both ends of the shaft supported. This keeps the shaft in place without any need for shaft collars, roll pins, etc. Some wheels (like Colsons) are easy to broach (or press a knurled aluminum hub into), but nearly impossible to drill a bolt pattern into.
Art Dutra IV
世上无难事,只怕有心人.
Unread 31-12-2009, 13:45
Brandon Holley's Avatar
The benefit of live axles comes from being able to use the axle as the transmission of power to the wheel. As opposed to bolting the sprocket directly to the wheel and placing bearings in the wheel, the live axle setup transmits power from the sprocket through the axle to the wheel.
Some setups may only function with a live axle setup. However given the choice between dead or live axle....I use dead axle wherever and whenever I can.
Art- If your supporting the shaft on both sides anyways (assuming a wheel your using can have a bolt pattern), then bolting each end of the shaft in place is even more simple IMO, instead of having to turn down the ends of the shafts.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 31-12-2009, 13:59
artdutra04's Avatar
Turning down the ends of shafts on a lathe takes one tool.
Drilling and tapping the ends takes three: a center drill, the drill bit, then the tap.
On a manual lathe, it's faster to turn the ends down.
Art Dutra IV
世上无难事,只怕有心人.
Unread 31-12-2009, 14:25
I will sum up my experiences with live and dead axles below.
Live axles are useful because:
  • You can drive them from any point on the shaft (e.g. West Coast Drive where there is a bearing block between the driving sprocket and the wheel).
  • The keyed/hex shaft becomes a "universal" interface for attaching wheels, bearings, sprockets, gears, brakes, encoders, etc. As long as your piece has an (ex.) 1/2" keyed bore, it will rotate along with everything else on the shaft. With a dead axle, you must attach pieces to each other directly, and not all wheel and sprocket combinations play nice in this regard.
Dead axles are useful because:
  • You are minimizing the rotational mass of the wheel assembly and therefore maximizing efficiency since the shaft itself doesn't need to spin. Unless you have a truly massive axle or bad bearings/alignment, however, we're probably not talking a huge difference.
  • In the cantilevered case, you are minimizing torsional loads on ball bearings with dead axles (since the bearings are still centered on the axis of rotation no matter what the deflection of the shaft).
  • The closer together two bearings are, the easier it is to have them stay aligned. In a dead axle setup with two bearings in a single wheel, alignment is trivial. Live axle systems that support both ends of the shaft can get out of alignment more easily.
Did I miss anything?
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
pic: Chassis Driving 2 Hanna2325 Extra Discussion 4 12-01-2009 11:13
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
