Go to Post And if you are unhappy about me using "robot", let me break your heart over what we've done to the word "cheesecake". - Foster [more]
  #31   Spotlight this post!
Unread 01-01-2010, 19:51
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: pic: Chassis Idea
Originally Posted by IndySam View Post
We don't use welding anymore. Instead we glue everything together. Never had a failure.
I would love to hear more about this.
  #32   Spotlight this post!
Unread 01-01-2010, 20:06
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We machine connectors (like 8020 quick frame) that slip inside the 1" square tube and then use Loctite Hysol to bond them together.
You can hit it with a sledge hammer and the aluminum will give way before the Hysol does.
  #33   Spotlight this post!
Unread 01-01-2010, 20:27
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
for dead axles we just use 1/2" bolts. We find them to be easy to take on and off because all they need to be attached is nut. Yes you do give up some weight and room with the added material but we feel that the simplicity makes up for it.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
  #34   Spotlight this post!
Unread 01-01-2010, 21:59
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Which Hysol formulation do you use? Epoxy, Urethane, or Polyurethane? Any other information about how you bond the aluminum frame together would be appreciated.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
  #35   Spotlight this post!
Unread 02-01-2010, 01:18
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
IndySam I am with gburlison in that I would love to hear more about this. I never thought of gluing a frame together but that may be a good alternative to welding as we have a sponsor who could get us the 8020 parts easily enough (if we can't make our own) Do you have any examples of possibly a 2x1 tube connector? If you don't I would still love to see what your 1x1's look like.
Thanks,
Trent B
About the CAD Model, interesting choice of live axles but I suppose the wheel was the deciding factor.
I found too when I did some of my own CAD models, for things like batteries, cims and gearboxes its usually easiest just to set the weight and be done with it (no messing around with materials, but always use them on stuff you plan to build yourself (aluminum frame)).
I have yet to design a frame like this, might try to CAD one quick before the kickoff.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
  #36   Spotlight this post!
Unread 02-01-2010, 01:28
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Someone should really just start a new thread about this. I'm interested as well.
-RC
R.C.
MadTown Robotics Team 1323
  #37   Spotlight this post!
Unread 02-01-2010, 01:35
College Mentor
AKA: Trent Borman
Sorry Rion for somewhat taking over your thread.
Future discussion on frame gluing
http://www.chiefdelphi.com/forums/sh...176#post892176
  #38   Spotlight this post!
Unread 02-01-2010, 01:37
This isn't that uncommon of a practice guys, and its fairly easy to do even with 1x1 and 1x2 square tubing. We've done it for the past 3 years or so; however, we machine out nylon and UHMW (and even solid aluminum) blocks to insert into the ends of the tubing. Then simply rivet, screw, or bolt the block into place. The ends of the blocks (or wherever you need) are drilled and tapped. The screw or large rivets are easily replaceable with hard epoxy, loctite, or even gorilla glue (in some areas). And there you have a snug fitting frame connector!
  #39   Spotlight this post!
Unread 02-01-2010, 04:56
R.C.'s Avatar
Here's a thread discussing live vs. dead axles.
http://www.chiefdelphi.com/forums/sh...ad.php?t=47117
-RC
R.C.
pic: Chassis Idea Rion Atkinson Extra Discussion 17 25-08-2009 13:24
pic: Chassis Driving 2 Hanna2325 Extra Discussion 4 12-01-2009 11:13
New AM C-Base Chassis vs. Old IFI KitBot Chassis? ChuckDickerson Kit & Additional Hardware 5 06-01-2009 08:36
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
