Go to Post Oh yes - and thanks for giving us kids our dreams. - DonRotolo [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 01-01-2010, 12:08
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
ofstream (standard C++ file output) not working
I was testing a logging system, where you would be able to log data to a logfile on the cRIO, and then FTP to it to see what happened. I used a modified simpleRobot, and added a streambuf* to the variable list, a ofstream, initialized to "cRIOUserLog.log", and then rdbuf to clog. but clog<<"Logging Test"<<endl; (which should also flush) does not appear to do anything. I FTP'd to the cRIO, and looked in most of the directories, but I cannot find cRIOUserLog.log. Is there something I need to do? I remember someone somewhere in some thread somewhile ago saying something about a write flag, but I was able to use IMAQ_write_png (don't think this is the actual name) to write PNG's to the cRIO.
Relevant code:
PHP Code:
class SuperSimpleRobot
streambufofsTclog;
ofstream UserLog;
public:
SuperSimpleRobot():
UserLog("cRIOUserLog.log")//...
ofsTclog=UserLog.rdbuf();
clog.rdbuf(ofTclog);
Watchdog.Kill();
Unread 01-01-2010, 12:55
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: ofstream (standard C++ file output) not working
Try calling Priv_SetWriteFileAllowed(1) in the constructor.
I've never used ofstream on the cRIO, but I've gotten C-style file I/O to work (FILE*, fopen(), fwrite(), etc.).
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 01-01-2010, 17:38
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Ditto. C-style has always run fine with me. If you know what you're doing it's not that hard to make a class similar to ofstream with c-style calls.
Unread 01-01-2010, 18:26
byteit101's Avatar
Thanks! I will try that next time I get a chance.
I know about C IO, but like C++ much better due to its simplicity, and ease of use by semi-incompetent people
Watchdog.Kill();
Unread 02-01-2010, 11:40
slavik262's Avatar
AKA: Matt Kline
What I was saying is that if you can't get ofstream to work, write your own class that copies its behavior and use the C-style I/O in the member functions.
Unread 02-01-2010, 12:37
byteit101's Avatar
if C style works, why would ofstream not work?
Watchdog.Kill();
Unread 02-01-2010, 18:01
Jared Russell's Avatar
Taking a year (mostly) off
The cRIO requires that you call Priv_SetWriteFileAllowed(1) before you can create files on the cRIO file system. You seem to be instantiating your ofstream object in the initialization list of your main robot class; in this case, the ofstream would attempt to create the specified file BEFORE you have allowed such an activity to take place (even if you call Priv_SetWriteFileAllowed(1) in your robot class's constructor - the initialization list gets executed first).
Also, ofstream has several methods that can be useful in diagnosing what has gone wrong. In particular, look at is_open(), good(), fail(), bad(), rdstate() here: http://www.cplusplus.com/reference/iostream/ofstream/
Hope this helps!
Unread 02-01-2010, 20:16
byteit101's Avatar
any files?
when we saved camera png's we did not have to call Priv_SetWriteFileAllowed(1)
Watchdog.Kill();
Unread 04-01-2010, 07:39
slavik262's Avatar
AKA: Matt Kline
It's a great question, but I've never had any issues reading/writing to the robot using C file I/O, and I've never called Priv_SetWriteFileAllowed(1). I know my suggestion is more of a workaround than a real answer, but I just thought it might help.
Unread 10-01-2010, 19:47
karatekid's Avatar
karatekid karatekid is offline
AKA: Cole
karatekid has a spectacular aura aboutkaratekid has a spectacular aura aboutkaratekid has a spectacular aura about
I got this from cprogramming.com:
#include <fstream>
#include <iostream>
using namespace std;
int main()
char str[10];
//Creates an instance of ofstream, and opens example.txt
ofstream a_file ( "example.txt" );
// Outputs to example.txt through a_file
a_file<<"This text will now be inside of example.txt";
// Close the file stream explicitly
a_file.close();
//Opens for reading the file
ifstream b_file ( "example.txt" );
//Reads one string from the file
b_file>> str;
//Should output 'this'
cout<< str <<"\n";
// b_file is closed implicitly here
This is how it is done in c++, for both input and output-this may not help, because I do not know how it will work with the robot, put it works for regular programs. Also, this only works for text files to my knowledge...
YOU JUST LOST THE GAME!
Unread 11-01-2010, 15:24
byteit101's Avatar
karatekid, I don't think you know what this thread is about. I know how to use o/i/fstream, but cannot find the file it (supposedly)creates. This format (should) work for the robot, as well as any other target supporting C++ io. And it works for binary fills also
Another thought: would I have to use /myfile instead of just myfile?
Watchdog.Kill();
Unread 11-01-2010, 20:21
karatekid's Avatar
AKA: Cole
Sorry?
Unread 13-01-2010, 11:03
slavik262's Avatar
AKA: Matt Kline
Any luck so far or is it still not working?
Also, I don't remember needing a forward slash in front of the filename when saving.
Unread 13-01-2010, 11:28
In Java, I recall I had to use a "file://" prefix on my filename (for example: "file://mylog.txt") in order to get file creation to work. Perhaps you have to do the same thing here?
Unread 13-01-2010, 16:49
byteit101's Avatar
Haven't tried to do it yet, yesterday we we only able to get LV/WR/NB installed. I think I might be able to test it Thursday, but definitely by Saturday.
Interesting Jared341, I will try this.
Watchdog.Kill();
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
Beware - transmission output shaft is not 5/8"! jskene Kit & Additional Hardware 30 13-02-2006 14:01
Drive() Not a Standard Toolset in EasyC? Chris_Elston Programming 3 08-02-2006 09:01
Beware - transmission output shaft is not 5/8"! jskene Technical Discussion 3 19-01-2006 14:24
