Go to Post So now that the Championship is over, how long 'till next kick off? ;) :p - Michelle Celio [more]
Unread 02-01-2010, 11:44
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Working with Quickframe
For the past several years we've used normal T-slot 80/20 to build a prototype/practice robot and then used 80/20 Quickframe to build the competition robot. Using normal 80/20 for the prototype lets us make changes very quickly but it's often too heavy for the final robot...it depends on the challenge. Quickframe is about half the weight.
Quick frame nylon connectors like the 9250 have always worked well for us at the corners but we've never trusted the 9240 when we need to connect a vertical member mid-span. instead we've ended up making our own aluminum L brackets. This is a tedious process.
Has anyone come up with a better (faster) way of joining a horizontal 1" square aluminum extrusion to a vertical member mid span? (Besides welding...we don't have the facilities for that and don't want to send it out since we pride ourselves on being 100% student built).
Unread 02-01-2010, 12:23
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Re: Working with Quickframe
Possibly cut it at the point you need a vertical piece and put in a 9230?
http://www.8020.net/Quick-Frame-7.asp
This could be a hassle if it is a last minute addition but otherwise if you carefully think through the order in which you are going to piece together your frame I imagine it would work fine.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 02-01-2010, 12:31
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Simply cut a piece of angle, and you have an instant L-bracket, we used these all over our 09' robot and they worked great.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 02-01-2010, 12:56
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
We didn't want to cut the frame's base members and use 9230s for fear of affecting the stiffness and strength of the frame. I suppose that would be fine higher up if the robot, though.
We have been making our own L brackets as described out of aluminum L material. It's just a pain and it's much fun when you're not dead on accurate lining up the holes.
Unread 02-01-2010, 13:31
AdamHeard's Avatar
Lead Mentor
Why not machine/cut the end of the tubing square (the piece butting up against a frame member), then put a small triangular plate on each side as a gusset, then rivet it all together. Many teams have done this well, specifically 2056 this year.
Unread 02-01-2010, 15:04
Gdeaver Gdeaver is offline
FRC #1640
The quick frame connectors do have their limitation. The first year we made our frame based on 8020 quick frame we had a similar problem. We used these connectors.
http://www.eztube.com/connectors/connectors.html
Note there are 2 versions. With a steel reinforcement and without. The problem with them is that they have 2 steps and the step near the joint is to big for quick frame. We set up about 6 students with files and mics and reduced them down. Gave the students something to do while the design was being finalized.
The steel reinforced ones are heavy but extremely strong. The composites may be good enough. The tower was supported by the bottom and top frame rails. We also have filled the voids in the quick frame connectors with epoxy putty and it did add some strength and stiffness. A very thin CA can wick in and bond a joint. 1/8 pop rivet can also help. Team 104 was limited by administration policy to hand tools and cordless drills. Quick frame was great under these restrictions.
Unread 02-01-2010, 15:15
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Any advice for a team that has not used quickframe before? Normally we use kitbot chassis, but I believe we intend to use the kitbot parts for our practice bot this year, and something new for the competition bot seems to be in order. Any tips and tricks?
Go REX!!!
Unread 02-01-2010, 16:55
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
One of the advantages of making a practice robot is that it can be a great working prototype "build #1" and then lead to an improved competition "build #2" robot. This would mean that you would want to use the same or a very similar chassis system for the two robots.
If you want to use the kitbot parts, you can buy a second kitbot to build robot #2.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 02-01-2010, 16:57
Rookie Year: 1942
Maybe you can find a place that will weld for you, but let the students watch and learn. Seeing the capability and benefits that welding brings could inspire a student to develop that capability for you.
Chris Fultz
Unread 02-01-2010, 19:36
FRC #1727 (REX)
Well if we have enough reasons to do so, we may just go with quick frame for both. It is considerably lighter, right?
Go REX!!!
Unread 02-01-2010, 20:16
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Quickframe is almost exactly half the weight of normal 80/20 1010 extrusion. It's harder to change your mind, though, so we like to use the normal 80/20 extrusion for prototypes.
Unread 02-01-2010, 20:18
College Mentor
AKA: Trent Borman
Short answer C-Base is pretty close to 8020 1x1 extrusion but much lighter than 2x1. Both are twice as heavy as a Quick frame.
.258 lb/feet
4 35" lengths, 2 28" lengths (I realize some of these would have to be shorter given the fact it would make a 40x30 frame but at those contents it would be around.
4.21lbs for the members. Throw in 4 three way corners (so you can build up) at .065 lbs a piece and 4 90 degree connectors (for the internal bars (the 2 extra 38" lengths) 9240 as an example) are .03 lbs a piece
Total 4.59 lbs with a few extra inches of quick frame aluminum that probably aren't needed.
C-Base (4 35" members at 1.25x1.13" are 1.4 lbs each + 2 28" ones about about .8 of the 1.4lbs or 1.12) total 7.84 lbs
8 corners at .24lbs each total being 1.92 lbs
Total for C-Base is 9.76 without fasteners or basically twice the weight. But the Quick frame has 1/16" walls vs C-Base 1/8" walls so it is "warranted" that the C-Base should weigh about twice as much as it has twice the aluminum thickness.
Unread 02-01-2010, 20:19
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
In reply to Chris, I'm sure we could find a place to have our frame welded, it's more of a philosphical thing with the team. The students are proud of the fact that adults never touch the robot. We don't have a lab where welding could be done, even if we developed the skills to do so.
Unread 02-01-2010, 20:36
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Gusset plates are cool.
http://picasaweb.google.com/RoboticW...31396482780482
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Working with curved surfaces Goaliexam Inventor 4 09-05-2006 14:44
Working with Gyros DavidSJohnson Programming 1 10-02-2006 00:16
Working with Lexan Phil Paspalas Technical Discussion 41 09-02-2006 16:14
[ECDU]: Working with programmers? Bcahn836 FIRST-related Organizations 5 07-03-2005 22:15
Working with Potentiometers GrahamS314 Programming 11 02-02-2003 14:34
