Re: UART Serial on cRIO
The cRIO serial port is advertised as a true RS-232, hence it already has the level shifting drivers built in. No need for MAX232.
http://decibel.ni.com/content/servle...structions.pdf |
| Reimaging the cRio Issues there are no cRio devices on the subnet | Stuart | FRC Control System | 2 | 25-02-2009 23:41 |
| cRIO configuration issue- serial connection to laptop | Torbots 1197 | FRC Control System | 5 | 28-01-2009 22:28 |
| DS tty serial and crio run speed | Mr-Shutter | FRC Control System | 5 | 21-01-2009 12:39 |
| serial | edomus | Technical Discussion | 4 | 12-02-2004 15:09 |
| Serial Shortening | Gobiner | Programming | 6 | 14-02-2003 23:48 |
