Go to Post At least try to make sure other teams are aware of you. Don't be obnoxious, but don't be a wall flower either. - Joe Johnson [more]
Unread 03-01-2010, 07:53
Re: Bumper Attachment for Rapid Removal
For the rookies here and those working with bumpers for the first time in the coming weeks...
The GDC wrote very specific rules for bumpers in both 2008 and 2009.
The rules are not open for interpretation by inspectors and the GDC believes the rules to be clear enough for compliance and understanding by all teams.
The bumper rules are intended to minimize robot damage by insuring that any robot to robot or robot to field interaction take place only through the soft parts of the bumper.
I would suggest that teams take some time this week and review the 2009 Q&A on bumpers and the bumper rules in the robot section of the 2009 manual. It will help you in the coming weeks to understand whatever changes may be introduced by the 2010 manual.
Unread 03-01-2010, 10:39
czeke czeke is offline
Tool and Die maker/Tool Designer
AKA: Carl Zechel
FRC #1091 (Oriole Assault)
czeke has a spectacular aura aboutczeke has a spectacular aura about
Smile Re: Bumper Attachment for Rapid Removal
Originally Posted by Dale View Post
I know the rules could change for the 2010 game but I'd be interested in what systems teams have used to facilitate rapid attachment and removal of bumpers.
We've always put threaded inserts inside the bumper and then bolted them onto brackets on the frame. This seems simple enough but given the cramped quarters inside the robot and subtle alignment issues it can be a tedious 30 minute job to take the bumpers on and off for weighing.
There has to be a better way? Care to share pictures or descriptions?
What our team has done, is to use 3/4" x 3/4" ( 1/8" wall ) square aluminum tubing, for the structure of the chassis, then use 1/16" aluminum U-channel
( which is 3/4" wide and 1/2" deep ) to fit onto the tubing. 2 small pieces, about 2" long are placed on the bumper board, inside, so that it is locked into place vertically, and then 2 pieces are placed to lock into the vertical structural components, to keep the bumper from moving forward and backward. We then simply drill 4 clearance holes for the nylon bolts, washers, and wingnuts ( # 10-32 ) that will hold them in place. Our bumper weight, last season was around 10 pounds, easily within specs.
Unread 03-01-2010, 10:50
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Was chatting with RC last night and we also came up with cotter pins + clevis pins as a cheap alternative to another solution. You can just buy steel clevis pins from mcmastercarr since the weight goes with the bumpers and for the most part bumpers seem to be underweight.
http://www.mcmaster.com/#clevis-pins/=57qrqv
Then just pick your style of cotter pin to secure the other end http://www.mcmaster.com/#cotter-pins/=57qrx2
Now for the expensive solution.
http://www.mcmaster.com/#aluminum-qu...e-pins/=57qs26
Quick release pins, push button yank out.
Downside is they are about 20 bucks a piece though theoretically you need just 1 per bumper right in the middle of the span if your bumpers are secure enough they shouldn't be able to bend up at the edges if they get yanked.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 03-01-2010, 13:35
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by skimoose View Post
Team 228 turned aluminum pins which were inserted into holes in the frame and held to the frame with hairpin cotter pins from McMaster. The bumpers were held onto the pins with larger hairpin cotter pins as can be seen in this photo:
The bumper brackets were 0.125" aluminum angle bored to the OD of the pins on one flange and bored for deckmate screws into the bumper plywood. This system only required the pulling of 14 cotter pins to remove the bumpers and reinstall. We averaged under 5 minutes to remove/install all the bumpers.
This is very similar to what we did for 2009, and it worked fairly well for us. The bracket may have been the AM one, but I didn't make the bumpers, so I'm not sure. However, we had some issues with getting a few of the pins in - issues with lining up the brackets with the frame exactly, and a few of the pins had to be pushed in at EXACTLY the right angle...while using a hammer. If the pins had gone in a bit more smoothly, we would have had a much easier time. I have the feeling that we'll also be modifying our system this year (game pending), but the pins are much easier than what we've used in the past, so we might just stick with them.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 03-01-2010, 18:08
College Mentor
AKA: Trent Borman
I have a feeling our team will use Pins this year if we can, getting bolts out of a cramped robot to release the bumpers is not a fun experience, the first year was awful, last year was mildly better.
Unread 03-01-2010, 18:52
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
I know that last year sense our robot was made with 80/20 And we had vertical piece of it on each corner we found bolts that fit into the slots and Just mounted the bolts into the bumper back. This allowed us to just slide the bumpers on and off.
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 04-01-2010, 02:23
kevinhorn kevinhorn is offline
FRC #3213 (Thunder Tech)
kevinhorn is just really nicekevinhorn is just really nicekevinhorn is just really nicekevinhorn is just really nice
Here is a vid from a proof of concept that we did in 2008.
Our 2009 robot used a shoulder-bolt form a lawnmower axel with the hex ground down. This proved quick and simple.
Unread 04-01-2010, 16:45
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
There's two good ways to do this that I can think of.
The first is if you have a reasonably solid frame, 1/4in thick or more, solid bar chassis (like 675 uses... a lot...). You could have matching holes in the frame and bumpers, tap the holes in the frame (or maybe weld on matching-thread nuts to the inside of the frame, assuming you're using weldable materials). Then what you do is get bolts that are just longer than the combined thickness of the frame member, nut if applicable, and bumper, and use that. Installation/removal is quick and easy, especially if you've got a socket driver on a power drill.
The second option should work for pretty much any frame. Pins. Do the same thing as above; holes in both the bumpers and frame members in matching place, or you could press or bolt in the male pin to the bumper. You can use either bolts or machined pins. Bolts will be cheaper but harder to drill a hole through. I really suggest using a drill press and a vice for this. Trying to drill something small while holding both things in your hand... bad idea.
Anywho, so what you do is once you've got your holes drilled and your pin ready, you mock it up on the chassis, and mark where to drill your hole. pull it apart, drill the hole, and put it back together with a cotter pin through the hole. For extra strength, put an appropriately sized washer in between the cotter pin and the frame member.
I can't guarantee either of those will conform to FIRST rules (depends on how you design them, honestly), but that's on you. Option #2 will be quicker to get on or off. Both are pretty quick though.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 04-01-2010, 16:52
AdamHeard's Avatar
Lead Mentor
This is more or less what 973 used to do, and now does. We have been happy with both methods with the exception of losing pins.
Unread 04-01-2010, 17:01
Otaku's Avatar
AKA: Michael Baker
[...]with the exception of losing pins.
Idea for preventing that, taken from race cars;
http://www.irvansmith.com/scart/hood..._term=HOD-2001
Something like that. Thin cable, one side with the pin, the other bolted down to the chassis. No worry of losing pins, they'll be attached to the frame via cable. Pull the pin out, take off the bumpers, and get to work. no worries about trying to find the pin afterwords.
Unread 04-01-2010, 17:06
AdamHeard's Avatar
Lead Mentor
Yup, we made lanyards after those issues.
Unread 04-01-2010, 17:10
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
We've been using a similar method since 2007. Like Adam and 973, we've had problems losing pins. We've been very happy with it and it's made many inspections much faster...
If we use bumpers this year I think we'll use a lanyard attached to the bumper to make sure we don't lose the quick release pin.
Team 1538 / The Holy Cows, 2005-2016
Drill/Mill or Lathe/Mill attachment for small shop area Coach Norm General Forum 22 16-09-2009 15:59
US Digital Encoder - video for disc removal Andy Baker Electrical 2 08-06-2009 18:32
EasyC License removal, without computer Joe G. Programming 2 05-12-2008 07:37
Bumper Attachment bLuEpHoEnIx Technical Discussion 12 18-02-2006 20:22
2x multiplier removal secnario Specialagentjim Rules/Strategy 34 04-02-2004 13:33
