Go to Post How the mentors of a team inspire their team is unimportant, as long as the team is inspired to do great things. We on 1824 believe in 'student designed, student built', but that does not mean that all teams should do as we do. For inspiration comes in many forms. - Daniel_LaFleur [more]
Unread 01-04-2010, 12:44 AM
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
The 2010 Curve Ball
In 2009 the GDC threw us a curve ball with the Regolith and rover wheels. With Kickoff is just days away, what do you predict the 2010 curve ball will be? What will be the one change that will shake things up more than any other? The one change that will nullify countless off-season prototypes? The one change that will force everyone to rethink everything?
It can be anything. Let’s see who gets to say I told you so after Kickoff!
My prediction: The good ‘ole CIMs will be a thing of the past and will be replaced with some new motor in some new legal quantity other than 4.
Unread 01-04-2010, 12:54 AM
Re: The 2010 Curve Ball
Non-flat surfaces, in a fairly large proportion.
Back in the days between 1999 and 2004, there was some form of structure to climb on every year (save 2002). These structures could easily block midfield, which many of them did, or make staying off of them and staying competitive very tricky. Since 2004, we have not really had that midfield barrier. Sure, we've had to go around triangles (2005), go up ramps at the end of the field (2006), and dodge large structures (2007), but none of them have had that same "I'm in your way, climb on/over me" feel that those older ones had.
A number of prototypes that are out there seem to assume a fairly flat floor with primarily carpet covering. But let's not forget, the GDC has been known to use as many as three different surfaces in one game, notably in 2003's ramp and 2006's ramps.
I don't think the CIMs will entirely disappear. However, let's see what happens when we can only use the BIG CIM's from the 2006-2007 era. More weight, less power, and how on earth do you get the pulley and tensioner off this darn motor without breaking it? That's going to be a sight to see... (And yes, that would be a dirty trick. The only things in the KOP's those years that weighed more than the big CIM were the compressor and the batteries.)
Unread 01-04-2010, 01:13 AM
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
My prediction....
We'll find out in 5 days....
Team 1538 / The Holy Cows, 2005-2016
Unread 01-04-2010, 01:17 AM
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Well, assuming that we're gonna be dealing with more space themed objects this year (like the remote control from Overdrive relating to controling space probes or the regolith being like the surface of the moon) I think we'll either be stuck with less traction/less mobility or we'll be using an entirely new method of control as an option (e.g. IR remote). And as for the field that would be an interesting idea for a field and I'm not gonna say the GDC will count that out, so yes morphed surfaces would make it challenging.
Also if what I've heard is true they found water on the moon so ice may be within the means of terrain and what best represents ice but the regolith from last year?
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 01-04-2010, 01:50 AM
Steve Compton Steve Compton is offline
Project Manager, Mentor
FRC #1391
Steve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to beholdSteve Compton is a splendid one to behold
Not being able to see the objects we've got to manipulate...unless we've got a camera on the manipulator and a netbook on the driver's station.
Unread 01-04-2010, 02:12 AM
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
personal I'm hoping for active field elements. put some motors out there, have the robots communicate with each other and the field to get bonuses. having the field be the 7th robot would be a cool twist IMO.
PS I very much liked this years BEST game even if the scoring was a little confusing
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 01-04-2010, 02:25 AM
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
2010: Placebo Odyssey Two
Art Dutra IV
世上无难事,只怕有心人.
Unread 01-04-2010, 03:19 AM
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
No wheels hahaha
Unread 01-04-2010, 08:13 AM
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Originally Posted by jsasaki View Post
No wheels hahaha
It's actually a great idea. Force us to use different means of transport.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 01-04-2010, 08:25 AM
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Stairs.
___________________
- Tennyson, Ulysses
Unread 01-04-2010, 08:44 AM
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Back to carpet but with different size sledding disks placed upside down under it.
Unread 01-04-2010, 08:49 AM
DUCKIE's Avatar
DUCKIE DUCKIE is offline
Duckie THE Duct Tape Enthusiast
AKA: Andrea Tribo
FRC #0365 (Miracle Workerz)
DUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant future
Send a message via AIM to DUCKIE
Assuming the "Coopertition Bonus Points" mentioned in Manual section 5 are not earned solely on chips like the safety award has been....
My guess is that the 2010 game will not be a "traditional" 3 vs. 3 game.
Perhaps a flashback to the 2001 4 vs. the clock game or the alliances can work together on a shared task like the FLL cross-table elements along with scoring points independently.
We can lick gravity, but sometimes the paperwork is overwhelming. - Werner von Braun
Unread 01-04-2010, 10:39 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I still want to know how many legs our robots will need.
Unread 01-04-2010, 11:23 AM
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Who said the robots even need to move around at all? We don't need no stinkin' drivetrains.
2010: Kinetic Sculpture Derby
Unread 01-04-2010, 11:46 AM
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I hear the GDC spent most of last summer at State Fairs watching truck and tractor pulls and mud bog competitions.
Maybe the field will be something mushy.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
voltage-torque curve kamocat Motors 11 04-10-2009 03:58 PM
torque curve LIL_C Technical Discussion 0 01-12-2008 02:02 PM
Acceleration Curve EricWilliams Programming 5 02-01-2006 04:27 PM
2X Ball Into the Ball Release MikeDubreuil Rules/Strategy 23 03-28-2004 07:31 PM
The Learning Curve Was Steep! Mike McIntyre OCCRA 0 11-12-2001 12:23 AM
