Go to Post You want to make sure you got a Mike Walker and Billfred at your event so the field runs very smoothly throughout the day. - Arefin Bari [more]
  #31   Spotlight this post!
Unread 04-01-2010, 15:30
FRC Key Volunteer Trainer
AKA: CrazyNate
Re: The 2010 Curve Ball
Originally Posted by Daniel_LaFleur View Post
Stairs.
Possibly, but people have been predicting stairs ever since Dean's wheelchair first made an appearance...
Nate Smith
nsmith@smythsoft.com
  #32   Spotlight this post!
Unread 04-01-2010, 15:57
dtengineering's Avatar
AKA: Jason Brett
Please let it be a larger playing field.
This allows room for all the mid-field obstacles from earlier four robot games that really became kind of impractical with six machines crammed on to the field.
But, sigh... I do know space is limited in some of the smaller FRC venues, so we're not likely to see that.
Perhaps, however, we might have strict limits on energy consumption... efficiency is always a good thing. Maybe each robot will be fitted with an ammeter to measure total current flow, and it will report back to the field control system how much power each robot is drawing. Alliances will then have "power consumption points" deducted from their final score.
Or maybe the combined total power consumed by all three robots in on an alliance will be monitored... so if robot one is in a pushing match and needs to pour on the juice, robots two and three need to dial back their consumption a bit. THAT would be a real challenge for drivers!
Jason
  #33   Spotlight this post!
Unread 04-01-2010, 16:07
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Smaller robots would give the same effect.
GitHub
  #34   Spotlight this post!
Unread 04-01-2010, 16:14
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Smaller robots + the non-compactness of our existing control system = major pain in the neck
The cRIO (and it's auxiliary hardware) is far too bulky to make the robots significantly smaller. We've had very wide open fields the past couple of year (2006, out side of the ramps was wide open / 2007, fairly wide open except near the rack / 2008, pretty wide open unless there was lots of traffic generated / 2009, wide open). Putting more elements on the field or creating obstacles would be kind of nice...
Team 1538 / The Holy Cows, 2005-2016
  #35   Spotlight this post!
Unread 04-01-2010, 16:17
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by Wayne TenBrink View Post
The KOP includes "1 Long box, 36.5" x 8.75" x 5.75", 29 lbs each" - sounds like the AM kit frame.
Based on the box Wayne mentioned, it seems like the legnth of the robot is unlikely to change. They could require a narrower width, but that would still leave significant space consumption issues based purely on the 38" dimension.
  #36   Spotlight this post!
Unread 04-01-2010, 16:21
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
There is not going to be a curve ball this year just a kick but game...
Every day is a new adventure!!!
  #37   Spotlight this post!
Unread 04-01-2010, 16:39
Dunno about that one, Sean. If they do like they did in 2007 with the height/weight classes (which didn't return the next year for some unknown reason), there could well be a number of smaller robots. Or they changed the size after the kit frame material was made and teams have to do the cutting down.
Sure, it's likely to be the same, but there's no reason for it to be, based on a single box dimension. (Not to mention the fact that said box could very well be a pre-built lift system that must be on the robot, not a KOP frame...)
  #38   Spotlight this post!
Unread 04-01-2010, 16:51
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
They made a similar last minute dimensional change in 2005 to adjust to our current dimensions from 30x36 (I think, it's been a while) to through a last minute change at us from what the envelope had been for the previous 4 or 5 years. This was done after the kit bot, new that year, had been designed. I have heard about this from several people involved in the original kitbot design.
That said the size of the robots is really about getting through standard doors and staying on standard shipping palates so I would not expect much change.
Thank-you 294 & 67
www.bobcatrobotics.org
  #39   Spotlight this post!
Unread 04-01-2010, 22:18
AKA: Jason Brett
Good point on not using the box size to guess at robot size... and I agree that smaller robots, while difficult to build, and more difficult for specators to watch, would allow more room on the playing field.
I do want to point out, however, a few practical maximum dimensions... the robot has to be able to fit through a doorway, and the 28" dimension works pretty well for that once bumpers are added. (Wouldn't it be cruel to increase the max width to 38" and see how many 38"x38" robots are stuck in their build rooms on ship day?)
The max weight is also limited, I understand, by American health and safety regulations that limit loads lifted by hand to 150 pounds.
So I doubt the robots will be any bigger....
Jason
  #40   Spotlight this post!
Unread 04-01-2010, 22:56
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Bigger robots will always be a problem as long as DOORS remain the same size. (There are rumors that in the early years some teams found they couldn't get their 'bots out of the workshop ...)
Personally I'd LOVE to see an obstacle to climb over again. Those were fun days.
And I've said it before, but this thread looks like a good place to repeat myself. Consider the following points:
- In 2006 the tetras were 8 lbs apiece
- The GDC is always looking for a readily available, fairly inexpensive game piece
My vote for the curve ball is ... bowling balls!
"It's NOT Just A Robot Thing!"
  #41   Spotlight this post!
Unread 04-01-2010, 23:05
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
2005
But yes, bowling balls would be cool.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
  #42   Spotlight this post!
Unread 04-01-2010, 23:10
Joining the 900 Meme Team
FRC #0079
Originally Posted by Travis Hoffman View Post
Who said the robots even need to move around at all? We don't need no stinkin' drivetrains.
2010: Kinetic Sculpture Derby
48 without a sweet drivetrain? That'll be the day.
  #43   Spotlight this post!
Unread 04-01-2010, 23:39
Horsegirrl's Avatar
Horsegirrl Horsegirrl is offline
Live everyday like it's your last
AKA: Katie Stevens
FRC #1923 (Midknight Inventors)
Horsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond reputeHorsegirrl has a reputation beyond repute
Isn't this the year of the water game? haha
Katie Stevens
1923- Team member (2006-2009) (founding member)
Master of Ceremonies
2011- Brunswick Eruption, Ramp Riot 2012- Hatboro- Horsham District, Rutgers District, New York City, Boston, Lenape District, Mt.Olive District, Monty Madness, BR^2, Ramp Riot, BE 2013- Hatboro- Horsham District, New York City, TCNJ District, Lenape District, Bridgewater Raritan District, MAR Champs, Monty Madness, MidKnight Mayhem, BE 2014- Clifton District, Lenape District, Bridgewater District, NYC Regional, MAR Champs, Monty Madness, Midknight Mayhem 2015- New York City, Lenape District, Bridgewater District, North Brunswick District, MAR champs
And yes, i do ride horses
  #44   Spotlight this post!
Unread 04-01-2010, 23:46
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
And those tetra being flung around by robots were a hazard I don't think the GDC considered until the game was actually payed. I can't imagine anything like that again.
I too would love to see some ramps or something to climb again. The floor has been flat for too long.
  #45   Spotlight this post!
Unread 05-01-2010, 00:38
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
I too would love to see the return of ramps like in 2006 or platforms like in 2004 or some other fun field obstacle but I just don’t see it happening for one simple reason: BUMPERS. Ever notice that about the time bumpers came along the field got flat? At first bumpers were optional but for the last couple of years they have been mandatory. I suspect he GDC has a fondness for bumpers for good reason. I well remember watching a 2004 Newton match when two opposing robots charged out of the gate at the beginning of autonomous and met mid field in the hardest, fastest, head on robot impact I have ever seen. I can’t remember for sure what the team numbers were but I want to say 254 was one of them. In any case, neither robot moved from the point of impact for rest of the match. Bumpers are designed to reduce the effects of such violent robot impacts. I think I read somewhere that the CRIO is rated to 50g. While 50g is nothing to sneeze at I bet those two robots on Newton back in 2004 felt much more. The recent bumper rules are the way they are for many good reasons. Heck, last year nobody was ever able to get enough traction to get going anywhere near what we have in the past but we had the most stringent bumper rules to date. As long as bumpers are deemed necessary by the GDC in anywhere near the same manner that we have become used to (bumper perimeter requirements, bumper zone, non-articulating, etc., etc. etc.) I predict that the field will remain relatively flat. Bumpers add to the safety factor and, well, we all know FIRST is all about safety and rightfully so. It is a litigious society we live in after all.
voltage-torque curve kamocat Motors 11 10-04-2009 15:58
torque curve LIL_C Technical Discussion 0 12-01-2008 14:02
Acceleration Curve EricWilliams Programming 5 01-02-2006 16:27
2X Ball Into the Ball Release MikeDubreuil Rules/Strategy 23 28-03-2004 19:31
The Learning Curve Was Steep! Mike McIntyre OCCRA 0 12-11-2001 00:23
