Go to Post I'd also like to apologize to any of the teams whose robots we may have broken. - Ginger Power [more]
Unread 04-01-2010, 18:39
Re: CAN control weirdness
Originally Posted by nathanww View Post
The documentation talks about a "voltage control mode", where the voltage is varied according to the CAN command. Does this mean that the Jaguar in this mode is just sending an analog voltage instead of a PWM wave?
No, it is still a duty cycle modulated wave form. The difference is that it will compensate to ensure a fixed voltage across the motor. Without this feature, drive strength is dependant on battery voltage and load. With voltage mode, some of this variability is compensated for by dynamically changing the duty cycle.
It is not capable of creating an analog voltage.
As I understand it, CAN will be run by daisy-chaining Jaguars together, with an additional safety verification provided in the form of a "heartbeat" PWM from the digital sidecar. However, if a point on the daisy chain fails, will the "downstream" Jaguars continue executing the last recieved command?(since there are no further commands coming through the CANbus and the heartbeat is telling it that everything is fine). Or is there some sort of additional safety system that will detect the loss of connection and shut down?
Without going into too much detail, this is not a problem. A Jaguar that is not receiving fresh CAN messages will shut down, even if the PWM heartbeat tells it to continue.
Unread 04-01-2010, 19:46
DonRotolo's Avatar
Back to humble
FRC #0832
[Nitpick]
I know what you mean, and you are correct in that respect BUT: the world really is analog, and all voltages are also analog, particularly voltages going to a motor.
[/Nitpick]
(Spoken by a true Analog EE)
Unread 04-01-2010, 20:50
Originally Posted by Don Rotolo View Post
[Nitpick]
[/Nitpick]
Sorry Don. I actually had the "aww, thats not right but they'll know what I mean" thought train go through my head, but I was already off eating dinner. Please forgive me.
Unread 04-01-2010, 21:13
DonRotolo's Avatar
Back to humble
FRC #0832
Even I admit it was nit-picking.
Off topic: Back when I was in college, Digital Electronics was "The Thing" to study. How hard could it be, one and zero? I chose Analog design, using the logic* that the world was built in Analog and so I'd never be out of work. It turned out that way, too. So, I defend Analog whenever I get the chance. Just a hobby of mine ...
Eric, just in case you didn't know, it's really a pleasure having someone so knowledgeable here in this forum, thanks for sharing your expertise with us.
Don
*No, not digital logic!
can we control the amount of air to control the speed of the cylinder? Team2339 Pneumatics 22 11-02-2009 15:33
Can I control a victor/jaguar with an RC receiver Bruceb Electrical 3 30-12-2008 10:50
Where can I find motor control in Camera.c? sjung9442 Programming 3 31-01-2006 15:49
Autonomous weirdness in user_routines_fast.c Roland Programming 6 30-03-2004 11:36
Can We Use A N64 Controller To Control The Robot pobots Electrical 25 18-04-2003 12:48
