Go to Post Rain? Prepare for Armageddon to strike when you go to St. Louis. Two years in St. Louis. Two years of Tornado scares. Tis the season. - Koko Ed [more]
Unread 03-11-2009, 19:40
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Communicating with a laptop
Okay, so, now that all of team 1058's competitons are over, we are playing around with some coding. We plan on making our robot driven via a wireless 360 controller. Currently we have it working via a Laptop, passeing data to an arduino, then to the digital/analog IO on teh DS, however, this is inefficient, and slow. Is ther a way i can directly communicate from a laptop to the DS (or maybe even to the robot with wifi???".
I'm not 100% sure, but cant i send an array of bytes through a digital port from a serial port on the laptop (wit the proper hard ware of course)?? How do I do that?
Can i use teh second ethernet port, and send data that way?
Unread 04-11-2009, 06:46
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Communicating with a laptop
To have the laptop control the robot directly, take a look at [Dave Flowerday]'s virtual driver station software.
For information on sending serial data through the DS's digital inputs, check out this prior discussion.
--Ryan
FRC 766, 2015-, Mentor
Unread 30-11-2009, 07:54
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Also keep in mind that there is a full network stack in vxWorks, so you can communicate over the network too using traditional socket programming. We put a lightweight webserver on our bot so we can control it by accessing a webpage.
Unread 06-12-2009, 00:27
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
So using the socket programming in vxWorks you can set up a socket on your laptop and a socket on your laptop and communicate with the two?
What about the user data packet already sent back to the robot from the DS? Is there any way to access that?
Unread 06-12-2009, 00:33
virtuald's Avatar
RobotPy Guy
Yes. If you've done sockets before, this is probably the most flexible way to go. Probably not legal to use during a competition though.
Yes, look into the dashboard class. The official dashboard stuff is done in labview, but I know I saw some threads about someone who made one in C# or C++ or something...
Unread 06-12-2009, 00:41
slavik262's Avatar
AKA: Matt Kline
I'm not a huge fan of LabVIEW... I'm kind of a C++ guy. Would sending data back using the DS be legal in competition?
Unread 06-12-2009, 09:25
It was legal last year. That's exactly what the Dashboard packets are for.
Unread 06-12-2009, 09:29
slavik262's Avatar
AKA: Matt Kline
Sorry, I misspoke. How could a laptop get access to the DS packets going back to the robot so that the laptop can communicate to the robot without using LabVIEW?
Unread 06-12-2009, 12:55
I misunderstood the question anyway. Sending arbitrary data to the robot is not supported by the Dashboard protocol; it's one-way UDP from the robot only.
Unread 06-12-2009, 14:03
slavik262's Avatar
AKA: Matt Kline
Thanks for clearing up the confusion. And using sockets during competition would probably be illegal. That's unfortunate... I was hoping for two-way communication. Oh well... at least we can have it for debugging.
Unread 06-12-2009, 19:36
Last year, I did not find any rule that made it illegal to use your own socket interface to communicate from the dashboard to the robot. It would be very easy for FIRST to firewall off unnecessary ports (I don't know if they did or not). There was a few questions on the Q/A about what ports were open, but there was never an adequate answer.
Unread 11-12-2009, 10:18
slavik262's Avatar
AKA: Matt Kline
So we shouldn't completely rule it out then, but try to get a better answer to whether FIRST will allow us to use sockets?
Also, if it wouldn't be too inconvenient, would you kindly give me a link to the networking API for VxWorks? I'm browsing around in the library documentation but dont' know where to look.
EDIT: Is this what I'm looking for?
http://www.slac.stanford.edu/exp/gla...ckLib.html#top
Unread 12-12-2009, 08:41
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
yes, that is the docs.
see http://www.chiefdelphi.com/forums/sh...ad.php?t=72874 and download the link on the 4th post for a small library using sockLib
the man documentation is also in C:\WindRiver\vxworks-6.3\man\cat1\sockLib.1
and C:\WindRiver\vxworks-6.3\man\cat2\functionname.2
Watchdog.Kill();
Unread 05-01-2010, 11:00
slavik262's Avatar
AKA: Matt Kline
Sorry to bump this, but where is the Q & A where we can ask about using sockets? Will it be on the FRC website once competitions start up?
Unread 05-01-2010, 15:06
byteit101's Avatar
FIRST forums for official answers
Watchdog.Kill();
Inventor Install with Vista64 Laptop??? Ziaholic Inventor 9 11-01-2009 23:52
Control a vex with a laptop? antiNeo Programming 17 24-06-2008 12:51
Help: IFI loader not communicating with control unit red_alert_13 Programming 9 20-01-2006 17:30
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
