Go to Post Continuous improvement isn't rocket science. - JVN [more]
Unread 05-01-2010, 21:41
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
Re: Rover wheels on carpet?
Interestingly enough when our team practiced on a mostly carpet surface (with some regolith) we didn't have any static problems either. No problems at regional either. However, at Atlanta we had a weird problem where the cRIO would spontaneously reset itself. Someone suggested it may be static, so we put electrical tape across all of the open ports (serial, Ethernet, and exposed module slots). It worked flawlessly after that.
If you truly have a static problem, then I would suggest taping any exposed conductors that are near the wheels, especially if they are advanced electronic components (e.g. Jaguars, Digital Sidecar, Gyro, cRIO).
Mounting Sprockets to the Rover Wheels Ice Berg Technical Discussion 22 20-01-2009 00:38
Encoders and Rover Wheels EncodersRUS Programming 14 12-01-2009 12:34
Rover Wheels neoshaakti Kit & Additional Hardware 11 09-01-2009 14:34
Cost of Rover Wheels Boco Gear General Forum 3 08-01-2009 16:10
