Go to Post Mind you, the Q&A forum and competition officials DO take precedence over my opinion. - dtengineering [more]
Unread 05-01-2010, 21:45
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Rover wheels on carpet?
In your post it says wood and carpet. Which is the surface that you will be driving on? The team that I was helping out last year drove their robot on a wood surface, it left a lot of marks. I do not recommend it. If your surface is carpet, go out enjoy and see what the robot does, it should be a fun time.
#4. Find time to change the wheels? (also includes removing and mounting sprockets and tensioning chain)(then prevents us from playing Lunacy in the future)
Is there an upcoming Lunacy off-season competition?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 05-01-2010, 22:16
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
the stage has a wooden frame with carpet on top.
And not that I know of, I was just saying...
Eric: the reason I did not mention bringing regolith is we ony have 2 sheets, since we will be letting other people drive the robot it would be nearly pointless(imho) to try and tell a person who has never driven the robot before to try and stay on them. we dont have any tread laying around either.
I'll test the robot on some carpet on Thursday, and if we have a problem, I'll probably go with the duct-tape...
we were just assuming there would be a problem.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 06-01-2010, 03:10
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Shouldn't take much longer than ~45mins tops, and it's perfectly reversible.
Though I just suggest protecting all open connections. It's a bad idea to have things exposed regardless of static risk. Attack everything with a roll of electrical tape; insulate mounting screws and such. It's impossible for static electricity to effect something it can't get to.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 06-01-2010, 08:31
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Rover wheels on carpet?
You might also try fastening a traction material layer over the rover wheels to prevent slippage. Your robot will likely drive differently. Are there any other FIRST teams in the area that you could borrow additional Regolith from to increase your driving surface area?
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 06-01-2010, 09:34
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
We had a lo of problems with static, we used a drag wire and it worked perfectly. It will most likely not leave any more marks than the wheels themselves.
Unread 06-01-2010, 10:59
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
Put some fabric softener in a spray bottle and spray it all over the carpet. We do this frequently in our office and at trade shows where enough static would build up from a person walking to cause a laptop to reboot when they touched it.
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Unread 06-01-2010, 11:06
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Way, way back (almost a year ago, now!) we had our initial rolling chassis outfitted for testing with the rover wheels. The programming team was out in the carpeted hallway doing a little driving to make sure everything was working fine... As they drove down and back, you could literally see the static electric discharges traveling between the robot and the wall (where, i assume, they used those hollow metal studs instead of 2x4's - at least, that's what they used when they renovated our build space the past few months).
The above results make sense... Think about shuffling your feet over carpet during the winter, then touching a door knob - you get a shock. Do the same thing on a hard wood floor, you don't (or at least, not as much). Carpet is GREAT for creating static electricity, which is a huge drawback here.
I would suggest changing the wheels - it really doesn't take too long, and would be a lot safer than any other option.
Unread 06-01-2010, 16:11
gorrilla's Avatar
AKA: adam spears
I'll do that too.
Adam Spears
Mounting Sprockets to the Rover Wheels Ice Berg Technical Discussion 22 20-01-2009 00:38
Encoders and Rover Wheels EncodersRUS Programming 14 12-01-2009 12:34
Rover Wheels neoshaakti Kit & Additional Hardware 11 09-01-2009 14:34
Cost of Rover Wheels Boco Gear General Forum 3 08-01-2009 16:10
