Go to Post FRC is about giving students the best experience possible. - MikeE [more]
Unread 03-08-2002, 12:20
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Serial Cable
Not trying to throw off the other thread but, does anyone know the maximum distance you can make a serial cable that will work?
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 03-08-2002, 12:38
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
Hmmmm, I'm not sure. I know USB is 50ft. If you can tell me what you are going to do with it, I might be able to help
Unread 03-08-2002, 12:45
Git 'em!
For plugging a computer into a basic stamp 2 board of education
Robot in 3 Days
Unread 03-08-2002, 12:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
They are not too common in many stores but they do make 50ft cables so you could go at least that long before it doesn't work. I'm guessing that it is not quite the same if you plug a bunch together because of increased # of connections and resistance. Hope this helps.
Unread 03-08-2002, 12:49
MattK's Avatar
Tap it.
I agree with Sanddrag
Unread 03-08-2002, 13:08
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
I think the maximum length for an RS232 connection is 100 feet... let me double check that...
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 03-08-2002, 13:53
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
the maxiumum recommended length from InovationFIRST is 25 ft. beyond that, if the robot goes crazy, it's not their problem. i've been content with using a 6 ft cable, for many uses. from diving the robot down the street (we were too lazy to carry it, and we had one battery that still had a somewhat usable charge ) to testing out the different systems on the bot. sure, i'd go for a longer one, but is it needed, not really. also, when you do connect cables together, the maximum length will go down, a lot.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 03-08-2002, 16:12
330 has used a 50 foot tether/programming cable since '98
How long of a serial cable you can use is mostly limited by the quality of the rs232 drivers and receivers, and even more heavily on the data rate. Because of this, it's hard to find "the answer" for the maximum length of a serial cable.
Unread 03-08-2002, 22:24
Git 'em!
So is there a way to boost a serial signal??
Robot in 3 Days
Unread 15-08-2002, 22:09
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
i think that there might be, but i dought you could make it, and to buy it you need lots of $$$$$.
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
LEGO IR tower cable Jeff Rodriguez Chit-Chat 1 31-10-2003 16:23
Competition port cable Ken Leung Electrical 2 17-09-2003 08:12
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
25 FT SERIAL CABLES (controller tether) sanddrag General Forum 10 06-09-2002 20:29
