Go to Post We need to celebrate great things because good enough isn't inspiring. - Andrew Schreiber [more]
Unread 03-08-2002, 16:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I've actually never heard of the method you're describing
There is a risk factor of having a drivetrain without the shock loading system but as long as it is built robustly, it should be okay. We have never had problems with sprockets and chains. I don't thinks you could really break a chain link or sprocket tooth wery easily. However, we ahve had problems in a couple other areas. We mounted our drill motors with 6-32 threaded rod and connected them with the SPI drive couplers. Under extreme abuse the couplers came loose and the threaded rod flexed. However, this was the least of our concerns. We were using 32P Brass gears from SPI and those stripped and broke like crazy. As long as you use Steel 20P gears from Boston Gear or sprockets and chains, you should be alright. Also, keep the chains straight and tight and maybe a little slippage with the tires isn't such a bad thing. It will be easier to turn and won't be suck a shock when going instantly from full speed to stopped such as when runing into something. Hope this helps.
most important phase? Jeremy L Rules/Strategy 3 15-01-2003 15:21
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
How important is a machine shop? archiver 2001 13 24-06-2002 04:14
most important charecteristic of successful teams archiver 2001 11 23-06-2002 22:12
Anyway to make it easier for readers to search for important info's? Ken Leung CD Forum Support 10 30-06-2001 14:47
