Go to Post The toughest part about that Chairman's Award was the fact that someone was cutting onions in the stands near 558/on the field while it was being read out. At least that was the excuse I'm going to use ;) - esquared [more]
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 06-01-2010, 14:01
GaryVoshol's Avatar
Cogito ergo arbitro
Re: 2010 Game Hint #2
Originally Posted by JimWright949 View Post
I think this is a gate in the middle of the field, the yellow is to indicate where the yellow alliance is to enter the field. 3x3x3 game, without wheels is my guess.
-Jim
But how do you navigate there from the homepage, or from the FRC page as Bill's blog noted?
(since 2004)
  #62   Spotlight this post!
Unread 06-01-2010, 14:04
DUCKIE's Avatar
DUCKIE DUCKIE is offline
Duckie THE Duct Tape Enthusiast
AKA: Andrea Tribo
FRC #0365 (Miracle Workerz)
DUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant futureDUCKIE has a brilliant future
Send a message via AIM to DUCKIE
The Yellow squares in the drawing are to prevent/identify tripping hazards around the fields. All fields had them... maybe not all were yellow... but they were there.
<See Here>
We can lick gravity, but sometimes the paperwork is overwhelming. - Werner von Braun
  #63   Spotlight this post!
Unread 06-01-2010, 14:05
dustinjeremy2k's Avatar
dustinjeremy2k dustinjeremy2k is offline
FRC #1153 (RoboRebels)
dustinjeremy2k is on a distinguished road
Originally Posted by DUCKY View Post
Looks like the typical gate design.
I agree. I can't make out any significant change.
I cannot tell if gate is larger than usual.... but I would not complain. A larger gate would make moving robots and people on and off field safer.
Again, I'm with you there. One thing I'd like to point out is there has ALWAYS been two complete sections between the corner of the playing field and the gate. Check your old photos. We cannot see two complete sections on either side, so... we can't really tell where this is on the field! I don't know why everyone is assuming the gate could only fit in the center?
It is missing the Plexiglas/Lexan sections that have protected the sides of the field for the last 3 or 4 years though.
This was my second observation, but again, I think it's a mistake (like the yellow trip hazard plates that should be bent instead of flat). I can't imagine that FIRST would run the risk of having a robot catch one of the uprights and damage the field.... Small beans.
The hint is simply CARPET... yahoo! I guess I didn't waste my summer on another pointless drive concept!
  #64   Spotlight this post!
Unread 06-01-2010, 14:26
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
See the second photo on post #49 by Cyberphill. The "yellow" plate was only on one side of the gate, now there is a "yellow" plate on both sides in the clue. The photograph shows four "yellow" plates between the gates. The gates have simply been moved one section in towards the middle and they now have the "yellow" plates on both sides.
  #65   Spotlight this post!
Unread 06-01-2010, 14:31
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
How'd you find the URL to the hint already? I don't see it on the FRC page above Hint 1... Or was it just some lucky content id number guessing?
EDIT: Looks like it's up on the site now...
  #66   Spotlight this post!
Unread 06-01-2010, 14:46
AKA: Chris Leung
Originally Posted by rsisk View Post
If the gate is in the center of the field, does that mean we go from four gates to two? How is that going to affect traffic flow? Especially when the scoring table and a lot of the electronics run to the middle of the field?
So maybe they are not in the center, but just offset more from the driver stations, maybe at the next side rail segment (I think there are 7 per side)
Maybe the field is a different shape? Triangle? Hexagon? With starting positions or maybe some kind of goal in each corner? You never know...
And maybe it's just the perspective, but the carpet/regolith/floor(maybe rubberized or *high* friction floors, or maybe even a padded floor??) ends right behind the view of the pipe guardrail. Just a random observation.
  #67   Spotlight this post!
Unread 06-01-2010, 14:48
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Still can't find hint directly from home site. Maybe all is not what it appears.
  #68   Spotlight this post!
Unread 06-01-2010, 14:52
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Same here. I noted my concerns back on page 2 of this thread. Somehow, between posts #8 and #9, somebody spontaneously found Clue-2. Puzzling.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
  #69   Spotlight this post!
Unread 06-01-2010, 14:54
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
And maybe it's just the perspective, but the carpet/regolith/floor(maybe rubberized or *high* friction floors, anyone?) ends right behind the view of the pipe guardrail. Just a random observation.
Note to everyone: the picture is rendered as if one was standing on the field and looking out. The yellow is on the outside of the field.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
  #70   Spotlight this post!
Unread 06-01-2010, 15:04
Ziaholic's Avatar
Elec/SW Mentor
AKA: Marc
Originally Posted by Ted Weisse View Post
This link was already posted on page 1 of this thread ... not sure what you're trying to accomplish here, or with the new "real" thread that you created.
(but at least now I can see a link to Hint #2 on the main FRC page ... so that question is resolved ...)
  #71   Spotlight this post!
Unread 06-01-2010, 15:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
So...the floor looks like carpet. Dave's game hint is "What is may not be what it [seems]". So it's not really carpet. It is flat though. Or is it?
Or perhaps the hint refers to how hard it can be for a robot to open the gate. Field reset volunteers know what I'm talking about. It's a simple latch ... except ... Or perhaps it refers to the hump underneath the gate, meaning the field isn't flat.
See, it's so ambiguous I simply must be correct.
GitHub
  #72   Spotlight this post!
Unread 06-01-2010, 15:06
AKA: Chris Leung
Yeah I realized that. But the floor texture inside the field doesn't look like carpet from previous years, which is why I made the comment about rubberized/high traction flooring. Maybe it's the 'opposite' of regolith? Or maybe they just used a different program or texture to render it?
  #73   Spotlight this post!
Unread 06-01-2010, 15:14
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
[quote=Ziaholic;893537]This link was already posted on page 1 of this thread ... not sure what you're trying to accomplish here, or with the new "real" thread that you created.
Sorry bad post.
Mod has closed it and best to delete it if they would please.
Sorry.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
  #74   Spotlight this post!
Unread 06-01-2010, 15:17
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
To make this clearer, look at this picture:
http://usfirst.org/uploadedFiles/FE-00032.pdf
Assuming the basic shape and construction of the field is the same, including the yellow plates (a big assumption!), there could very easily be four gates, each between a pair of the yellow plates. Aside from that, the gates appear to look the same way they always have. Of course, they might just be pulling a fast one on us...
Does anyone else remember when TBA signatures actually worked?
  #75   Spotlight this post!
Unread 06-01-2010, 15:25
lingomaniac88 lingomaniac88 is offline
FRC #1554
lingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud oflingomaniac88 has much to be proud of
The first thing I thought of when I saw this was garbage cans with the "step to open" mechanism:
Perhaps it's something that human players can step on to control a certain aspect of the field, such as a chute to release game pieces or the position of a scoring location.
"It is common sense to take a method and try it. If it fails, admit it frankly and try another. But above all, try something."
-- Franklin Delano Roosevelt.
[BB] 2010 Game Hint #1 ATannahill Rumor Mill 577 28-03-2010 01:04
[Joke] 2010 Game Hint Greg Needel Rumor Mill 67 24-12-2009 10:30
Game Hint #1 Ice Berg Rumor Mill 898 03-12-2009 20:35
Game Hint #3 SuperJake General Forum 1 29-12-2008 14:59
Game hint #3 garyk General Forum 7 02-01-2008 16:54
