Go to Post Wait...engineers have personalities? - Mark McLeod [more]
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
  #91   Spotlight this post!
Unread 06-01-2010, 16:05
JKWarrior's Avatar
JKWarrior JKWarrior is offline
FRC #0573
JKWarrior is an unknown quantity at this point
Re: 2010 Game Hint #2
Originally Posted by IKE View Post
My thoughts exactly. Coupled with a gate, maybe a HP from each team can enter the field, and pressure plates kill the robots...
right BATTLE BOTS! but seriously pressure plates could work but i see no wires, but this is a low quality CAD program
  #92   Spotlight this post!
Unread 06-01-2010, 16:06
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
If you zoom in the yellow things are conected to a special square tubing while they other sides are cirular, they are defently part of the game or somthing.
Every day is a new adventure!!!
  #93   Spotlight this post!
Unread 06-01-2010, 16:11
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Originally Posted by IndySam View Post
the yellow things are there to stop people from tripping over the supports. They have always been there.
That's all that need be said.
  #94   Spotlight this post!
Unread 06-01-2010, 16:13
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Nope. The round tubes go from top to bottom of the rail. The square one goes to a plate on the floor at an angle from the top rail (to form a triangle for support) to keep the rail from falling outwards when hit by a bot. Nice try, though. Thinking outside the box.
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
  #95   Spotlight this post!
Unread 06-01-2010, 16:18
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I think the GDC is sending us a message -- "HI" -- if you tilt them both the same amount it spells out that message ^^
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
  #96   Spotlight this post!
Unread 06-01-2010, 16:19
JKWarrior's Avatar
FRC #0573
Originally Posted by bduddy View Post
To make this clearer, look at this picture:
http://usfirst.org/uploadedFiles/FE-00032.pdf
Assuming the basic shape and construction of the field is the same, including the yellow plates (a big assumption!), there could very easily be four gates, each between a pair of the yellow plates. Aside from that, the gates appear to look the same way they always have. Of course, they might just be pulling a fast one on us...
maybe the gate has been moved to the center of the field (replaceing the human player positions in your link
  #97   Spotlight this post!
Unread 06-01-2010, 16:26
rulesall2 rulesall2 is offline
Team Role: Tactician
rulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud of
no, if you look at the link above ^^ from last year, it was connected the same way. although as this becomes picked apart, more details will come out like this one.
As stated by Bob Steele said earlier, it could just be a change in the design of the corners that requires the change in the number of plates. Also, due to the zoom, it is impossible to locate the access point. I am speculating a third gate though...
A side note, use spell check.
EDIT: Last year had the ball corral areas for empty cells, that could have been the reason two yellow plates were not needed, as the bar crossing the corner created enough support.
  #98   Spotlight this post!
Unread 06-01-2010, 16:27
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Am I the only person happy to be back on carpet... That's all I needed to see.
Is now an engineer thanks to FIRST.
  #99   Spotlight this post!
Unread 06-01-2010, 16:39
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The yellow plates are on the outside of the field, and are there to keep people from tripping. They are polyethylene (plastic) panels. I'm guessing the reason they are flat in the second game hint is because they were too lazy to actually model the curve. They have hook Velcro on the bottom, and are stuck to the carpet just by putting pressure down on them, as they bend quite easily.
2009: (yellow)
2008: (green with caution tape)
2007: (yellow)
2006: (yellow)
Originally Posted by Karibou View Post
Maybe they just removed that to make the objects in this image more visible? I don't know why they would decide to be THAT nice, though.
This is only my 3rd year in FRC. I've always known the field with the plastic siding. Was that nonexistent in previous years?
2005 was the first year of using polycarbonate side panels along the entire field. Before that, the sides of the field were just the aluminum tubing with a single wire strung in between; the only places that had polycarbonate panels were at the gates. I know this first hand, because our 2004 robot got stuck on these wires a lot.
Edit: I just noticed, that in the photo from 2004 linked to above, instead of the polyethylene plastic panels, there's diamond plate protecting the field supports. So the move to the yellow plastic was probably just to save costs.
Art Dutra IV
世上无难事,只怕有心人.
  #100   Spotlight this post!
FRC1612's Avatar
FRC1612 FRC1612 is offline
FRC #1612 (Robo-Sharks)
FRC1612 is an unknown quantity at this point
Originally Posted by DUCKY View Post
The Yellow squares in the drawing are to prevent/identify tripping hazards around the fields. All fields had them... maybe not all were yellow... but they were there.
<See Here>
OKAY... So the yellow things where there! thats not new. The gates are bigger as some have posted... SEE HERE
And the gate is in the middle of the field see post above^^^ top picture...
The only thing left is to verify that it is indeed carpet in the picture. And if it is i am guessing that they are just giving us a hint that it is back to carpet.
So is it carpet or not?!?!
~Robo-Sharks
  #101   Spotlight this post!
Unread 06-01-2010, 16:40
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
In 8 years of mentoring one thing I have learned is this:
Students can learn to drive on whatever they give us.
Ramps, carpet, grating, HDPE, lexan, diamond plate, regolith, other robots the driver station wall, referees, stairs, Dean, the bar, goals, the scorer's table, you name it, I've watched robots somehow manage to drive on it at events over the last few years.
As far as I'm concerned the surface we play on is is of minor consequence and easily overcome compared to what the game object is.
Thank-you 294 & 67
www.bobcatrobotics.org
  #102   Spotlight this post!
Unread 06-01-2010, 16:48
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
It doesn't matter if it is carpet or not. Last year there was still carpet under the Regolith. Just because it isn't in the picture doesn't mean it isn't there. They can always put Regolith or something else on top of the carpet. For all that picture shows it could just be concrete with the carpet or whatever playing surface left out.
  #103   Spotlight this post!
Unread 06-01-2010, 16:54
FRC1612's Avatar
Looking at the game hint ... they probably rotated the image at an angle to show as much carpet(flooring) as possible without showing the game elements or anything else on the field.
Really measuring to the amount of carpet left outside the field im gonna have to say this is at least half the field in the clue... So unless the corners of the field are a different material. Im gonna have to say the whole field is carpet(or whatever flooring is in the picture).
Something new i noticed is that the ramp unlike past years extends into the field when up... Not sure if this was just a mistake on the computer or not? it should be back a little so the bend is outside the field.
~Robo-Sharks
  #104   Spotlight this post!
Unread 06-01-2010, 17:09
Kimmeh's Avatar
Kimmeh Kimmeh is offline
Student at Kettering University
AKA: Kimberly
FRC #0068 (Truck Town Thunder)
Kimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond repute
Send a message via Yahoo to Kimmeh
We agreed that this year there won't be any robots this year. It will be all on the human player! We'll spend the next six weeks learning how to do the Robot dance.
[2014 - Present] 68 Truck Town Thunder| Mentor |2014 - Great Lakes Bay Winner, Curie Quarterfinalists, District Chairman's Award, MCS Chairman's Award, Industrial Design Award, Entrepreneurship Award
[2014 - Present] 5046 Jacked Up Jackets| Mentor |
[2010 - 2013] 3421 Tachyon TECs| Mentor |2010 - Rookie Inspiration Award; 2013 - Coopertition Award , Kettering Quarterfinalists - 2nd Seed, Livonia Quarterfinalists - 2nd Seed Captain
[2009 - 2010] 2604 Metal and Soul| Student | 2010 - Gracious Professionalism Award, UL Industrial Safety Award
  #105   Spotlight this post!
Unread 06-01-2010, 17:18
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
I would LOVE carpet back!
I mean, doing doughnuts all day was fun and all, but i like POWER! TORQUE! ACCELERATION!
Carpet would be nice this year
I have been the designated driver on the team the past 3 years, and I liked driving for Rack and Roll the best.
heres my list:
#1: Rack-n-Roll
#2: Lunacy
#3: Overdrive (our robot was slow and cumbersome/hard to drive, and there were too many line rules for driving lol)
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
[BB] 2010 Game Hint #1 ATannahill Rumor Mill 577 28-03-2010 01:04
[Joke] 2010 Game Hint Greg Needel Rumor Mill 67 24-12-2009 10:30
Game Hint #1 Ice Berg Rumor Mill 898 03-12-2009 20:35
Game Hint #3 SuperJake General Forum 1 29-12-2008 14:59
Game hint #3 garyk General Forum 7 02-01-2008 16:54
