Go to Post If it reads MINUS voltage, the power is reversed (and this is bad). - DonRotolo [more]
Thread Tools Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
  #106   Spotlight this post!
Unread 06-01-2010, 17:22
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
Re: 2010 Game Hint #2
Originally Posted by jamie_1930 View Post
That's all that need be said.
This perfectly exemplifies the two opposite types of people
*serious people
*not serious people
haha, this made me laugh
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
  #107   Spotlight this post!
Unread 06-01-2010, 17:24
I'm with Art on the side paneling. I distinctly remember a robot in AZ 2003 running on practice day, and something went haywire in automode. The robot went up the ramp, over the top, took a left on the other side, and right between the top and bottom rails of the field. It ended up under the bleachers before someone got to the E-Stop. Fortunately, nobody was hit.
Every year since then, there has been a shield of some form (wire or plastic) to prevent that. It isn't always shown on the drawings, though.
The amount of carpet outside the field is irrelevant, and even so, there isn't half the field shown. Usually there's no more than about a yard outside on either side, left from putting two rolls side-by-side and centering the field on them. That's no more than about a 3-4-yard section there total, at an unknown area of the field. It may in fact be the corners, or it may be the middle. Just as a note, those support pillars can (technically) go into just about any joint on the field border that isn't on the ends. And I think your angle is skewed; the ramp doesn't go into the field. Rather, there is a cutout in the lower part of the field border which can give that perception.
The key element is this: there is a gate in the side of the field. Next to that gate is clear of obstructions at the time shown in this CAD. Somewhere else on the field is the item in Hint #1. That is all we know at this time;usually, the rest of the hints come out on Saturday during Kickoff right before the curtain comes down.
  #108   Spotlight this post!
Unread 06-01-2010, 17:28
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
OK. Lets look at what is not there!
The track from hint #1 is not in hint #2.
so where is it? Well if the field is symmetrical then we can multiply the hint#2 view by 4. we are now seeing almost 1/3 of the total field surface. The area we cannot see is the middle and the two ends.
The track from hint #1 seemed to want to be attached to other pipe. Thus the long pair of pipe must be somewhere we cannot see. I suggest it be against the ends of the field. Because the lexan frame that holds the pipe would need to be mounted to some support.
Happiest when people tell the truth... However, I am blessed with many friends.
  #109   Spotlight this post!
Unread 06-01-2010, 17:31
ATannahill ATannahill is offline
AKA: Alex Tannahill
Your forgetting a third dimension.
- Arizona North
  #110   Spotlight this post!
Unread 06-01-2010, 17:38
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
Originally Posted by artdutra04 View Post
The yellow plates are on the outside of the field, and are there to keep people from tripping. They are polyethylene (plastic) panels. I'm guessing the reason they are flat in the second game hint is because they were too lazy to actually model the curve. They have hook Velcro on the bottom, and are stuck to the carpet just by putting pressure down on them, as they bend quite easily.
Would this mean that the game hint isn't about the yellow pads? If they have been around in previous years and they are back this year, then that doesn't really seem like anything new.
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
  #111   Spotlight this post!
Unread 06-01-2010, 17:57
Katie_UPS's Avatar
Katie_UPS Katie_UPS is offline
AKA: Katie Widen
Katie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond reputeKatie_UPS has a reputation beyond repute
I believe the robots will have to ride unicycles. The wider gates are for the EMTs to pick up any robots that get hurt.
  #112   Spotlight this post!
Unread 06-01-2010, 18:01
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Arrive in Florida, get a free suite, and there is another game hint, NICE!
From the looks of a more open field, I'm thinking that the scoring is either A: on the left and right and left side of the field much like 2006 or B: in the middle of the field like in 2007.
Oh and I see much more carpet than in previous years!
1058 PVC Pirates 2016 - xxxx
  #113   Spotlight this post!
Unread 06-01-2010, 18:12
carolynn4848's Avatar
carolynn4848 carolynn4848 is offline
a.k.a. Coraline
FRC #1735 (Green Reapers)
Team Role: Operator
carolynn4848 is a glorious beacon of lightcarolynn4848 is a glorious beacon of lightcarolynn4848 is a glorious beacon of lightcarolynn4848 is a glorious beacon of lightcarolynn4848 is a glorious beacon of light
Send a message via AIM to carolynn4848 Send a message via Yahoo to carolynn4848
Originally Posted by TD912 View Post
Unless they are giving us different wheels this year... Or the GDC threw us a curveball and the field will be grey colored regolith... >_>
I personally think that would be awesome. I loved driving on the regolith.
I think I have an addiction. To FIRST.
I am Coraline! Hear me roar!!
  #114   Spotlight this post!
Unread 06-01-2010, 18:16
Yin-Yang's Avatar
Yin-Yang Yin-Yang is offline
FRC #1189 (The Gearheads)
Yin-Yang can only hope to improve
Send a message via AIM to Yin-Yang
the Grayish mass on the top could be interpreted as a WALL if u focus your eyes differnet
  #115   Spotlight this post!
Unread 06-01-2010, 18:22
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Interesting idea, but it appears to be just the same background FIRST used for the first hint. In any case, if that was a wall, it seems highly unlikely that the gate would still be structured in the same way...
Does anyone else remember when TBA signatures actually worked?
  #116   Spotlight this post!
Unread 06-01-2010, 18:27
LavastormSW's Avatar
LavastormSW LavastormSW is offline
AKA: Stef
FRC #2129 (Ultraviolet Robotics)
LavastormSW is an unknown quantity at this point
Send a message via AIM to LavastormSW
The yellow platforms look like they may be on hinges, allowing the gray handle to rest on the field, causing the yellow platforms to be vertical. Perhaps we have to design robots to shoot the platforms down.
To the optimist, the glass is half full. To the pessimist, the glass is half empty. To the engineer, the glass is twice as big as it needs to be.
“Scientists dream about doing great things. Engineers do them.”
- James A. Michener
  #117   Spotlight this post!
Unread 06-01-2010, 18:30
As noted previously, those yellow "platforms" happen to be trip guards on field support units, and the gray "handle" happens to be the field border. Ask any other member of your team, or see the pictures earlier in this thread.
  #118   Spotlight this post!
Unread 06-01-2010, 18:34
AKA: Stef
Originally Posted by dustinjeremy2k View Post
This was my second observation, but again, I think it's a mistake (like the yellow trip hazard plates that should be bent instead of flat).
On the contrary, I think that making those yellow plates straight and not curved was deliberate. It doesn't seem like they would make a simple mistake like that.
Originally Posted by GaryVoshol View Post
They cover the field wall supports so people don't trip.
Originally Posted by DUCKY View Post
The Yellow squares in the drawing are to prevent/identify tripping hazards around the fields. All fields had them... maybe not all were yellow... but they were there.
Then why wouldn't they be curved down to touch the floor in the picture? These look like they're there to serve some other purpose.
- James A. Michener
  #119   Spotlight this post!
Unread 06-01-2010, 18:36
AKA: Stef
I don't think they're trip guards. If they were, they would be curved down to touch the floor. It doesn't seem like they would make a simple mistake like forgetting to curve them.
- James A. Michener
  #120   Spotlight this post!
Unread 06-01-2010, 18:38
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Because they are not manufactured curved. The curve comes from the velcro that holds then to the floor.
[BB] 2010 Game Hint #1 ATannahill Rumor Mill 577 28-03-2010 01:04
[Joke] 2010 Game Hint Greg Needel Rumor Mill 67 24-12-2009 10:30
Game Hint #1 Ice Berg Rumor Mill 898 03-12-2009 20:35
Game Hint #3 SuperJake General Forum 1 29-12-2008 14:59
Game hint #3 garyk General Forum 7 02-01-2008 16:54
