Go to Post People should listen to this Andy Baker character, he seems like a smart guy... - Karthik [more]
Unread 06-01-2010, 19:24
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Unhappy Radio Interference
my team is trying to do a demonstration running multiple robots each with their own controls and ifi system but the radios are interfering with one another any idea how i could change the radio channel so they could run together?
P.S. they each have separate team numbers.
Thanks
Unread 06-01-2010, 19:29
Re: Radio Interference
Radio channel, for the IFI systems, is set by a block of 4 dip switches. I forget which setting is which channel, though. The block is on the left side of the display, and the channel may be viewed with the OI's "Select" button.
Unread 06-01-2010, 19:47
AKA: Jon
Unhappy Re: Radio Interference
Is that the only thing to switch the channel?
Unread 06-01-2010, 19:49
Should be. As I recall, the display you'll be looking for is "cXX", where "XX" is the channel. 40 was the default, IIRC.
Unread 06-01-2010, 20:13
DonRotolo's Avatar
Back to humble
FRC #0832
There are instructions somewhere on this forum, and elsewhere. I haven't time to search for them, but they are definitely there.
Unread 06-01-2010, 21:04
To enable the alternate channels on an IFI operator interface from 2005-2008, you have to have the team number set to a value of 2048 or higher, so that the most significant bit is a one. (If you change the team number to meet this requirement, remember that you'll have to tether the robot so that the RC can recognize the change.)
Here is what my cheat sheet says about the channel dipswitch settings:
1   2   3   4   Channel
X   ON  ON  ON  04
X   ON  ON  OFF 13
X   ON  OFF ON  22
X   ON  OFF OFF 31
X   OFF ON  ON  40
X   OFF ON  OFF 01
X   OFF OFF ON  40
X   OFF OFF OFF 40
This information is in the IFI control system documentation.
Unread 11-01-2010, 12:53
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Also a note: Two of those channels interfere with each other (although i can't for the life of me remember which two). At off season mini competitions, we FREQUENTLY ran into that when running 6 robots on the field at a time - 1 or two robots would become disabled seemingly "randomly", causing much frustration.
VEX Radio Range & Loss of Radio Fail Safe? Chris_Elston Programming 14 03-09-2008 09:13
Radio Channel Interference in a skirmish Leav Control System 2 09-03-2008 16:06
Competition Radio Interference Solution? FIRST JerseyKid Programming 21 04-01-2007 17:17
Large CIM Creating Radio interference Alex Burman Motors 1 13-02-2006 14:21
need 2003 radio/help with old radio MaxM Technical Discussion 2 04-01-2004 15:31
